Changes between Version 191 and Version 192 of WKTRaster/SpecificationWorking03
11/30/11 00:37:56 (13 years ago)
robe
  • TabularUnified WKTRaster/SpecificationWorking03
    v191 v192
    531531 * The raster_column view rows will always be in synch with the existing list raster columns.
    532532
    533  * All the information will be trustworthy because it will be enforced by constraints, so people can't change the band types etc... without changing the constraints. The raster_columns information will always be correct or null (if the constraint can not be not applied).
     533 * All the information will be trustworthy because it will be enforced by constraints, so people can't change the band types etc... without changing the constraints. The raster_columns information will always be correct or null (if the constraint can not be applied).
    534534
    535535 * Idem for the raster_overview table.
    536536
    537 PostGIS is using the typmod feature of PostgreSQL to 'store' metadata about a table and then display them in the geometry_column view. Unfortunately the typmod is limited to XXX bytes and there is too much information to 'store' about a raster table to use typmod. PostGIS raster will therefore use another approach consisting in 'storing' metadata about a raster table as constraint on the table. A set of constraint will be applied to a raster table and those constraint will be read and displayed by the raster_column view.
     537PostGIS is using the typmod feature of PostgreSQL to 'store' metadata about a table and then display them in the geometry_column view. Unfortunately the typmod is limited to XXX bytes and there is too much information to 'store' about a raster table to use typmod. PostGIS raster will therefore use another approach consisting of 'storing' metadata about a raster table as constraints on the table. A set of constraints will be applied to a raster table and those constraints will be read and displayed by the raster_column view.
    538538
    539539The '''major changes concerning the raster_column table''' are as follow:
    540540
    541  * There will be a flexible !ApplyRasterConstraint() function trying to apply a set of constraint on a table. As for any constraint, each constraint will be successfully applied only when all the rows of the table fulfil this constraint. The list of potential constraint applied by the C loader (using the !ApplyRasterConstraint function) and hence the list of column available in the raster_column view will be: srid int, samealignment boolean, scalex float8, scaley float8, width int, height int, numberofband int, pixeltypes text[], nodatavalues float[] in addition to the 'r_table_catalog', 'r_table_schema', 'r_table_name' and 'r_column' columns. There is still discussion about if global extent as a geometry should be added to this list. Comments are welcomes.
    542
    543  * The raster_column view rows will be determined by querying the PostgreSQL catalog. A typical query exist for this.
     541 * There will be a flexible !ApplyRasterConstraint() function trying to apply a set of constraint on a table. As for any constraint, each constraint will be successfully applied only when all the rows of the table fulfill this constraint. The list of potential constraint applied by the C loader (using the !ApplyRasterConstraint function) and hence the list of column available in the raster_column view will be: srid int, samealignment boolean, scalex float8, scaley float8, width int, height int, numberofbands int, pixeltypes text[], nodatavalues float[] in addition to the 'r_table_catalog', 'r_table_schema', 'r_table_name' and 'r_column' columns. There is still discussion about if global extent as a geometry should be added to this list. Comments are welcome.
     542
     543 * The raster_column view rows will be determined by querying the PostgreSQL catalog. A typical query exists for this.
    544544
    545545 * The raster_column view will derive columns of metadata from the constraints applied to each table listed. When a constraint does not exist (because it could not be applied successfully to the table by !ApplyRasterconstraint()), the column corresponding to this constraint for this table will be null.
    553553 * We will also provide a SQL function for creating overviews (ST_CreateOverview(schemaname text, tablename teat, columnname, factor int)).
    554554
    555  * The raster_overview table will NOT be created by default by the rtpostgis.sql script. It will be the responsibility of applications to use the !ApplyOverviewConstraints and ST_CreateOverview() function to create the raster_overviews view and create overviews.
     555 * The raster_overview view will NOT be created by default by the rtpostgis.sql script. It will be the responsibility of applications to use the !ApplyOverviewConstraints and ST_CreateOverview() function to create the raster_overviews view and create overviews.
    556556
    557557The '''major changes concerning the raster2pgsql loader''' are as follow:
