Changes between Version 206 and Version 207 of WKTRaster/SpecificationWorking03
07/24/12 13:41:23 (13 years ago)
pracine
  • TabularUnified WKTRaster/SpecificationWorking03
    v206 v207
    1818== ''Note that accomplished objectives have been moved at the bottom of the page.'' ==
    1919
     20----
     21== '''Objective 2.0.04 - Implement better support for NULL, Empty, !HasNoBand(rast), !HasNoBand(rast, band) and !BandIsNoData rasters in all functions.''' ==
     23 Each function should better handle NULL rasters, empty rasterm rasters with no band and bands only filled with nodata values.
     25  1) Generally, when NULL rasters are provided, return NULL. If the function involves a second non NULL raster and something can be done with it, do it.
     27  2) Generally, when empty rasters are provided (ST_IsEmpty, width=0 or height=0), return an empty raster. If the function involves a second non empty raster and something can be done with it, do it.
     28
     29  2) Generally, when a !HasNoBand(rast) or a !HasNoBand(rast, band) raster is provided return a raster with no band but with the right extent. If the function involves a second raster having a band or the band, treat the first missing band like a !BandIsNoData.
     30
     31  4) A !BandIsNoData raster is a normal raster but many functions can be optimized with this type of raster.
     32
     33  5) All functions having missing the requested information (about its extent when it is a NULL or an empty raster or about its band when it is a !HasNoBand(rast) or a !HasNoBand(rast, band) raster) should return NULL or a documented value.
     34
     35  6) Try as less as possible to return EXCEPTION (or ERROR).
     36
     37 See discussion in http://trac.osgeo.org/postgis/ticket/594
     38
     39'''ST_IsEmpty(rast) -> boolean'''
     40
     41 Returns TRUE if the raster width or the raster height is 0.
     42
     43'''ST_HasNoBand'''
     44
     45 '''Variants'''
     46
     47  1) ST_HasNoBand(rast, band) -> boolean
     48
     49  2) ST_HasNoBand(rast) -> boolean
     50
     51 Returns TRUE if the the raster does not have this band.
     52
     53 Variant 2 returns TRUE if the the raster does not have any band.
     54
     55'''ST_BandIsNoData'''
     56
     57 '''Variants'''
     58
     59  1) ST_BandIsNoData(rast, band) -> boolean
     60
     61  2) ST_BandIsNoData(rast) -> boolean
     62
     63 Returns TRUE if the specified raster band is only filled with no data value.
     64
     65 Variant 2 default to band 1.
     66
     67 '''Implementation details'''
     68
     69 This require a new flag to be set in the core at import and at edition. See discussion in http://trac.osgeo.org/postgis/ticket/593
    2070
    2171----
    472522== Accomplished objectives ==
    473523
    474 ----
    475 == '''Objective FV.01 - Being able to return a JPEG, a TIFF, a PNG or any image format supported by GDAL - ''Done''''' ==
    476
    477 '''ST_bytea(raster, integer) -> raster''' -- the integer parameters is the band number of the raster.[[BR]]
    478 What is does?
    479
    480 ----
    481 ~~'''Open Question:''' When exporting a multiband raster to JPEG, TIFF, PNG, SVG or KML, how should we specify the band number in the exporting function.~~
    482
    483 ~~There is two options to select the band to convert from a multiband raster in all the ST_AsFormat functions. [[BR]]~~
    484 [[BR]]
    485 ~~ 1. Precede each call with ST_Band() to return a selected band.[[BR]]~~
    486 ~~  Pros: This is a general function that can be called before any function that would otherwise require a band parameter.[[BR]]~~
    487 ~~  Cons: This implies creating a temporary raster. This might be more elegant and general but is this too much overhead comparing with having a band parameter?~~
    488
    489 ~~ 2. Add a band parameter to each ST_AsFormat function.[[BR]]~~
    490 ~~  Pros: Hypothetically less overhead.[[BR]]~~
    491 ~~  Cons: Every functions implying access to a band should then have this parameter when in most case it would be equal to 1. In many cases it makes no sence to have to specify a band parameter since it is the whole raster that we want to export, including all the bands.~~
    492
    493 ~~Pierre: More I think about it more I think that the first option is the best one...~~
    494
    495 ~~mloskot: Perhaps there is a compromise in form of two sets of functions: 1) ST_As* which always burn the whole raster (all bands) 2) ST_BandAs* which takes number of band as a parameter and return only this requested band.~~
    496
    497 ----
    498
    499 '''ST_Band(raster, integer) -> raster''' -- the integer parameters are the band number of the rasters.[[BR]]
    500 Return a single band from a multiband raster. If "band" is greater than the value returned by ST_GetNumBands(), the function returns the last band. This function should be used to select a band before converting it to JPEG, TIFF, PNG, SVG or KML with the corresponding function. e.g. '''ST_AsTIFF(ST_Band(raster, band))
    501
    502 A complete implementation of ST_Band should include the following:
    503
    504 1. ST_Band(rast raster, nbands int[]) -> raster
    505
    506     nbands is an array of 1-based band indices of the bands to copy into the output raster
    507
    508     For a raster rast with 3 bands:
    509 {{{
    510 ST_Band(rast, ARRAY[1,3,2])
    511
    512 ST_Band(rast, ARRAY[3,2,1])
    513 }}}
    514     You can rearrange the bands as above. You can also duplicate the bands:
    515 {{{
    516 ST_Band(rast, ARRAY[1,2,3,2,1])
    517 }}}
    518
    519 2. ST_Band(rast raster, nband int) -> raster
    520
    521     nband is a single integer of the 1-based band index of the band to copy into the output raster
    522
    523 {{{
    524 ST_Band(rast, 1)
    525
    526 ST_Band(rast, 3)
    527 }}}
    528
    529 3. ST_Band(rast raster, nbands text) -> raster
    530
    531     nbands is a comma separated string of 1-based band indices indicating the bands to copy into the output raster
    532
    533 {{{
    534 ST_Band(rast, '1,2')
    535
    536 ST_Band(rast, '1,2,3, 1, 1 , 2')
    537 }}}
    538
    539 4. ST_Band(rast raster, nbands text, delimiter char) -> raster
    540
    541     nbands is a user-specified delimiter separated string of 1-based band indices indicating the bands to copy into the output raster
    542
    543 {{{
    544 ST_Band(rast, '1,2', ',')
    545
    546 ST_Band(rast, '1,2,3, 1, 1 , 2', ',')
    547 }}}
    548
    549 5. ST_Band(rast raster) -> raster
    550
    551     the band to extract is automatically assumed to be one.
    552
    553 {{{
    554 ST_Band(rast)
    555 }}}
    556
    557 If an index is outside the valid range of band indices for a raster (less than 1 or greater than the value returned by ST_NumBands), the function will fail and return.
    558
    559 ~~''' Open Question: ''' Should the function fail if an index is invalid?  How should this work when providing more than one indices to the function?~~
    560
    561 ----
    562
    563 '''ST_AsJPEG(raster, quality) -> JPEG as "bytea"'''[[BR]]
    564
    565 The JPEG format has several limitations:
    566
    567   1. JPEG only allows 1 (greyscale) or 3 (RGB) bands of data
    568
    569   2. JPEG only supports 8BUI pixeltype
    570
    571   3. JPEG cannot embed spatial reference information within the file but can have an associated world file
    572
    573 To address the limitations:
    574
    575   1. Use ST_Band to specify which band(s) should be passed to the ST_AsJPEG function. Variations of ST_AsJPEG are made available that allows specifying a band index. If a raster whose number of specified bands does not equal 1 or 3 is provided, a warning is raised and the first or the first three bands are used.
    576
    577   2. Throw an exception if any of the specified bands is not 8BUI. The user should use ST_Reclass to convert any non-8BUI bands to 8BUI.
    578
    579   3. Nothing can be done.
    580
    581 A proposed set of variations of the ST_AsJPEG function:
    582
    583 1. ST_AsJPEG(rast raster, options text[])
    584
    585     rast: the raster with one or three bands in 8BUI pixel type to generate a JPEG image from
    586
    587     options: array of creation options to pass to the GDAL JPEG driver
    588
    589 {{{
    590 ST_AsJPEG(rast, ARRAY['QUALITY=90', 'PROGRESSIVE=ON'])
    591 }}}
    592
    593 2. ST_AsJPEG(rast raster)
    594
    595     Like !#1 above but use the driver's default creation options
    596
    597 3. ST_AsJPEG(rast raster, nbands int[], options text[])
    598
    599     nbands: an integer array specifying the band indices of the raster to include in the JPEG file
    600
    601 {{{
    602 ST_AsJPEG(rast, ARRAY[1,3,6], ARRAY['QUALITY=50'])
    603 }}}
    604
    605 4. ST_AsJPEG(rast raster, nbands int[])
    606
    607     Like !#3, but use the default creation options
    608
    609 {{{
    610 ST_AsJPEG(rast, ARRAY[1,3,6])
    611 }}}
    612
    613 5. ST_AsJPEG(rast raster, nbands int[], quality int)
    614
    615     quality: number between 10 and 100 indicating image quality
    616
    617 {{{
    618 ST_AsJPEG(rast, ARRAY[1,2,3], 90)
    619 }}}
    620
    621 6. ST_AsJPEG(rast raster, nband int, options text[])
    622
    623     nband: index of the band to include
    624
    625 {{{
    626 ST_AsJPEG(rast, 2, ARRAY['QUALITY=25'])
    627 }}}
    628
    629 7. ST_AsJPEG(rast raster, nband int, quality int)
    630
    631 {{{
    632 ST_AsJPEG(rast, 5, 75)
    633 }}}
    634
    635 8. ST_AsJPEG(rast raster, nband int)
    636
    637 {{{
    638 ST_AsJPEG(rast, 4)
    639 }}}
    640
    641 ''OLD NOTES''
    642
    643 ~~Return the raster as a JPEG encoded as a PostgreSQL bytea. By default quality is set to 75, but this option can be used to select other values. Values must be in the range 10-100. Low values result in higher compression ratios, but poorer image quality. Values above 95 are not meaningfully better quality but can but substantially larger. (copied from http://www.gdal.org/frmt_jpeg.html)~~
    644
    645
    646 ~~'''Open Question:''' Is JPEG export limited to raster having 8 bit unsigned integer pixeltype (8BUI)?~~
    647
    648 ~~[http://www.gdal.org/frmt_jpeg.html See how GDAL do it]. It converts only 8 bits rasters. Should we do the same?~~
    649
    650 ~~Otherwise, how do we convert other types to 8BUI? e.g. 16BUI or 8BSI?~~
    651
    652 ~~Pierre: It might be more simple to ignore pixeltypes other than 8BUI but it would be very convenient to have a way to quickly export elevation data for example as a JPEG. It would be nice to have an elegant solution to this. Maybe something inspired from !MapServer.~~
    653
    654 ~~Proposition one (Pierre): ST_AsJPEG could simply (optionally when the pixeltype is not 8BUI) map the ST_Maximum() and ST_Minimum() value to 0-255. ST_Maximum() and ST_Minimum() are not in the spec yet but this could be on nice usage of it. They will imply caching the min and max when importing and editing. Both function should ignore the !NoDataValues. They could also be two parameters passed to ST_AsJPEG(raster, quality, min, max).~~
    655
    656 ~~Proposition two: There could also be just one parameter (string) defining a mapping method:~~
    657
    658 ~~ * Method "None": No mapping. This is possible only for 8BUI.~~
    659
    660 ~~ * Method "!MaxMinValue": Use the Max and the Min cached in the raster. e.g. for 16BSI (min, max) -> (-2033, 2456) -> (round((-2033 - -2033)/(2456 - -2033)*255), round((2456 - -2033)/(2456 - -2033)*255)) -> (0, 255).[[BR]]~~
    661 ~~[[BR]]This is equivalent to ST_AsJPEG(raster, quality, ST_Minimum(rast), ST_Maximum(rast))~~
    662
    663 ~~ * Method "!MaxMinType": Use the Max and the Min allowed by the type. e.g. for 16BSI (min, max) -> (-2033, 2456) -> (round((-2033 - -32768)/(32767 - -32768)*255), round((2456 - -32768)/(32767 - -32768)*255)) -> (120, 137)[[BR]]~~
    664 ~~[[BR]]This would be equivalent to ST_AsJPEG(raster, quality, ST_BandPixelTypeMin(rast), ST_BandPixelTypeMax(rast)). Both functions (ST_BandPixelTypeMin & ST_BandPixelTypeMax) are not yet planned and I could not find an SQL query that returns the equivalent range for a type. [http://groups.google.nl/group/microsoft.public.sqlserver.programming/browse_thread/thread/46512c2691da4607/6743f4aea485c6d1 One possible solution.]~~
    665
    666
    667 ~~mloskot: ATM, I have no thoughts on this issue.~~
    668
    669 ~~'''Open Question:''' Is JPEG export limited to raster having 1 or 3 bands?~~
    670
    671 ~~[http://www.gdal.org/frmt_jpeg.html See how GDAL do it]. It converts only 1 or 3 band rasters. Should we do the same? In this case 1 band rasters would be exported as a greyscale JPEG having R G and B identical and 3 band rasters would be interpreted as R, G and B.~~
    672
    673 ~~Pierre: I think the answer should be yes. I don't see how we could have a 2 band raster fit into RGB.~~
    674
    675 ~~mloskot: I agree, the answer should be yes.~~
    676
    677 ~~'''Here is an attempt to define the different versions of the function:'''~~
    678
    679 ~~The most minimalistic versions of the function should assume band 1, 2 and 3 as being r, g, b and the quality equal to 75:~~
    680
    681 ~~ ST_AsJPEG(raster) -quality = 75~~
    682
    683 ~~A variant allow specifying the quality:~~
    684
    685 ~~ ST_AsJPEG(raster, integer)~~
    686
    687 ~~Another variant should enable us to specify which band correspond to the r, the g and the b:~~
    688
    689 ~~ ST_AsJPEG(raster, integer, integer, integer) - raster, rband, gband, bband, quality=75~~
    690
    691 ~~ ST_AsJPEG(raster, integer, integer, integer, integer) - raster, rband, gband, bband, quality~~
    692
    693 ~~Another version should be designed to be used with a future ST_Band(raster) function. In this case there is no attempt to extract r, g or b band from any passed raster:~~
    694
    695 ~~ ST_AsJPEG(raster, raster, raster)~~
    696
    697 ~~ ST_AsJPEG(raster, raster, raster, integer) -with the quality param~~
    698
    699 ~~Another series should allow converting 1 band raster with pixel of type 8BUI to a grayscale JPEG (Carefull study of the GDAL behavior when converting a single band to JPEG should be done before confirming these functions):~~
    700
    701 ~~ ST_AsJPEG(raster, "GRAYSCALE") - convert only band 1 with quality = 75~~
    702
    703 ~~ ST_AsJPEG(raster, "GRAYSCALE", integer) - convert only band 1 with specified quality~~
    704
    705 ~~ ST_AsJPEG(raster, integer, "GRAYSCALE") - allow specifying the band number to convert~~
    706
    707 ~~ ST_AsJPEG(raster, integer, "GRAYSCALE", integer) - allow specifying the band number to convert and the quality~~
    708
    709 ~~Another series should allow converting 1 band raster of ANY pixel type to a grayscale JPEG. Pixel types different than 8BUI should be mapped according to specified min, max values and a mapping mode: "!MaxMinValue" (default) or "!MaxMinType".~~
    710
    711 ~~ ST_AsJPEG(raster, "GRAYSCALE", min, max, text) - convert only band 1 with quality = 75~~
    712
    713 ~~ ST_AsJPEG(raster, "GRAYSCALE", integer, min, max, text) - convert only band 1 with specified quality~~
    714
    715 ~~ ST_AsJPEG(raster, integer, "GRAYSCALE", min, max, text) - allow specifying the band number to convert~~
    716
    717 ~~ ST_AsJPEG(raster, integer, "GRAYSCALE", integer, min, max, text) - allow specifying the band number to convert and the quality~~
    718
    719 ----
    720
    721 '''ST_AsTIFF(raster, compression) -> TIFF as "bytea"'''[[BR]]
    722 Return the raster as a TIFF encoded as a PostgreSQL bytea. If raster is a multiband raster and no band were selected with ST_Band() every band are written to the resulting TIFF.
    723
    724 compression=[JPEG/LZW/PACKBITS/DEFLATE/CCITTRLE/CCITTFAX3/CCITTFAX4/NONE]: Set the type of compression to use. None is the default. The CCITT compression should only be used with 1bit (NBITS=1) data. JPEG should only be used with Byte data. When using JPEG add a number specifying the quality. 75 is the default. e.g. ST_AsTIFF(raster, "JPEG60") (copied from http://www.gdal.org/frmt_gtiff.html)
    725
    726 A proposed implementation of the ST_AsTIFF functions.
    727
    728 The TIFF format is probably the most robust available for converting rasters to GDAL rasters. Not only does it support all PostGIS Raster pixel types, it also provides plenty of creation options and possibly no issues with the number of bands. The only limitation found is that there can only be one NODATA value for all bands.
    729
    730 ''If the compression parameter/option is specified to JPEG, all bands must be of pixel type 8BUI.  If the compression parameter/option is specified to one of the CCITT options, all bands must be of pixel type 1BB.  If any band violates the restriction, an exception is raised.''
    731
    732 The next three functions are the most basic of the ST_AsTIFF functions.
    733
    734 1. ST_AsTIFF(rast raster, options text[], srs text) -> bytea
    735
    736     The most generic version of this function. All other ST_AsTIFF functions call this function.
    737
    738     This function will check that all bands of the raster to be converted has the same NODATA value. If there are more than one possible NODATA values, a WARNING will be raised and the output TIFF will use the NODATA value of the first band with a NODATA value.
    739
    740         options: the GDAL creation options found in the Creation Options section of the GDAL TIFF driver
    741
    742         srs: the user-specified OGC WKT or the proj4 text for a spatial reference to embed in the GDAL raster. TIFF is one of the formats that supports embedding the spatial reference within the image file.
    743
    744 {{{
    745 ST_AsTIFF(rast, ARRAY['COMPRESS=DEFLATE', 'ZLEVEL=9'], '+proj=aea +lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000 +ellps=GRS80 +datum=NAD83 +units=m +no_defs')
    746
    747 ST_AsTIFF(rast, ARRAY['COMPRESS=DEFLATE', 'ZLEVEL=9'], 'PROJCS["NAD83 / California Albers",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Albers_Conic_Equal_Area"],PARAMETER["standard_parallel_1",34],PARAMETER["standard_parallel_2",40.5],PARAMETER["latitude_of_center",0],PARAMETER["longitude_of_center",-120],PARAMETER["false_easting",0],PARAMETER["false_northing",-4000000],AUTHORITY["EPSG","3310"],AXIS["X",EAST],AXIS["Y",NORTH]]')
    748 }}}
    749
    750 2. ST_AsTIFF(rast raster, options text[]) -> bytea
    751
    752 This one removes the user-specified srs argument. The output TIFF's spatial reference will be set to the same as the input raster, if possible.
    753
    754 {{{
    755 ST_AsTIFF(rast, ARRAY['COMPRESS=DEFLATE', 'ZLEVEL=9'])
    756 }}}
    757
    758 3. ST_AsTIFF(rast raster) -> bytea
    759
    760 The simplest implementation of this function. Since the options argument has been removed, the output TIFF will be created with default options. Like the prior function, the spatial reference of the TIFF will be set to the same as the input raster.
    761
    762 {{{
    763 ST_AsTIFF(rast)
    764 }}}
    765
    766
    767 The next three functions add a band index argument to filter the raster's bands before generating the output TIFF.
    768
    769 4. ST_AsTIFF(rast raster, nbands int[], options text[], srs text) -> bytea
    770
    771 {{{
    772 ST_AsTIFF(rast, ARRAY[3,1,2], ARRAY['COMPRESS=DEFLATE', 'ZLEVEL=9'], '+proj=aea +lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000 +ellps=GRS80 +datum=NAD83 +units=m +no_defs')
    773 }}}
    774
    775 5. ST_AsTIFF(rast raster, nbands int[], options text[]) -> bytea
    776
    777 This one removes the user-specified srs argument. The output TIFF's spatial reference will be set to the same as the input raster, if possible.
    778
    779 {{{
    780 ST_AsTIFF(rast, ARRAY[3,1,2], ARRAY['COMPRESS=DEFLATE', 'ZLEVEL=9'])
    781 }}}
    782
    783 6. ST_AsTIFF(rast raster, nbands int[]) -> bytea
    784
    785 Since the options argument has been removed, the output TIFF will be created with default options. Like the prior function, the spatial reference of the TIFF will be set to the same as the input raster.
    786
    787 {{{
    788 ST_AsTIFF(rast, ARRAY[3,1,2])
    789 }}}
    790
    791
    792 The next two functions add a compression argument. If the compression desired is JPEG or DEFLATE, the user can specify a quality as part of the compression string.
    793
    794 Examples are:
    795
    796 {{{
    797 JPEG90
    798
    799 JPEG
    800
    801 DEFLATE8
    802
    803 DEFLATE
    804 }}}
    805
    806 7. ST_AsTIFF(rast raster, compression text, srs text) -> bytea
    807
    808 This function will parse the compression string for the compression type and the compression quality. It will also inspect to make sure that the pixel types of the raster's bands are appropriate for the compression type. This is primarily for JPEG and CCITT compression types, which only support 8BUI and 1BB respectively.
    809
    810 {{{
    811 ST_AsTIFF(rast, 'JPEG90', '+proj=aea +lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000 +ellps=GRS80 +datum=NAD83 +units=m +no_defs')
    812
    813 ST_AsTIFF(rast, 'JPEG', '+proj=aea +lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000 +ellps=GRS80 +datum=NAD83 +units=m +no_defs')
    814
    815 ST_AsTIFF(rast, 'LZMA', '+proj=aea +lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000 +ellps=GRS80 +datum=NAD83 +units=m +no_defs')
    816 }}}
    817
    818 8. ST_AsTIFF(rast raster, compression text) -> bytea
    819
    820 The output TIFF will be created with default options. Like the prior function, the spatial reference of the TIFF will be set to the same as the input raster.
    821
    822 {{{
    823 ST_AsTIFF(rast, 'LZMA')
    824 }}}
    825
    826
    827 The next two functions include band index and compression arguments
    828
    829 9. ST_AsTIFF(rast raster, nbands int[], compression text, srs text) -> bytea
    830
    831 {{{
    832 ST_AsTIFF(rast, ARRAY[2], 'JPEG90', ARRAY['BIGTIFF=IF_NEEDED'], '+proj=aea +lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000 +ellps=GRS80 +datum=NAD83 +units=m +no_defs')
    833
    834 ST_AsTIFF(rast, ARRAY[1,3], 'JPEG', ARRAY['BIGTIFF=IF_NEEDED'], '+proj=aea +lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000 +ellps=GRS80 +datum=NAD83 +units=m +no_defs')
    835
    836 ST_AsTIFF(rast, ARRAY[3,1,2], 'LZMA', ARRAY['BIGTIFF=IF_NEEDED'], '+proj=aea +lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000 +ellps=GRS80 +datum=NAD83 +units=m +no_defs')
    837 }}}
    838
    839 10. ST_AsTIFF(rast raster, nbands int[], compression text) -> bytea
    840
    841 {{{
    842 ST_AsTIFF(rast, ARRAY[3,2], 'DEFLATE9')
    843 }}}
    844
    845 The output TIFF will be created with default options. The spatial reference of the TIFF will be set to the same as the input raster.
    846
    847 ----
    848 ~~'''Open Question:''' What if we want to export only the first two band of a three band layer?~~
    849
    850 ~~Maybe we need a ST_RasterFromBands(band1, band2, etc...) to reconstitute a multiband raster from multiple sources (having the same width, height, pixelsize, etc...)~~
    851
    852 ~~mloskot: or ST_RasterFromBands(bands) where bands is ARRAY[int]. For instance, ST_RasterFromBands(ARRAY[1,3]) will burn new raster from 1 and 3 bands of input raster.~~
    853
    854 ----
    855 '''ST_AsPNG(raster, band) -> PNG as "bytea"'''
    856
    857 Like the JPEG raster format, the PNG format has limitations:
    858
    859   1. PNG only allows 1 (greyscale) or 3 (RGB) bands of data
    860
    861   2. PNG only supports 8BUI and 16BUI pixeltypes. Any other pixeltype will be written as 8BUI, though the results are probably useless
    862
    863   3. PNG cannot embed spatial reference information within the file but can have an associated world file
    864
    865 Like JPEG, the limitations can be resolved:
    866
    867   1. Use ST_Band to specify which band(s) should be passed to the ST_AsPNG function. If a raster whose number of specified bands does not equal 1 or 3 is provided, a warning is raised and the first or the first three bands are used.
    868
    869   2. Throw an exception if any of the specified bands is not 8BUI or 16BUI. The user should use ST_Reclass to convert any non-8BUI or 16BUI bands to 8BUI or 16BUI.
    870
    871   3. Nothing can be done within this function. ST_Georeference() can be used to the contents of the associated world file
    872
    873 A proposed set of variations of the ST_AsPNG function:
    874
    875 1. ST_AsPNG(rast raster, options text[])
    876
    877     rast: the raster with one or three bands in 8BUI or 16BUI pixel type to generate a PNG image from
    878
    879     options: array of creation options to pass to the GDAL PNG driver
    880
    881 {{{
    882 ST_AsPNG(rast, ARRAY['ZLEVEL=9'])
    883 }}}
    884
    885 2. ST_AsPNG(rast raster)
    886
    887     Like !#1 above but use the driver's default creation options
    888
    889 3. ST_AsPNG(rast raster, nbands int[], options text[])
    890
    891     nbands: an integer array specifying the band indices of the raster to include in the PNG file
    892
    893 {{{
    894 ST_AsPNG(rast, ARRAY[3,1,2], ARRAY['ZLEVEL=9'])
    895 }}}
    896
    897 4. ST_AsPNG(rast raster, nbands int[])
    898
    899     Like !#3, but use the default creation options
    900
    901 {{{
    902 ST_AsPNG(rast, ARRAY[3])
    903 }}}
    904
    905 5. ST_AsPNG(rast raster, nbands int[], compression int)
    906
    907     compression: number between 1 and 9 indicating the amount of time to spend on compression. 1 is fastest with least compression. 9 is slowest with best compression
    908
    909 {{{
    910 ST_AsPNG(rast, ARRAY[2,1,3], 3)
    911 }}}
    912
    913 6. ST_AsPNG(rast raster, nband int, options text[])
    914
    915     nband: index of the band to include
    916
    917 {{{
    918 ST_AsPNG(rast, 2, ARRAY['ZLEVEL=5'])
    919 }}}
    920
    921 7. ST_AsPNG(rast raster, nband int, compression int)
    922
    923 {{{
    924 ST_AsPNG(rast, 1, 8)
    925 }}}
    926
    927 8. ST_AsPNG(rast raster, nband int)
    928
    929 {{{
    930 ST_AsPNG(rast, 1)
    931 }}}
    932
    933 ----
    934
    935 '''ST_AsGDALRaster(raster, band int, type text, options text) -> bytea'''
    936
    937 Use GDAL to convert the raster into one of the format suported by GDAL.
    938
    939 This is a generic interface to outputting a supported and installed GDAL raster:
    940
    941 1. ST_AsGDALRaster(rast raster, format text, options text[], srs text) -> bytea
    942
    943   This is the most generic and GDAL-specific method to convert a raster to a GDAL raster.  All other version of ST_AsGDALRaster and other format specific functions (ST_AsJPEG, ST_AsTIFF and ST_AsPNG) are all wrappers around this function.  Reference information for the format and options arguments of a particular format are specified at: http://gdal.org/formats_list.html.  The arguments specified are:
    944
    945   format: the GDAL format code.  e.g. GTiff, JPEG, PNG
    946
    947   options: the GDAL creation options found in the '''Creation Options''' section of a specified format.  e.g. COMPRESS=JPEG, JPEG_QUALITY=90
    948
    949   srs: the user-specified OGC WKT or the proj4 text for a spatial reference to embed in the GDAL raster.  Not all formats support embedding this information.  e.g. the non-empty value for the srtext or proj4text column from the spatial_ref_sys table.
    950
    951 {{{
    952 ST_AsGDALRaster(rast, 'GTiff', ARRAY['COMPRESS=JPEG', 'JPEG_QUALITY=90'], '+proj=aea +lat_1=34 +lat_2=40.5 +lat_0=0 +lon_0=-120 +x_0=0 +y_0=-4000000 +ellps=GRS80 +datum=NAD83 +units=m +no_defs')
    953
    954 ST_AsGDALRaster(rast, 'GTiff', ARRAY['COMPRESS=JPEG', 'JPEG_QUALITY=90'], 'PROJCS["NAD83 / California Albers",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Albers_Conic_Equal_Area"],PARAMETER["standard_parallel_1",34],PARAMETER["standard_parallel_2",40.5],PARAMETER["latitude_of_center",0],PARAMETER["longitude_of_center",-120],PARAMETER["false_easting",0],PARAMETER["false_northing",-4000000],AUTHORITY["EPSG","3310"],AXIS["X",EAST],AXIS["Y",NORTH]]')
    955 }}}
    956
    957
    958 2. ST_AsGDALRaster(rast raster, format text, options text[]) -> bytea
    959
    960   This one removes the user-specified srs argument.  The output GDAL raster's spatial reference will be set to the same as the input raster, if possible.
    961
    962 {{{
    963 ST_AsGDALRaster(rast, 'JPEG', ARRAY['QUALITY=50'])
    964
    965 ST_AsGDALRaster(rast, 'PNG', ARRAY['ZLEVEL=7'])
    966 }}}
    967
    968 3. ST_AsGDALRaster(rast raster, format text) -> bytea
    969
    970   The simplest implementation of this function.  Since the options argument has been removed, the output GDAL raster will be created with default options.  Like the prior function, the spatial reference of the GDAL raster will be set to the same as the input raster.
    971
    972 {{{
    973 ST_AsGDALRaster(rast, 'JPEG')
    974 }}}
    975
    976 ----
    977
    978 '''ST_GDALDrivers() -> set of record'''
    979
    980 As each GDAL installation may be different and ST_AsGDALRaster can be used to support formats other than GTiff, JPEG and PNG, a method is needed to expose to the end user the possible GDAL formats capable of being exported.  This function will output the following columns.
    981
    982   idx: the internal GDAL index number
    983
    984   short_name: the GDAL format code.  This is the value to pass to the format paramenter of ST_AsGDALRaster
    985
    986   long_name: the full name of the GDAL format
    987
    988   create_options: the creation options available for the format as an XML string.
    989
    990 The formats outputted from ST_getGDALDrivers have been filtered to only those that the GDAL capabilities !CreateCopy and Virtual IO support.
    991
    992 '''Open Question:''' Should the GDAL raster process be capable of supporting the GDAL capability Create?  As the GDAL raster process writes nothing to a file in the filesystem (via Virtual IO), should there be support for writing the output GDAL raster temporarily to the filesystem?  If so, how is it done in other PostgreSQL extensions in a secure manner?
    993
    994 ----
    995
    996 ~~'''ST_srtext(rast raster) -> text'''
    997
    998 ~~A helper function to get the value of column srtext or proj4text for a raster with an SRID.  By default, the srtext is returned.  If srtext is not available but proj4text is, the proj4text is returned.
    999
    1000 ~~This function may be removed based upon the capabilities of SPI.  It may not be possible to remove this function as the srs function argument of ST_AsGDALRaster can be NULL, thereby instructing the function to not embed any spatial reference information into the output GDAL raster.
    1001
    1002 ----
    1003
    1004 '''ST_Reclass(rast raster, VARIADIC argset reclassarg[]) -> raster'''
    1005
    1006 Due to limitations in the JPEG (8BUI) and PNG (8BUI and 16BUI) raster formats regarding supported pixel/data types, a method must be provided that can convert a band of a larger data type to 8BUI, amongst other uses.  ST_Reclass allows raster's band pixel values to be remapped from one range of numbers to another as well as between pixel types, e.g. 32BF to 8BUI.
    1007
    1008 ST_Reclass returns a duplicate of the submitted raster with the bands specified to be reclassed being processed.  This means that if a raster with 5 bands are submitted and band 1 is to be reclassed, the output raster will have 5 bands with band 1 reclassified.  The other four bands will not be touched.
    1009
    1010 1. ST_Reclass(rast raster, VARIADIC argset reclassarg[]) -> raster
    1011
    1012   rast: the raster whose specified bands are to be reclassified
    1013
    1014   reclassarg: a new custom type defining the parameters required for reclassifying a band's pixel values.
    1015
    1016 {{{
    1017 CREATE TYPE reclassarg AS (
    1018
    1019   nband int,
    1020
    1021   reclassexpr text,
    1022
    1023   pixeltype text,
    1024
    1025   nodata double
    1026
    1027 );
    1028 }}}
    1029
    1030     nband: index of the band to reclass (1-based)
    1031
    1032     reclassexpr: reclassification expression indicating the ranges to convert from and to.  More than one expression can be provided by separating the expression with a comma (,).  The values provided can be of any valid numeric type.
    1033
    1034       ''rangefrom:rangeto[, rangefrom:rangeto]''
    1035
    1036 {{{
    1037 0-100:0-10
    1038
    1039 0-100:0-10, 101-1000:11-100
    1040
    1041 0-100:0-10, 101-1000:11-100, 1001-10000:101-1000
    1042 }}}
    1043
    1044       In the last example above, the default evaluation of the ranges is
    1045
    1046 {{{
    1047         0 <= x < 100 reclassified to 0 <= y <= 10
    1048
    1049         101 <= x < 1000 reclassified to 11 <= y <= 100
    1050
    1051         1001 <= x < 10000 reclassified to 101 <= y <= 1000
    1052 }}}
    1053
    1054       To change the evaluation of rangefrom, use square brackets and parentheses.
    1055
    1056 {{{
    1057 1. [a-b] = a <= x <= b
    1058
    1059 2. (a-b] = a < x <= b
    1060
    1061 3. [a-b) = a <= x < b
    1062
    1063 4. (a-b) = a < x < b
    1064 }}}
    1065
    1066       !#3 above is the default evaluation of x in the range a-b. The use of square brackets and parentheses are optional, so the examples below would be permitted. Missing notations substitute the appropriate notation from #3 above.
    1067
    1068 {{{
    1069 [a-b = a <= x < b
    1070
    1071 (a-b = a < x < b
    1072
    1073 a-b] = a <= x <= b
    1074
    1075 a-b) = a <= x < b
    1076 }}}
    1077
    1078       Two special cases are also available for use when x may be outside the range of a-b.  This situation is possible if your range is based upon an approximation, such as from ST_ApproxMinMax.
    1079
    1080 {{{
    1081 ]a-b or )a-b = x < a, rule matches
    1082
    1083 a-b[ or a-b( = x >= b, rule matches
    1084 }}}
    1085
    1086     pixeltype: the reclassified band's pixel type, e.g. 8BUI, 16BUI, 32BF
    1087
    1088     nodata: the nodata value of the reclassified band.  If the source band has a nodata value, all source pixel value equal to the source nodata value will be converted to the reclassified band's nodata value.  If set to NULL, the reclassified band will NOT have a nodata value specified.
    1089
    1090 {{{
    1091 ST_Reclass(rast, ROW(1, '0-100:0-10, 101-1000:11-100, 1001-10000:101-1000', '16BUI', NULL));
    1092
    1093 ST_Reclass(rast, ROW(1, '0-100:0-10, 101-1000:11-100, 1001-10000:101-1000', '16BUI', 1001));
    1094
    1095 ST_Reclass(rast,
    1096   ROW(1, '0-100:0-10, 101-1000:11-100, 1001-10000:101-1000', '16BUI', 1001),
    1097   ROW(2, '0-100:0-10, 101-1000:11-100, 1001-10000:101-1000', '16BUI', 1001),
    1098   ROW(3, '0-100:0-10, 101-1000:11-100, 1001-10000:101-1000', '16BUI', 1001),
    1099   ROW(5, '0-100:0-10, 101-1000:11-100, 1001-10000:101-1000', '16BUI', 1001)
    1100 )
    1101 }}}
    1102
    1103   An expanded example
    1104
    1105 {{{
    1106 SELECT ST_Reclass(
    1107   ST_Band(rast, ARRAY[1,1,1]),
    1108   ROW(1, LEAST(covmin, 0)::text || '-0:0,0-' || GREATEST(covmax, 0)::text || ':0-255', '8BUI'),
    1109   ROW(2, LEAST(covmin, 0)::text || '-0:200,0-' || GREATEST(covmax, 0)::text' || ':0-255','8BUI'),
    1110   ROW(3, LEAST(covmin, 0)::text || '-0:255,0-' || (GREATEST(covmax, 0)/2)::text' || ':0,' || (GREATEST(covmax, 0)/2)::text' || ':' || GREATEST(covmax, 0)::text || ':0-255', '8BUI')
    1111 )
    1112 FROM mycoverage
    1113 }}}
    1114
    1115 2. ST_Reclass(rast raster, nband int, reclassexpr text, pixeltype text, nodata double) -> raster
    1116
    1117   provides a method to process just one band of a raster
    1118
    1119 {{{
    1120 ST_Reclass(rast, 1, '0-100:0-10', '8BUI', 11)
    1121 }}}
    1122
    1123 3. ST_Reclass(rast raster, nband int, reclassexpr text, pixeltype text) -> raster
    1124
    1125   nodata parameter removed so reclassified band will NOT have a nodata value set
    1126
    1127 {{{
    1128 ST_Reclass(rast, 1, '0-100:0-10', '8BUI')
    1129 }}}
    1130
    1131 4. ST_Reclass(rast raster, reclassexpr text, pixeltype text) -> raster
    1132
    1133   nband parameter removed so reclassified band is assumed to be 1.  nodata parameter removed so reclassified band has NO nodata value.
    1134
    1135 {{{
    1136 ST_Reclass(rast, '0-100:0-10', '8BUI')
    1137 }}}
    1138
    1139 5. ST_Reclass(rast raster, reclassexpr text, pixeltype text, nodata double) -> raster
    1140
    1141   nband parameter removed so reclassified band is assumed to be 1
    1142
    1143 {{{
    1144 ST_Reclass(rast, '0-100:0-10', '8BUI', 11)
    1145 }}}
    1146
    1147 ----
    1148
    1149 == '''Objective FV.02 - Being able to intersect vector and raster to produce raster.''' ==
    1150
    1151 '''ST_Intersects(raster, raster) -> boolean'''[[BR]]
    1152
    1153 This function uses the same tests as the two geometry version of ST_Intersects where tests see if two rasters overlap, touches or has one within the other.  If any condition is true, the two rasters intersect.
    1154
    1155 For this description, the rasters are called A and B and the bands tested are assumed to be 1.
    1156
    1157 Preliminary criteria before the real work begins:
    1158
    1159 1. make sure that rasters A and B have the same SRID.  if not, return false.
    1160
    1161 2. make sure that the convex hulls of A and B intersect.  if not, return false.
    1162
    1163 Special case where a raster may be fully contained within another raster's cell (the entirety of A within a cell of B):
    1164
    1165 1. using every third pixel by row and column, test each selected cell's geopoint (excluding no data by default unless exclude_nodata_value = FALSE) of A to that of B for overlap.
    1166
    1167 2. if a cell of A does overlap a cell of B, return true.
    1168
    1169 3. if no cell of A overlaps with B, continue to additional testing
    1170
    1171 Actual testing involves the use of calculating the intersection of grid lines between A and B
    1172
    1173 1. Using every third A's column and B's row, calculate the intersection point of each pair of grid lines.
    1174
    1175 2. If intersection point doesn't exist or is outside the bounds of the end points comprising each grid line used, go back to step 1.
    1176
    1177 3. If intersection point exists and within bounds, sample the area around the intersection point by offset the intersection point by a small amount (1/10th of the smaller scale of A and B) for 360 degrees starting from 00:00.  sampled points are 0, 45, 90, 135, 180, 225, 270 and 315 degrees.
    1178
    1179 4. At each sample point, test to see if the geopoint has non-nodata (unless including nodata) values in both A and B.  if so, return true.
    1180
    1181 5. At the same time as step 4, build an adjacency matrix for the intersection to see if two non-overlapping pixels from A and B touch.
    1182
    1183 6. Once all sample points have been tested and no overlapping pixels found, the adjacency matrix is checked to see if any sampled pixel of A touched a sampled pixel of B.  If two pixels touched, return true.
    1184
    1185 7. If after all the searching and testing, nothing intersects or touches, return false.
    1186
    1187 A set of ST_Intersects functions for rasters:
    1188
    1189 1. ST_Intersects(raster rastA, raster rastB, integer bandA DEFAULT NULL, integer bandB DEFAULT NULL) -> boolean
    1190
    1191 If bandA and bandB are NULL, only the convex hulls of the rasters will be tested.  If bandA or bandB are provided, both parameters must be provided and not NULL.
    1192
    1193 2. ST_Intersects(raster rastA, integer bandA, raster rastB, integer bandB) -> boolean
    1194
    1195 A refactored set of St_Intersects() for testing a raster and a geometry.  The first set converts the geometry to a raster to see if the two rasters intersect.
    1196
    1197 3. ST_Intersects(rast raster, geom geometry, nband integer DEFAULT NULL) -> boolean
    1198
    1199 4. ST_Intersects(rast raster, nband integer, geom geometry) -> boolean
    1200
    1201 The second set of ST_Intersects() for testing a raster and a geometry converts the raster to a geometry and sees if the geometries intersect.
    1202
    1203 5. ST_Intersects(geom geometry, rast raster, nband DEFAULT NULL) -> boolean
    1204
    1205 The order in which the geometry and raster are passed into ST_Intersects determines which method of testing is used.  If geometry is first, the raster is converted to a set of geometries.  If raster is first, the geometry is converted to a raster.
    1206
    1207 These set of functions are required because there are cases where ST_Intersects(raster, geometry) != ST_Intersects(geometry, raster).
    1208
    1209 [[Image(st_intersects_triangle.png)]]
    1210
    1211 In the image above, the black border denotes the boundary of a triangle polygon and the red within is the raster version of the geometry.  The polygon touches the raster in blue while the red raster does not.
    1212
    1213 '''ST_AsRaster(geometry, pixeltype, val, nodataval, ulx, uly, width, height, pixelsizex, pixelsizey, skewx, skewy) -> raster'''
    1214
    1215 ST_AsRaster provides the ability convert a geometry into a raster. To create the raster, the X and Y scale or the width and height of the raster must be provided.
    1216
    1217 The output raster will be in the same coordinate system as the source geometry. The only exception is for ST_AsRaster variations with a raster input parameter.
    1218
    1219 1. ST_AsRaster([[BR]]
    1220         geom geometry,[[BR]]
    1221         scalex double precision, scaley double precision,[[BR]]
    1222         gridx double precision DEFAULT NULL, gridy double precision DEFAULT NULL,[[BR]]
    1223         pixeltype text[] DEFAULT ARRAY!['8BUI']::text[],[[BR]]
    1224         value double precision[] DEFAULT ARRAY![1]::double precision[],[[BR]]
    1225         nodataval double precision[] DEFAULT ARRAY![0]::double precision[],[[BR]]
    1226         skewx double precision DEFAULT 0, skewy double precision DEFAULT 0,[[BR]]
    1227         touched boolean DEFAULT FALSE
    1228 ) -> raster
    1229
    1230     geom: the geometry to convert to a raster. Can be any valid PostGIS geometry.
    1231
    1232     scalex: the scale/pixel size in the X axis of the output raster. If scalex and scaley are zero (0), the output raster's scale will be autocomputed.
    1233
    1234     scaley: the scale/pixel size in the Y axis of the output raster. If scalex and scaley are zero (0), the output raster's scale will be autocomputed.
    1235
    1236     pixeltype: array of pixel types for each band. Each array element is a band.
    1237
    1238     value: array of values to burn into the raster for the geometry. Each array element is a band.
    1239
    1240     nodataval: array of nodata values to burn into the raster. Each array element is a band. If an array element is null, that band will not have a nodata value.
    1241
    1242     upperleftx: the X value of the upper-left corner of the output raster
    1243
    1244     upperlefty: the Y value of the upper-left corner of the output raster
    1245
    1246     gridx: the X coordinate of a point on the grid to which the raster will be aligned. Value is in the raster's world coordinates.
    1247
    1248     gridy: the Y coordinate of a point on the grid to which the raster will be aligned. Value is in the raster's world coordinates.
    1249
    1250     skewx: the skew along the X axis of the raster. by default, the skew along the X axis is zero.
    1251
    1252     skewy: the skew along the Y axis of the raster. by default, the skew along the X axis is zero.
    1253
    1254     touched: from the GDAL man page for gdal_rasterize: "Enables the ALL_TOUCHED rasterization option so that all pixels touched by lines or polygons will be updated not just those one the line render path, or whose center point is within the polygon. Defaults to disabled for normal rendering rules."
    1255
    1256 ''If the number of elements for pixeltype, value and nodataval do not match, the minimum number of elements will be used.''
    1257
    1258 2. ST_AsRaster(
    1259         geom geometry,[[BR]]
    1260         scalex double precision, scaley double precision,[[BR]]
    1261         pixeltype text[],[[BR]]
    1262         value double precision[] DEFAULT ARRAY![1]::double precision[],[[BR]]
    1263         nodataval double precision[] DEFAULT ARRAY![0]::double precision[],[[BR]]
    1264         upperleftx double precision DEFAULT NULL, upperlefty double precision DEFAULT NULL,[[BR]]
    1265         skewx double precision DEFAULT 0, skewy double precision DEFAULT 0,[[BR]]
    1266         touched boolean DEFAULT FALSE
    1267 ) -> raster
    1268
    1269 3. ST_AsRaster(
    1270         geom geometry,[[BR]]
    1271         width integer, height integer,[[BR]]
    1272         gridx double precision DEFAULT NULL, gridy double precision DEFAULT NULL,[[BR]]
    1273         pixeltype text[] DEFAULT ARRAY!['8BUI']::text[],[[BR]]
    1274         value double precision[] DEFAULT ARRAY![1]::double precision[],[[BR]]
    1275         nodataval double precision[] DEFAULT ARRAY![0]::double precision[],[[BR]]
    1276         skewx double precision DEFAULT 0, skewy double precision DEFAULT 0,[[BR]]
    1277         touched boolean DEFAULT FALSE
    1278 ) -> raster
    1279
    1280 4. ST_AsRaster(
    1281         geom geometry,[[BR]]
    1282         width integer, height integer,[[BR]]
    1283         pixeltype text[],[[BR]]
    1284         value double precision[] DEFAULT ARRAY![1]::double precision[],[[BR]]
    1285         nodataval double precision[] DEFAULT ARRAY![0]::double precision[],[[BR]]
    1286         upperleftx double precision DEFAULT NULL, upperlefty double precision DEFAULT NULL,[[BR]]
    1287         skewx double precision DEFAULT 0, skewy double precision DEFAULT 0,[[BR]]
    1288         touched boolean DEFAULT FALSE
    1289 ) -> raster
    1290
    1291 5. ST_AsRaster(
    1292         geom geometry,[[BR]]
    1293         scalex double precision, scaley double precision,[[BR]]
    1294         gridx double precision, gridy double precision,[[BR]]
    1295         pixeltype text,[[BR]]
    1296         value double precision DEFAULT 1,[[BR]]
    1297         nodataval double precision DEFAULT 0,[[BR]]
    1298         skewx double precision DEFAULT 0, skewy double precision DEFAULT 0,[[BR]]
    1299         touched boolean DEFAULT FALSE
    1300 ) -> raster
    1301
    1302 6. ST_AsRaster(
    1303         geom geometry,[[BR]]
    1304         scalex double precision, scaley double precision,[[BR]]
    1305         pixeltype text,[[BR]]
    1306         value double precision DEFAULT 1,[[BR]]
    1307         nodataval double precision DEFAULT 0,[[BR]]
    1308         upperleftx double precision DEFAULT NULL, upperlefty double precision DEFAULT NULL,[[BR]]
    1309         skewx double precision DEFAULT 0, skewy double precision DEFAULT 0,[[BR]]
    1310         touched boolean DEFAULT FALSE
    1311 ) -> raster
    1312
    1313 7. ST_AsRaster(
    1314         geom geometry,[[BR]]
    1315         width integer, height integer,[[BR]]
    1316         gridx double precision, gridy double precision,[[BR]]
    1317         pixeltype text,[[BR]]
    1318         value double precision DEFAULT 1,[[BR]]
    1319         nodataval double precision DEFAULT 0,[[BR]]
    1320         skewx double precision DEFAULT 0, skewy double precision DEFAULT 0,[[BR]]
    1321         touched boolean DEFAULT FALSE
    1322 ) -> raster
    1323
    1324 8. ST_AsRaster(
    1325         geom geometry,[[BR]]
    1326         width integer, height integer,[[BR]]
    1327         pixeltype text,[[BR]]
    1328         value double precision DEFAULT 1,[[BR]]
    1329         nodataval double precision DEFAULT 0,[[BR]]
    1330         upperleftx double precision DEFAULT NULL, upperlefty double precision DEFAULT NULL,[[BR]]
    1331         skewx double precision DEFAULT 0, skewy double precision DEFAULT 0,[[BR]]
    1332         touched boolean DEFAULT FALSE
    1333 ) -> raster
    1334
    1335 9. ST_AsRaster(
    1336         geom geometry,[[BR]]
    1337         ref raster,[[BR]]
    1338         pixeltype text[] DEFAULT ARRAY!['8BUI']::text[],[[BR]]
    1339         value double precision[] DEFAULT ARRAY![1]::double precision[],[[BR]]
    1340         nodataval double precision[] DEFAULT ARRAY![0]::double precision[],[[BR]]
    1341         touched boolean DEFAULT FALSE
    1342 ) -> raster
    1343
    1344 10. ST_AsRaster(
    1345         geom geometry,[[BR]]
    1346         ref raster,[[BR]]
    1347         pixeltype text,[[BR]]
    1348         value double precision DEFAULT 1,[[BR]]
    1349         nodataval double precision DEFAULT 0,[[BR]]
    1350         touched boolean DEFAULT FALSE
    1351 ) -> raster
    1352
    1353
    1354 ~~ * Rasterize the provided geometry to a raster created using the specified parameters.~~
    1355 ~~ * Implemented as a wrapper around GDAL like ST_DumpAsPolygons() does.~~
    1356 ~~ * ST_AsRaster is necessary to implement ST_Intersection(geometry, raster, band) -> raster and an eventual ST_BurnToRaster(raster, geometry)  -> raster where the provided geometry is first rasterized to the same alignment as the other raster involved.~~
    1357 ~~ * Each geometry of a table is rasterized as one raster. To produce a global unique raster including all the geometries of a table (loosing overlaps by the way), a user must use the planned ST_Union aggregate function to merge all the rasters together optionally in a GROUP BY query grouping some rows together.~~
    1358
    1359 ~~ * The raster is burned with the specified value converted (or truncated) with a warning to the provided pixeltype. The hasnodatavalue flag of the resulting raster must be set and the nodata value is set to the provided value (expect in variant 10 and 12).~~
    1360
    1361 ~~ * Alignment, width, height and pixelsize are optionally computed:~~[[BR]]
    1362 ~~ -From the vector extent of the geometry,~~[[BR]]
    1363 ~~ -Imposed with parameters,~~[[BR]]
    1364 ~~ -From another provided raster.~~
    1365
    1366 ~~ * Alignment can be optionally specified as:~~[[BR]]
    1367 ~~ -A x and a y world coordinates specifying an arbitrary pixel corner. Although it can be, it IS NOT necessarily the coordinates of the upper left corner pixel.~~[[BR]]
    1368 ~~ -A ulx and a uly world coordinates specifying the upperleft corner of the raster. This IS NECESSARILY the upper left corner of the upperleft pixel. In this case a width and a height must also be provided.~~[[BR]]
    1369 ~~ -An existing raster. The x and y are derived from the provided raster and the resulting raster has the same ulx, uly, width and height as the provided raster. A 'CROP' option  allows cropping the resulting raster to the minimal extent of the geometry keeping the x and y alignment of the provided raster.~~[[BR]]
    1370 ~~ -Default alignment is the upper left corner of the envelope of the geometry. This might result in table where all rasters are misaligned, but this is useful when reconverting to raster a set of polygons vectorized from rasters (with ST_DumpAsPolygon() or ST_Intersection()).~~
    1371
    1372 ~~ * Pixelsize can be optionally specified as:~~[[BR]]
    1373 ~~ -One or two floating point numbers. If only one is provided, both x and y pixelsizes are assigned the same value.~~[[BR]]
    1374 ~~ -A width and a height (integers). In this case the x pixelsize is the x extent divided by the provided width and the y pixelsize is the y extent divided by the provided height. This is useful only when the alignment is specified as the upper left corner of the raster.~~[[BR]]
    1375 ~~ -“FIRST_SEGMENT_LENGTH”. The pixelsize is set to the length of the first line segment encountered in the geometry. This is useful when reconverting to raster polygons vectorized from rasters (with ST_DumpAsPolygon() or ST_Intersection()). In this case, all segments are of the same length which is the original raster pixel size. This is useful only when alignment is not specified. If the geometry is a point, return an error.~~[[BR]]
    1376 ~~ -Default is the smallest of the width or height of the extent of the source geometry divided by 250. If the smallest of the width or height of the extent of the source geometry is zero then a warning is reported an no NULL is returned.~~
    1377
    1378 ~~ * It would be interesting to have a 'ADD_WEIGHTING_INFO' option to create a second band with the length of the line or the area of polygon (or the distance to the center of points) intersecting each pixel. This band could then be used in a ST_Union(rast, 'MAX_LENGTH') or a ST_Union(rast, 'MAX_AREA') function burning the value of the line having the longest intersection with the pixel or the value of the polygon having the biggest intersecting area. For this to be useful ST_Union should work with a ST_MapAlgebra(rast1, rast2) able to refer to pixel value in any band (e.g. rast1.2 referring to the pixel value in the second band). The ST_Union(rast, 'MAX_LENGTH') aggregate could then be implemented with the following state expression: 'CASE WHEN rast1.2 > rast2.2 THEN rast1.1 ELSE rast2.1 ENDIF'. Otherwise we would have to imbricate four Mapalgebra functions. ST_Union(rast, 'MAX_COMBINED_LENGTH') could use a ST_MapAlgebra(rast1, rast2) able to take a custom user function. The state function would accumulate, in a temporary table, the total intersecting length or area for a same value over every overlapping pixels and the final function would determine which of the values from the temporary table would be the right one to burn in the final raster pixel. Variations of ST_Union which could then be easily implemented could be: ST_Union(rast, 'WEIGHTED') to weight the value with the length, the area or the count, ST_Union(rast, 'MOST_FREQUENT') to burn the value for the most frequent points values.~~
    1379
    1380 ~~ '''Variants'''~~
    1381
    1382 ~~ * There are many variants because we are creating a raster from scratch. We want to make it easy (serie one and four) to convert geometries to raster and at the same time we want to have flexibility to control the resulting raster properties (series two and three).~~
    1383 ~~ * Variant 3, 5 and 13 are the most useful.~~
    1384 ~~ * Variant 6, 7, 8, 9, 10, 11, 12 are also useful.~~
    1385 ~~ * Variant 1, 2, 4 are useful for quick conversion.~~
    1386 ~~ * All variant should be pl/pgsql variant of variant 9 which is the only one needing to be implemented as a rt_pg functions.~~
    1387
    1388 ~~ * The '''first series of variant''' get their alignment from the extent of the geometry.~~
    1389
    1390 ~~ 1) ST_AsRaster(geometry, pixeltype, val, nodataval) – 0, alignment is computed from the geometry envelope, pixel size is computed by dividing the extent by 250. This variant is optional and discouraged as it results in many unaligned rasters for a table with many geometries.~~
    1391
    1392 ~~ 2) ST_AsRaster(geometry, pixeltype, val, nodataval, pixelsize float8) – 1, x and y are computed from upper left corner it the geometry envelope. This variant is optional and discouraged as it results in many unaligned rasters for a table with many geometries.~~
    1393
    1394 ~~ 3) ST_AsRaster(geometry, pixeltype, val, nodataval, ‘FIRST_SEGMENT_LENGTH’) – 0, ulx and uly are get from the envelope, pixel size from the length of the first segment. This variant is useful only to rasterize geometries produced by ST_DumpAsPolygon or ST_Intersection. Otherwise it discouraged as it would result in many unaligned rasters for a table with many geometries.~~
    1395
    1396 ~~ * The '''second series of variant''' have their alignment specified by an arbitrary pixel corner of the desired raster.~~
    1397
    1398 ~~ 4) ST_AsRaster(geometry, pixeltype, val, nodataval, x float8, y float8) – 2, pixel size is computed by dividing the extent by 250. This variant is optional and discouraged as it results in many unaligned rasters for a table with many geometries.~~
    1399
    1400 ~~ 5) ST_AsRaster(geometry, pixeltype, val, nodataval, x float8, y float8, pixelsize) – 3, this is one of the preferred variant when the geometry is not the result of ST_DumpAsPolygon or ST_Intersection.~~
    1401
    1402 ~~ 6) ST_AsRaster(geometry, pixeltype, val, nodataval, x float8, y float8, pixelsizex, pixelsizey) - 4, this is one of the preferred variant when the geometry is not the result of ST_DumpAsPolygon or ST_Intersection.~~
    1403
    1404 ~~ 7) ST_AsRaster(geometry, pixeltype, val, nodataval, x float8, y float8, pixelsizex, pixelsizey, skewx, skewy) – 6, this is one of the preferred variant when the geometry is not the result of ST_DumpAsPolygon or ST_Intersection.~~
    1405
    1406 ~~ * The '''third series of variant''' have their alignment specified by the upper left corner of the upper left pixel of the desired raster.~~
    1407
    1408 ~~ 8) ST_AsRaster(geometry, pixeltype, val, nodataval, ulx, uly, width, height, pixelsize) – 2,2,1, this is useful to rasterize geometries to a common raster extent. Some geometries might be outside the extent of the desired raster extent resulting in a nodata value raster.~~
    1409
    1410 ~~ 9) ST_AsRaster(geometry, pixeltype, val, nodataval, ulx, uly, width, height, pixelsizex, pixelsizey, skewx, skewy) – 2,2,4, this is useful to rasterize geometries to a common raster extent. Some geometries might be outside the extent of the desired raster extent resulting in a nodata value raster. This is the only variant which must be implemented in the tr_pg layer. All other variant must be implemented in pl/PgSQL and derive the argument to call this variant.~~
    1411
    1412 ~~ * The '''fourth series of variant''' get their alignment (and size for variant 10 and 12) from an existing raster. Variant 10 and 11 keep the same extent as the provided raster and variant 12 and 13 have their extent cropped to the extent of the geometry.~~
    1413
    1414 ~~ 10) ST_AsRaster(geometry, val, raster) – 0, the target raster metadata (including pixeltype, hasnodatavalue and nodatavalue) are copied from the provided raster~~
    1415
    1416 ~~ 11) ST_AsRaster(geometry, pixeltype, val, nodataval, raster) – 0, the target raster metadata are copied from the provided raster.~~
    1417
    1418 ~~ 12) ST_AsRaster(geometry, val, raster, “CROP”) – 0, the target raster alignment and pixel size are copied from the provided raster (including pixeltype, hasnodatavalue and nodatavalue) but the extent is reduced to the geometry extent. We should not create a (too big) raster and crop at the end. The final extent should be computed BEFORE burning.~~
    1419
    1420 ~~ 13) ST_AsRaster(geometry, pixeltype, val, nodataval, raster, “CROP”) – 0, the target raster alignment and pixel size are copied from the provided raster but the extent is reduced to the geometry extent. We should not create a (too big) raster and crop at the end. The final extent should be computed BEFORE burning.~~
    1421
    1422 ~~ '''Questions'''~~
    1423
    1424 ~~ -How does GDAL/ArcGIS choose the pixel size and the ul of the final raster?~~
    1425
    1426 ~~ -How does GDAL/ArcGIS allow selecting the value column -What if it is a text column?~~
    1427
    1428 ~~ -How does GDAL/ArcGIS allow giving a thickness to points and lines -No thickness is given. All pixels intersecting the geometry are burned following a selected method.~~
    1429
    1430 ~~ -How does GDAL/ArcGIS select which value to assign to the pixel when two or more features intersect with the pixel?~~
    1431
    1432 '''ST_Intersection(raster, band, geometry) -> raster'''
    1433
    1434 ST_Intersection is plpgsql function wrapping the two-raster ST_MapAlgebra functions.  Performance should be about the same as calling ST_MapAlgebra directly except for the case where returnband is BOTH as that results in two separate ST_MapAlgebra calls.
    1435
    1436 A set of ST_Intersection functions for raster, raster.
    1437
    1438 {{{
    1439 1. ST_Intersection(
    1440     rast1 raster, nband1 int,
    1441     rast2 raster, nband2 int,
    1442     returnband text DEFAULT 'BOTH',
    1443     otheruserfunc regprocedure DEFAULT NULL
    1444 );
    1445 }}}
    1446
    1447   returnband: can be FIRST, SECOND, BOTH, OTHER
    1448
    1449     * FIRST returns the band of rast1 in the intersecting extent. returning raster will have one band.
    1450     * SECOND returns the band of rast2 in the intersecting extent. returning raster will have one band.
    1451     * BOTH returns the bands of rast1 and rast2 in the intersection extent. returning raster will have two bands.
    1452     * OTHER returns the computed band based upon rast1 and rast2 in the intersecting extent. returning raster will have one band. If OTHER, must provide a regprocedure to otherfunc
    1453
    1454   otheruserfunc: function to call when returnband = OTHER. Function format must be identical to tworastuserfunc of 2-raster ST_MapAlgebraFct.
    1455
    1456 {{{
    1457 2. ST_Intersection(
    1458     rast1 raster, nband1 int,
    1459     rast2 raster, nband2 int,
    1460     otheruserfunc regprocedure
    1461 );
    1462 }}}
    1463
    1464 {{{
    1465 3. ST_Intersection(
    1466     rast1 raster,
    1467     rast2 raster,
    1468     returnband text DEFAULT 'BOTH',
    1469     otheruserfunc regprocedure DEFAULT NULL
    1470 );
    1471 }}}
    1472
    1473 {{{
    1474 4. ST_Intersection(
    1475     rast1 raster,
    1476     rast2 raster,
    1477     otheruserfunc regprocedure
    1478 );
    1479 }}}
    1480
    1481 A set of ST_Intersection functions for raster, geometry (converted to raster).
    1482
    1483 {{{
    1484 1. ST_Intersection(
    1485     rast raster, nband int,
    1486     geom geometry,
    1487     extent text DEFAULT 'INTERSECTION',
    1488     otheruserfunc regprocedure DEFAULT NULL
    1489 )
    1490 }}}
    1491
    1492   extent: can be INTERSECTION, FIRST, SECOND, UNION though FIRST and INTERSECTION will probably be the most commonly used
    1493
    1494 {{{
    1495 2. ST_Intersection(
    1496     rast raster, nband int,
    1497     geom geometry,
    1498     otheruserfunc regprocedure
    1499 );
    1500 }}}
    1501
    1502 {{{
    1503 3. ST_Intersection(
    1504     rast raster,
    1505     geom geometry,
    1506     extent text DEFAULT 'INTERSECTON',
    1507     otheruserfunc regprocedure DEFAULT NULL
    1508 );
    1509 }}}
    1510
    1511 {{{
    1512 4. ST_Intersection(
    1513     rast raster,
    1514     geom geometry,
    1515     otheruserfunc regprocedure
    1516 );
    1517 }}}
    1518
    1519 ~~ The first series of variant return a raster having the same extent as the provided raster.
    1520
    1521 ~~  Variant 1: ST_Intersection(geometry, val, raster, band, pixeltype, nodatavalue) -> raster
    1522
    1523 ~~  Variant 2: ST_Intersection(raster, band, geometry, val, pixeltype, nodatavalue) -> raster
    1524
    1525 ~~  Variant 3: ST_Intersection(geometry, val, raster, pixeltype, nodatavalue) -> raster
    1526
    1527 ~~  Variant 4: ST_Intersection(raster, geometry, val, pixeltype, nodatavalue) -> raster
    1528
    1529 ~~ The second series of variant return a raster having the minimal extent.
    1530
    1531 ~~  Variant 5: ST_Intersection(geometry, val, raster, band, pixeltype, nodatavalue, 'TRIM') -> raster
    1532
    1533 ~~  Variant 6: ST_Intersection(raster, band, geometry, val, pixeltype, nodatavalue, 'TRIM') -> raster
    1534
    1535 ~~  Variant 7: ST_Intersection(geometry, val, raster, pixeltype, nodatavalue, 'TRIM') -> raster
    1536
    1537 ~~  Variant 8: ST_Intersection(raster, geometry, val, pixeltype, nodatavalue, 'TRIM') -> raster
    1538
    1539 ~~ Returns a two bands raster the first band containing only the pixels from the provided raster intersecting with the geometry and the second band containing the same area filled with the provided value.
    1540
    1541 ~~ The second band gets its pixeltype and nodatavalue from the parameters.
    1542
    1543 ~~ Non intersecting pixels are filled with nodata values.
    1544
    1545 ~~ Variant 1 return a raster having the same extent as the provided raster.
    1546
    1547 ~~ Variant 3, 4, 7 and 8 defaults the band number to 1.
    1548
    1549 ~~ Variant 5 to 8 "trim" or "crop" the raster to the withvalue extent (removing extra nodata value pixels surrounding the extent of the resulting withvalue extent).
    1550
    1551
    1552 ~~ '''Open questions'''
    1553
    1554 ~~ PR: Shoud we return one raster per raster/geometry couple or split the raster into as many small rasters as there are areas sharing a same value? The second behavior seems more coherent with the present behavior of ST_Intersection(raster, geometry) -> geometry even if this would produce tons of small two bands rasters.
    1555
    1556 ~~ '''Implementation details'''
    1557
    1558 ~~ Rasterize the geometry as a new raster (ST_AsRaster(geometry, pixeltype, val, nodataval, raster)) and then copy only pixels for which both raster bands have a value.
    1559 ~~ Should be implemented as a wrapper around ST_MapAlgebra after rasterizing the geometry to a raster having the same alignment as the raster.
    1560
    1561 ----
    1562
    1563 == '''Objective FV.03 - ST_MapAlgebra (1 and 2 raster variants)''' ==
    1564
    1565 '''Two raster ST_MapAlgebra'''
    1566
    1567 These set of functions take two input rasters and create a 1-band output raster with the extent defined by extenttype.
    1568
    1569
    1570 1. ST_MapAlgebraExpr(
    1571         rast1 raster, band1 integer,[[BR]]
    1572         rast2 raster, band2 integer,[[BR]]
    1573         expression text,[[BR]]
    1574         pixeltype text DEFAULT NULL, extenttype text DEFAULT 'INTERSECTION',[[BR]]
    1575         nodata1expr text DEFAULT NULL, nodata2expr text DEFAULT NULL,[[BR]]
    1576         nodatanodataval double precision DEFAULT NULL
    1577 ) -> raster
    1578
    1579     rast1: the FIRST raster upon which a map algebra operation is to be done
    1580
    1581     band1: the band index (1-based) of the FIRST raster upon whose pixels a map algebra operation is to be done
    1582
    1583     rast2: the SECOND raster upon which a map algebra operation is to be done
    1584
    1585     band2: the band index (1-based) of the SECOND raster upon whose pixels a map algebra operation is to be done
    1586
    1587     expression: valid SQL expression resulting in a double precision value or NULL.  called when band 1 pixel AND band 2 pixel are NOT NODATA
    1588
    1589     pixeltype: the datatype of the output raster's one band
    1590
    1591     extenttype: one of the following (INTERSECTION, UNION, FIRST, SECOND)
    1592
    1593     nodata1expr: valid SQL expression resulting in a double precision value or NULL.  called when band 1 pixel IS NODATA and band 2 pixel IS NOT NODATA
    1594
    1595     nodata2expr: valid SQL expression resulting in a double precision value or NULL.  called when band 1 pixel IS NOT NODATA and band 2 pixel IS NODATA
    1596
    1597     nodatanodataval: double precision value used when band1 pixel and band 2 pixel are NODATA
    1598
    1599 {{{
    1600 ST_MapAlgebraExpr(r1.rast, 1, r2.rast, 2, 'rast1', '32BF', 'INTERSECTION')
    1601
    1602 ST_MapAlgebraExpr(r1.rast, 1, r2.rast, 2, '((rast1 + rast2)/2.)::numeric', '32BF', 'UNION', 'rast2', 'rast1', NULL)
    1603
    1604 ST_MapAlgebraExpr(r1.rast, 1, r2.rast, 2, 'CASE WHEN rast2 IS NOT NULL THEN NULL ELSE rast1 END', '32BF', 'FIRST', NULL, 'rast1', NULL)
    1605
    1606 ST_MapAlgebraExpr(r1.rast, 1, r2.rast, 2, 'CASE WHEN rast1 IS NOT NULL THEN NULL ELSE rast2 END', '32BF', 'SECOND', 'rast2', NULL, NULL)
    1607 }}}
    1608
    1609 2. ST_MapAlgebraExpr(
    1610         rast1 raster,[[BR]]
    1611         rast2 raster,[[BR]]
    1612         expression text,[[BR]]
    1613         pixeltype text DEFAULT NULL, extenttype text DEFAULT 'INTERSECTION',[[BR]]
    1614         nodata1expr text DEFAULT NULL, nodata2expr text DEFAULT NULL,[[BR]]
    1615         nodatanodataval double precision DEFAULT NULL
    1616 ) -> raster
    1617
    1618 {{{
    1619 ST_MapAlgebraExpr(r1.rast, r2.rast, 'rast1', '32BF', 'INTERSECTION')
    1620
    1621 ST_MapAlgebraExpr(r1.rast, r2.rast, '((rast1 + rast2)/2.)::numeric', '32BF', 'UNION', 'rast2', 'rast1', NULL)
    1622
    1623 ST_MapAlgebraExpr(r1.rast, r2.rast, 'CASE WHEN rast2 IS NOT NULL THEN NULL ELSE rast1 END', '32BF', 'FIRST', NULL, 'rast1', NULL)
    1624
    1625 ST_MapAlgebraExpr(r1.rast, r2.rast, 'CASE WHEN rast1 IS NOT NULL THEN NULL ELSE rast2 END', '32BF', 'SECOND', 'rast2', NULL, NULL)
    1626 }}}
    1627
    1628 This set of 2-raster ST_MapAlgebra functions require a user-provided function instead of expressions.  The user-provided function must receive three parameters (two double precision and one VARIADIC text array) and returns one double precision value.  A template for this user-provided function would be:
    1629
    1630 {{{
    1631 CREATE OR REPLACE FUNCTION userfunction(rast1 double precision, rast2 double precision, VARIADIC arg text[])
    1632         RETURNS double precision
    1633         AS $$
    1634         DECLARE
    1635         BEGIN
    1636                 -- your code here
    1637         END;
    1638         $$
    1639         LANGUAGE 'plpgsql';
    1640 }}}
    1641
    1642 The function should be able to support a NULL input parameter.  The function may also be STRICT.
    1643
    1644 1. ST_MapAlgebraFct(
    1645         rast1 raster, band1 integer,[[BR]]
    1646         rast2 raster, band2 integer,[[BR]]
    1647         userfunction regprocedure,[[BR]]
    1648         pixeltype text DEFAULT NULL, extenttype text DEFAULT 'INTERSECTION',[[BR]]
    1649         VARIADIC userargs text[] DEFAULT NULL
    1650 )
    1651
    1652 {{{
    1653 ST_MapAlgebraFct(r1.rast, 1, r2.rast, 1, 'raster_mapalgebra_intersection(double precision, double precision, text[])'::regprocedure, '32BF', 'INTERSECTION')
    1654 }}}
    1655
    1656 2. ST_MapAlgebraFct(
    1657         rast1 raster,[[BR]]
    1658         rast2 raster,[[BR]]
    1659         userfunction regprocedure,[[BR]]
    1660         pixeltype text DEFAULT NULL, extenttype text DEFAULT 'INTERSECTION',[[BR]]
    1661         VARIADIC userargs text[] DEFAULT NULL
    1662 )
    1663
    1664 {{{
    1665 ST_MapAlgebraFct(r1.rast, r2.rast, 'raster_mapalgebra_intersection(double precision, double precision, text[])'::regprocedure, '32BF', 'INTERSECTION')
    1666 }}}
    1667
    1668 ----
    1669 == '''Objective FV.14 - Being able to intersect two rasters to get a raster.''' ==
    1670
    1671 '''ST_Intersection(raster, integer, raster, integer) -> raster''' - Returns a two bands raster with values only in the intersecting areas of both rasters. Integer parameters are the band number of the raster.
    1672
    1673 Please look at ST_Intersection(raster, geometry) in FV.01 for complete specs.
    1674
    1675 ~~ '''Variants'''
    1676
    1677 ~~  1) ST_Intersection(raster, integer, raster, integer) -> raster -- the integer parameters are the band number of the rasters[[BR]]
    1678 ~~  2) ST_Intersection(raster, raster, integer) -> raster -- default first raster to band # 1[[BR]]
    1679 ~~  3) ST_Intersection(raster, integer, raster) -> raster -- default second raster to band # 1[[BR]]
    1680 ~~  4) ST_Intersection(raster, raster) -> raster -- default both rasters to band # 1
    1681
    1682 ----
    1683 == '''Objective FV.16 - Being able to quickly get raster statistics. - ''Done''''' ==
    1684
    1685 '''Add cached basic raster statistic to the base raster WKB format.
    1686
    1687 Statistics to be cached should include:
    1688
    1689   min/max[[BR]]
    1690   mean[[BR]]
    1691   standard deviation[[BR]]
    1692   histogram[[BR]]
    1693   build parameters of stats (sample rate, method used to determine # of bins in histogram?)[[BR]]
    1694
    1695 How are the statistics to be kept fresh?  Automatically using some method to see how much of the raster has changed since the last stats calculation?  Or let the user decide?
    1696
    1697 ----
    1698
    1699 '''ST_SummaryStats(raster, nband) -> record'''[[BR]]
    1700 This is the core function that gets the summary statistics (# of values, mean, standard deviation, minimum value, maximum value) of a specified raster's band.  It is this function that ST_Mean, ST_StdDev and ST_MinMax calls for their appropriate values.
    1701
    1702 1. ST_SummaryStats(rast raster, nband int, exclude_nodata_value boolean) -> record
    1703
    1704   returns one record of five columns (count, mean, stddev, min, max)
    1705
    1706   nband: index of band
    1707
    1708   exclude_nodata_value: if FALSE, nodata values in band are included in the stats. if TRUE, nodata values are not included
    1709
    1710 {{{
    1711 ST_SummaryStats(rast, 1, FALSE)
    1712 }}}
    1713
    1714 2. ST_SummaryStats(rast raster, nband int) -> record
    1715
    1716   assumes exclude_nodata_value = TRUE
    1717
    1718 {{{
    1719 ST_SummaryStats(rast, 2)
    1720 }}}
    1721
    1722 3. ST_SummaryStats(rast raster, exclude_nodata_value boolean) -> record
    1723
    1724   assumes nband = 1
    1725
    1726 {{{
    1727 ST_SummaryStats(rast, TRUE)
    1728 }}}
    1729
    1730 4. ST_SummaryStats(rast raster) -> record
    1731
    1732   assumes nband = 1 and exclude_nodata_value = TRUE
    1733
    1734 {{{
    1735 ST_SummaryStats(rast)
    1736 }}}
    1737
    1738 Due to the time it may take to do on-the-fly calculation of summary stats for large rasters (say 10000 x 10000), an alternative that sacrifices accuracy for speed is required.  The following functions sample a percentage of the raster in a methodical randomized manner.  The algorithm used for sampling is...
    1739
    1740 1. select the larger dimension of the width and height.  compute the number of pixels to sample in each "row" of the larger dimension
    1741
    1742 2. pick pixels from each "row" of the larger dimension in an incremental rolling manner where each increment is randomly determined.
    1743
    1744 The set of ST_ApproxSummaryStats functions are:
    1745
    1746 1. ST_ApproxSummaryStats(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision) -> record
    1747
    1748   sample_percent: a value between 0 and 1 indicating the percentage of the raster band's pixels to consider
    1749
    1750 {{{
    1751 ST_ApproxSummaryStats(rast, 3, FALSE, 0.1)
    1752
    1753 ST_ApproxSummaryStats(rast, 1, TRUE, 0.5)
    1754 }}}
    1755
    1756 2. ST_ApproxSummaryStats(rast raster, nband int, sample_percent double precision) -> record
    1757
    1758   assumes that nband = 1
    1759
    1760 {{{
    1761 ST_ApproxSummaryStats(rast, 2 0.01)
    1762
    1763 ST_ApproxSummaryStats(rast, 4, 0.025)
    1764 }}}
    1765
    1766 3. ST_ApproxSummaryStats(rast raster, exclude_nodata_value boolean, sample_percent double precision) -> record
    1767
    1768   assumes that nband = 1
    1769
    1770 {{{
    1771 ST_ApproxSummaryStats(rast, FALSE, 0.01)
    1772
    1773 ST_ApproxSummaryStats(rast, TRUE, 0.025)
    1774 }}}
    1775
    1776 4. ST_ApproxSummaryStats(rast raster, sample_percent double precision) -> record
    1777
    1778   assumes that nband = 1 and exclude_nodata_value = TRUE
    1779
    1780 {{{
    1781 ST_ApproxSummaryStats(rast, 0.25)
    1782 }}}
    1783
    1784 5. ST_ApproxSummaryStats(rast raster) -> record
    1785
    1786   assumes that nband = 1, exclude_nodata_value = TRUE and sample_percent = 0.1
    1787
    1788 {{{
    1789 ST_ApproxSummaryStats(rast)
    1790 }}}
    1791
    1792 The situation arises where the summary statistics of a coverage table is required.  As the coverage may be large (tens of gigabytes of memory or larger), the following functions are provided to permit an incremental computation of the summary statistics.
    1793
    1794 1. ST_SummaryStats(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean) -> record
    1795
    1796   rastertable: name of table with raster column
    1797
    1798   rastercolumn: name of column of data type raster
    1799
    1800 {{{
    1801 ST_SummaryStats('tmax_2010', 'rast', 1, FALSE)
    1802
    1803 ST_SummaryStats('precip_2011', 'rast', 1, TRUE)
    1804 }}}
    1805
    1806 2. ST_SummaryStats(rastertable text, rastercolumn text, nband int) -> record
    1807
    1808     exclude_nodata_value = TRUE
    1809
    1810 {{{
    1811 ST_SummaryStats('tmax_2010', 'rast', 1)
    1812 }}}
    1813
    1814 3. ST_SummaryStats(rastertable text, rastercolumn text, exclude_nodata_value boolean) -> record
    1815
    1816     nband = 1
    1817
    1818 {{{
    1819 ST_SummaryStats('precip_2011', 'rast', TRUE)
    1820 }}}
    1821
    1822 4. ST_SummaryStats(rastertable text, rastercolumn text) -> record
    1823
    1824     nband = 1 and exclude_nodata_value = TRUE
    1825
    1826 {{{
    1827 ST_SummaryStats('tmin_2009', 'rast')
    1828 }}}
    1829
    1830 Variations for ST_ApproxSummaryStats are:
    1831
    1832 1. ST_ApproxSummaryStats(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean, sample_percent double precision) -> record
    1833
    1834 {{{
    1835 ST_ApproxSummaryStats('tmax_2010', 'rast', 1, FALSE, 0.5)
    1836
    1837 ST_ApproxSummaryStats('precip_2011', 'rast', 1, TRUE, 0.2)
    1838 }}}
    1839
    1840 2. ST_ApproxSummaryStats(rastertable text, rastercolumn text, nband int, sample_percent double precision) -> record
    1841
    1842     exclude_nodata_value = TRUE
    1843
    1844 {{{
    1845 ST_ApproxSummaryStats('tmax_2010', 'rast', 1, 0.5)
    1846
    1847 ST_ApproxSummaryStats('precip_2011', 'rast', 1, 0.2)
    1848 }}}
    1849
    1850 3. ST_ApproxSummaryStats(rastertable text, rastercolumn text, exclude_nodata_value boolean, sample_percent double precision) -> record
    1851
    1852     nband = 1
    1853
    1854 {{{
    1855 ST_ApproxSummaryStats('tmax_2010', 'rast', FALSE, 0.5)
    1856
    1857 ST_ApproxSummaryStats('precip_2011', 'rast', TRUE, 0.2)
    1858 }}}
    1859
    1860 4. ST_ApproxSummaryStats(rastertable text, rastercolumn text, sample_percent double precision) -> record
    1861
    1862     nband = 1 and exclude_nodata_value = TRUE
    1863
    1864 {{{
    1865 ST_ApproxSummaryStats('tmax_2010', 'rast', 0.5)
    1866
    1867 ST_ApproxSummaryStats('precip_2011', 'rast', 0.2)
    1868 }}}
    1869
    1870 5. ST_ApproxSummaryStats(rastertable text, rastercolumn text) -> record
    1871
    1872     nband = 1, exclude_nodata_value = TRUE and sample_percent = 0.1
    1873
    1874 {{{
    1875 ST_ApproxSummaryStats('tmax_2010', 'rast')
    1876
    1877 ST_ApproxSummaryStats('precip_2011', 'rast')
    1878 }}}
    1879
    1880 The mean returned in the coverage functions (has rastertable and rastercolumn arguments) is the true mean of the raster tiles. The standard deviation returned is the standard deviation of all raster tiles.
    1881
    1882 ----
    1883
    1884 '''ST_Count(raster, nband) -> bigint'''[[BR]]
    1885
    1886 This function calls ST_SummaryStats and only returns the count from that function.
    1887
    1888 1. ST_Count(rast raster, nband int, exclude_nodata_value boolean) -> bigint
    1889
    1890     returns the count as an integer
    1891
    1892     nband: index of band
    1893
    1894     exclude_nodata_value: if FALSE, nodata values in band are included in the stats. if TRUE, nodata values are not included
    1895
    1896 {{{
    1897 ST_Count(rast, 1, FALSE)
    1898 }}}
    1899
    1900 2. ST_Count(rast raster, nband int) -> bigint
    1901
    1902     assumes exclude_nodata_value = TRUE
    1903
    1904 {{{
    1905 ST_Count(rast, 2)
    1906 }}}
    1907
    1908 3. ST_Count(rast raster, exclude_nodata_value boolean) -> bigint
    1909
    1910     assumes nband = 1
    1911
    1912 {{{
    1913 ST_Count(rast, TRUE)
    1914 }}}
    1915
    1916 4. ST_Count(rast raster) -> bigint
    1917
    1918     assumes nband = 1 and exclude_nodata_value = TRUE
    1919
    1920 {{{
    1921 ST_Count(rast)
    1922 }}}
    1923
    1924 The set of ST_ApproxCount functions are:
    1925
    1926 1. ST_ApproxCount(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision) -> bigint
    1927
    1928     sample_percent: a value between 0 and 1 indicating the percentage of the raster band's pixels to consider
    1929
    1930 {{{
    1931 ST_ApproxCount(rast, 3, FALSE, 0.1)
    1932
    1933 ST_ApproxCount(rast, 1, TRUE, 0.5)
    1934 }}}
    1935
    1936 2. ST_ApproxCount(rast raster, nband int, sample_percent double precision) -> bigint
    1937
    1938     assumes that nband = 1
    1939
    1940 {{{
    1941 ST_ApproxCount(rast, 2 0.01)
    1942
    1943 ST_ApproxCount(rast, 4, 0.025)
    1944 }}}
    1945
    1946 3. ST_ApproxCount(rast raster, exclude_nodata_value boolean, sample_percent double precision) -> bigint
    1947
    1948     assumes that nband = 1
    1949
    1950 {{{
    1951 ST_ApproxCount(rast, FALSE, 0.01)
    1952
    1953 ST_ApproxCount(rast, TRUE, 0.025)
    1954 }}}
    1955
    1956 4. ST_ApproxCount(rast raster, sample_percent double precision) -> bigint
    1957
    1958     assumes that nband = 1 and exclude_nodata_value = TRUE
    1959
    1960 {{{
    1961 ST_ApproxCount(rast, 0.25)
    1962 }}}
    1963
    1964 5. ST_ApproxCount(rast raster) -> bigint
    1965
    1966     assumes that nband = 1, exclude_nodata_value = TRUE and sample_percent = 0.1
    1967
    1968 {{{
    1969 ST_ApproxCount(rast)
    1970 }}}
    1971
    1972 The following functions are provided for coverage tables.
    1973
    1974 1. ST_Count(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean) -> bigint
    1975
    1976     rastertable: name of table with raster column
    1977
    1978     rastercolumn: name of column of data type raster
    1979
    1980 {{{
    1981 ST_Count('tmax_2010', 'rast', 1, FALSE)
    1982
    1983 ST_Count('precip_2011', 'rast', 1, TRUE)
    1984 }}}
    1985
    1986 2. ST_Count(rastertable text, rastercolumn text, nband int) -> bigint
    1987
    1988     exclude_nodata_value = TRUE
    1989
    1990 {{{
    1991 ST_Count('tmax_2010', 'rast', 1)
    1992 }}}
    1993
    1994 3. ST_Count(rastertable text, rastercolumn text, exclude_nodata_value boolean) -> bigint
    1995
    1996     nband = 1
    1997
    1998 {{{
    1999 ST_Count('precip_2011', 'rast', TRUE)
    2000 }}}
    2001
    2002 4. ST_Count(rastertable text, rastercolumn text) -> bigint
    2003
    2004     nband = 1 and exclude_nodata_value = TRUE
    2005
    2006 {{{
    2007 ST_Count('tmin_2009', 'rast')
    2008 }}}
    2009
    2010 Variations for ST_ApproxCount are:
    2011
    2012 1. ST_ApproxCount(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean, sample_percent double precision) -> bigint
    2013
    2014 {{{
    2015 ST_ApproxCount('tmax_2010', 'rast', 1, FALSE, 0.5)
    2016
    2017 ST_ApproxCount('precip_2011', 'rast', 1, TRUE, 0.2)
    2018 }}}
    2019
    2020 2. ST_ApproxCount(rastertable text, rastercolumn text, nband int, sample_percent double precision) -> bigint
    2021
    2022     exclude_nodata_value = TRUE
    2023
    2024 {{{
    2025 ST_ApproxCount('tmax_2010', 'rast', 1, 0.5)
    2026
    2027 ST_ApproxCount('precip_2011', 'rast', 1, 0.2)
    2028 }}}
    2029
    2030 3. ST_ApproxCount(rastertable text, rastercolumn text, exclude_nodata_value boolean, sample_percent double precision) -> bigint
    2031
    2032     nband = 1
    2033
    2034 {{{
    2035 ST_ApproxCount('tmax_2010', 'rast', FALSE, 0.5)
    2036
    2037 ST_ApproxCount('precip_2011', 'rast', TRUE, 0.2)
    2038 }}}
    2039
    2040 4. ST_ApproxCount(rastertable text, rastercolumn text, sample_percent double precision) -> bigint
    2041
    2042     nband = 1 and exclude_nodata_value = TRUE
    2043
    2044 {{{
    2045 ST_ApproxCount('tmax_2010', 'rast', 0.5)
    2046
    2047 ST_ApproxCount('precip_2011', 'rast', 0.2)
    2048 }}}
    2049
    2050 5. ST_ApproxCount(rastertable text, rastercolumn text) -> bigint
    2051
    2052     nband = 1, exclude_nodata_value = TRUE and sample_percent = 0.1
    2053
    2054 {{{
    2055 ST_ApproxCount('tmax_2010', 'rast')
    2056
    2057 ST_ApproxCount('precip_2011', 'rast')
    2058 }}}
    2059
    2060 ----
    2061
    2062 '''ST_Sum(raster, nband) -> double precision'''[[BR]]
    2063
    2064 This function calls ST_SummaryStats and only returns the sum from that function.
    2065
    2066 1. ST_Sum(rast raster, nband int, exclude_nodata_value boolean) -> double precision
    2067
    2068     returns the sum as an integer
    2069
    2070     nband: index of band
    2071
    2072     exclude_nodata_value: if FALSE, nodata values in band are included in the stats. if TRUE, nodata values are not included
    2073
    2074 {{{
    2075 ST_Sum(rast, 1, FALSE)
    2076 }}}
    2077
    2078 2. ST_Sum(rast raster, nband int) -> double precision
    2079
    2080     assumes exclude_nodata_value = TRUE
    2081
    2082 {{{
    2083 ST_Sum(rast, 2)
    2084 }}}
    2085
    2086 3. ST_Sum(rast raster, exclude_nodata_value boolean) -> double precision
    2087
    2088     assumes nband = 1
    2089
    2090 {{{
    2091 ST_Sum(rast, TRUE)
    2092 }}}
    2093
    2094 4. ST_Sum(rast raster) -> double precision
    2095
    2096     assumes nband = 1 and exclude_nodata_value = TRUE
    2097
    2098 {{{
    2099 ST_Sum(rast)
    2100 }}}
    2101
    2102 The set of ST_ApproxSum functions are:
    2103
    2104 1. ST_ApproxSum(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision) -> double precision
    2105
    2106     sample_percent: a value between 0 and 1 indicating the percentage of the raster band's pixels to consider
    2107
    2108 {{{
    2109 ST_ApproxSum(rast, 3, FALSE, 0.1)
    2110
    2111 ST_ApproxSum(rast, 1, TRUE, 0.5)
    2112 }}}
    2113
    2114 2. ST_ApproxSum(rast raster, nband int, sample_percent double precision) -> double precision
    2115
    2116     assumes that nband = 1
    2117
    2118 {{{
    2119 ST_ApproxSum(rast, 2 0.01)
    2120
    2121 ST_ApproxSum(rast, 4, 0.025)
    2122 }}}
    2123
    2124 3. ST_ApproxSum(rast raster, exclude_nodata_value boolean, sample_percent double precision) -> double precision
    2125
    2126     assumes that nband = 1
    2127
    2128 {{{
    2129 ST_ApproxSum(rast, FALSE, 0.01)
    2130
    2131 ST_ApproxSum(rast, TRUE, 0.025)
    2132 }}}
    2133
    2134 4. ST_ApproxSum(rast raster, sample_percent double precision) -> double precision
    2135
    2136     assumes that nband = 1 and exclude_nodata_value = TRUE
    2137
    2138 {{{
    2139 ST_ApproxSum(rast, 0.25)
    2140 }}}
    2141
    2142 5. ST_ApproxSum(rast raster) -> double precision
    2143
    2144     assumes that nband = 1, exclude_nodata_value = TRUE and sample_percent = 0.1
    2145
    2146 {{{
    2147 ST_ApproxSum(rast)
    2148 }}}
    2149
    2150 The following functions are provided for coverage tables.
    2151
    2152 1. ST_Sum(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean) -> double precision
    2153
    2154     rastertable: name of table with raster column
    2155
    2156     rastercolumn: name of column of data type raster
    2157
    2158 {{{
    2159 ST_Sum('tmax_2010', 'rast', 1, FALSE)
    2160
    2161 ST_Sum('precip_2011', 'rast', 1, TRUE)
    2162 }}}
    2163
    2164 2. ST_Sum(rastertable text, rastercolumn text, nband int) -> double precision
    2165
    2166     exclude_nodata_value = TRUE
    2167
    2168 {{{
    2169 ST_Sum('tmax_2010', 'rast', 1)
    2170 }}}
    2171
    2172 3. ST_Sum(rastertable text, rastercolumn text, exclude_nodata_value boolean) -> double precision
    2173
    2174     nband = 1
    2175
    2176 {{{
    2177 ST_Sum('precip_2011', 'rast', TRUE)
    2178 }}}
    2179
    2180 4. ST_Sum(rastertable text, rastercolumn text) -> double precision
    2181
    2182     nband = 1 and exclude_nodata_value = TRUE
    2183
    2184 {{{
    2185 ST_Sum('tmin_2009', 'rast')
    2186 }}}
    2187
    2188 Variations for ST_ApproxSum are:
    2189
    2190 1. ST_ApproxSum(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean, sample_percent double precision) -> double precision
    2191
    2192 {{{
    2193 ST_ApproxSum('tmax_2010', 'rast', 1, FALSE, 0.5)
    2194
    2195 ST_ApproxSum('precip_2011', 'rast', 1, TRUE, 0.2)
    2196 }}}
    2197
    2198 2. ST_ApproxSum(rastertable text, rastercolumn text, nband int, sample_percent double precision) -> double precision
    2199
    2200     exclude_nodata_value = TRUE
    2201
    2202 {{{
    2203 ST_ApproxSum('tmax_2010', 'rast', 1, 0.5)
    2204
    2205 ST_ApproxSum('precip_2011', 'rast', 1, 0.2)
    2206 }}}
    2207
    2208 3. ST_ApproxSum(rastertable text, rastercolumn text, exclude_nodata_value boolean, sample_percent double precision) -> double precision
    2209
    2210     nband = 1
    2211
    2212 {{{
    2213 ST_ApproxSum('tmax_2010', 'rast', FALSE, 0.5)
    2214
    2215 ST_ApproxSum('precip_2011', 'rast', TRUE, 0.2)
    2216 }}}
    2217
    2218 4. ST_ApproxSum(rastertable text, rastercolumn text, sample_percent double precision) -> double precision
    2219
    2220     nband = 1 and exclude_nodata_value = TRUE
    2221
    2222 {{{
    2223 ST_ApproxSum('tmax_2010', 'rast', 0.5)
    2224
    2225 ST_ApproxSum('precip_2011', 'rast', 0.2)
    2226 }}}
    2227
    2228 5. ST_ApproxSum(rastertable text, rastercolumn text) -> double precision
    2229
    2230     nband = 1, exclude_nodata_value = TRUE and sample_percent = 0.1
    2231
    2232 {{{
    2233 ST_ApproxSum('tmax_2010', 'rast')
    2234
    2235 ST_ApproxSum('precip_2011', 'rast')
    2236 }}}
    2237
    2238 ----
    2239
    2240 '''ST_Mean(raster, nband) -> double precision'''[[BR]]
    2241 This function calls ST_SummaryStats and only returns the mean from that function.
    2242
    2243 1. ST_Mean(rast raster, nband int, exclude_nodata_value boolean) -> double precision
    2244
    2245   returns the mean as a double precision
    2246
    2247   nband: index of band
    2248
    2249   exclude_nodata_value: if FALSE, nodata values in band are included. if TRUE, nodata values are not included.
    2250
    2251 {{{
    2252 ST_Mean(rast, 1, FALSE)
    2253 }}}
    2254
    2255 2. ST_Mean(rast raster, nband int) -> double precision
    2256
    2257   assumes exclude_nodata_value = TRUE
    2258
    2259 {{{
    2260 ST_Mean(rast, 2)
    2261 }}}
    2262
    2263 3. ST_Mean(rast raster, exclude_nodata_value boolean) -> double precision
    2264
    2265   assumes nband = 1
    2266
    2267 {{{
    2268 ST_Mean(rast, TRUE)
    2269 }}}
    2270
    2271 4. ST_Mean(rast raster) -> double precision
    2272
    2273   assumes nband = 1 and exclude_nodata_value = TRUE
    2274
    2275 {{{
    2276 ST_Mean(rast)
    2277 }}}
    2278
    2279 The set of ST_ApproxMean functions are:
    2280
    2281 1. ST_ApproxMean(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision) -> double precision
    2282
    2283   sample_percent: a value between 0 and 1 indicating the percentage of the raster band's pixels to consider
    2284
    2285 {{{
    2286 ST_ApproxMean(rast, 3, FALSE, 0.1)
    2287
    2288 ST_ApproxMean(rast, 1, TRUE, 0.5)
    2289 }}}
    2290
    2291 2. ST_ApproxMean(rast raster, nband int, sample_percent double precision) -> double precision
    2292
    2293   assumes that nband = 1
    2294
    2295 {{{
    2296 ST_ApproxMean(rast, 2 0.01)
    2297
    2298 ST_ApproxMean(rast, 4, 0.025)
    2299 }}}
    2300
    2301 3. ST_ApproxMean(rast raster, exclude_nodata_value boolean, sample_percent double precision) -> double precision
    2302
    2303   assumes that nband = 1
    2304
    2305 {{{
    2306 ST_ApproxMean(rast, FALSE, 0.01)
    2307
    2308 ST_ApproxMean(rast, TRUE, 0.025)
    2309 }}}
    2310
    2311 4. ST_ApproxMean(rast raster, sample_percent double precision) -> double precision
    2312
    2313   assumes that nband = 1 and exclude_nodata_value = TRUE
    2314
    2315 {{{
    2316 ST_ApproxMean(rast, 0.25)
    2317 }}}
    2318
    2319 5. ST_ApproxMean(rast raster) -> double precision
    2320
    2321   assumes that nband = 1, exclude_nodata_value = TRUE and sample_percent = 0.1
    2322
    2323 {{{
    2324 ST_ApproxMean(rast)
    2325 }}}
    2326
    2327 The following functions are provided for coverage tables.
    2328
    2329 1. ST_Mean(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean) -> double precision
    2330
    2331   rastertable: name of table with raster column
    2332
    2333   rastercolumn: name of column of data type raster
    2334
    2335 {{{
    2336 ST_Mean('tmax_2010', 'rast', 1, FALSE)
    2337
    2338 ST_Mean('precip_2011', 'rast', 1, TRUE)
    2339 }}}
    2340
    2341 2. ST_Mean(rastertable text, rastercolumn text, nband int) -> double precision
    2342
    2343     exclude_nodata_value = TRUE
    2344
    2345 {{{
    2346 ST_Mean('tmax_2010', 'rast', 1)
    2347 }}}
    2348
    2349 3. ST_Mean(rastertable text, rastercolumn text, exclude_nodata_value boolean) -> double precision
    2350
    2351     nband = 1
    2352
    2353 {{{
    2354 ST_Mean('precip_2011', 'rast', TRUE)
    2355 }}}
    2356
    2357 4. ST_Mean(rastertable text, rastercolumn text) -> double precision
    2358
    2359     nband = 1 and exclude_nodata_value = TRUE
    2360
    2361 {{{
    2362 ST_Mean('tmin_2009', 'rast')
    2363 }}}
    2364
    2365 Variations for ST_ApproxMean are:
    2366
    2367 1. ST_ApproxMean(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean, sample_percent double precision) -> double precision
    2368
    2369 {{{
    2370 ST_ApproxMean('tmax_2010', 'rast', 1, FALSE, 0.5)
    2371
    2372 ST_ApproxMean('precip_2011', 'rast', 1, TRUE, 0.2)
    2373 }}}
    2374
    2375 2. ST_ApproxMean(rastertable text, rastercolumn text, nband int, sample_percent double precision) -> double precision
    2376
    2377     exclude_nodata_value = TRUE
    2378
    2379 {{{
    2380 ST_ApproxMean('tmax_2010', 'rast', 1, 0.5)
    2381
    2382 ST_ApproxMean('precip_2011', 'rast', 1, 0.2)
    2383 }}}
    2384
    2385 3. ST_ApproxMean(rastertable text, rastercolumn text, exclude_nodata_value boolean, sample_percent double precision) -> double precision
    2386
    2387     nband = 1
    2388
    2389 {{{
    2390 ST_ApproxMean('tmax_2010', 'rast', FALSE, 0.5)
    2391
    2392 ST_ApproxMean('precip_2011', 'rast', TRUE, 0.2)
    2393 }}}
    2394
    2395 4. ST_ApproxMean(rastertable text, rastercolumn text, sample_percent double precision) -> double precision
    2396
    2397     nband = 1 and exclude_nodata_value = TRUE
    2398
    2399 {{{
    2400 ST_ApproxMean('tmax_2010', 'rast', 0.5)
    2401
    2402 ST_ApproxMean('precip_2011', 'rast', 0.2)
    2403 }}}
    2404
    2405 5. ST_ApproxMean(rastertable text, rastercolumn text) -> double precision
    2406
    2407     nband = 1, exclude_nodata_value = TRUE and sample_percent = 0.1
    2408
    2409 {{{
    2410 ST_ApproxMean('tmax_2010', 'rast')
    2411
    2412 ST_ApproxMean('precip_2011', 'rast')
    2413 }}}
    2414
    2415 The mean returned in the coverage functions (has rastertable and rastercolumn arguments) is the true mean of the raster tiles.
    2416
    2417 ----
    2418
    2419 '''ST_StdDev(raster, nband) -> double precision'''[[BR]]
    2420 This function calls ST_SummaryStats and only returns the standard deviation from that function.
    2421
    2422 1. ST_StdDev(rast raster, nband int, exclude_nodata_value boolean) -> double precision
    2423
    2424   returns the standard deviation as a double precision
    2425
    2426   nband: index of band
    2427
    2428   exclude_nodata_value: if FALSE, nodata values in band are included. if TRUE, nodata values are not included.
    2429
    2430 {{{
    2431 ST_StdDev(rast, 1, FALSE)
    2432 }}}
    2433
    2434 2. ST_StdDev(rast raster, nband int) -> double precision
    2435
    2436   assumes exclude_nodata_value = TRUE
    2437
    2438 {{{
    2439 ST_StdDev(rast, 2)
    2440 }}}
    2441
    2442 3. ST_StdDev(rast raster, exclude_nodata_value boolean) -> double precision
    2443
    2444   assumes nband = 1
    2445
    2446 {{{
    2447 ST_StdDev(rast, TRUE)
    2448 }}}
    2449
    2450 4. ST_StdDev(rast raster) -> double precision
    2451
    2452   assumes nband = 1 and exclude_nodata_value = TRUE
    2453
    2454 {{{
    2455 ST_StdDev(rast)
    2456 }}}
    2457
    2458 The set of ST_ApproxStdDev functions are:
    2459
    2460 1. ST_ApproxStdDev(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision) -> double precision
    2461
    2462   sample_percent: a value between 0 and 1 indicating the percentage of the raster band's pixels to consider
    2463
    2464 {{{
    2465 ST_ApproxStdDev(rast, 3, FALSE, 0.1)
    2466
    2467 ST_ApproxStdDev(rast, 1, TRUE, 0.5)
    2468 }}}
    2469
    2470 2. ST_ApproxStdDev(rast raster, nband int, sample_percent double precision) -> double precision
    2471
    2472   assumes that nband = 1
    2473
    2474 {{{
    2475 ST_ApproxStdDev(rast, 2 0.01)
    2476
    2477 ST_ApproxStdDev(rast, 4, 0.025)
    2478 }}}
    2479
    2480 3. ST_ApproxStdDev(rast raster, exclude_nodata_value boolean, sample_percent double precision) -> double precision
    2481
    2482   assumes that nband = 1
    2483
    2484 {{{
    2485 ST_ApproxStdDev(rast, FALSE, 0.01)
    2486
    2487 ST_ApproxStdDev(rast, TRUE, 0.025)
    2488 }}}
    2489
    2490 4. ST_ApproxStdDev(rast raster, sample_percent double precision) -> double precision
    2491
    2492   assumes that nband = 1 and exclude_nodata_value = TRUE
    2493
    2494 {{{
    2495 ST_ApproxStdDev(rast, 0.25)
    2496 }}}
    2497
    2498 5. ST_ApproxStdDev(rast raster) -> double precision
    2499
    2500   assumes that nband = 1, exclude_nodata_value = TRUE and sample_percent = 0.1
    2501
    2502 {{{
    2503 ST_ApproxStdDev(rast)
    2504 }}}
    2505
    2506 The following functions are provided for coverage tables.
    2507
    2508 1. ST_StdDev(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean) -> double precision
    2509
    2510   rastertable: name of table with raster column
    2511
    2512   rastercolumn: name of column of data type raster
    2513
    2514 {{{
    2515 ST_StdDev('tmax_2010', 'rast', 1, FALSE)
    2516
    2517 ST_StdDev('precip_2011', 'rast', 1, TRUE)
    2518 }}}
    2519
    2520 2. ST_StdDev(rastertable text, rastercolumn text, nband int) -> double precision
    2521
    2522     exclude_nodata_value = TRUE
    2523
    2524 {{{
    2525 ST_StdDev('tmax_2010', 'rast', 1)
    2526 }}}
    2527
    2528 3. ST_StdDev(rastertable text, rastercolumn text, exclude_nodata_value boolean) -> double precision
    2529
    2530     nband = 1
    2531
    2532 {{{
    2533 ST_StdDev('precip_2011', 'rast', TRUE)
    2534 }}}
    2535
    2536 4. ST_StdDev(rastertable text, rastercolumn text) -> double precision
    2537
    2538     nband = 1 and exclude_nodata_value = TRUE
    2539
    2540 {{{
    2541 ST_StdDev('tmin_2009', 'rast')
    2542 }}}
    2543
    2544 Variations for ST_ApproxStdDev are:
    2545
    2546 1. ST_ApproxStdDev(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean, sample_percent double precision) -> double precision
    2547
    2548 {{{
    2549 ST_ApproxStdDev('tmax_2010', 'rast', 1, FALSE, 0.5)
    2550
    2551 ST_ApproxStdDev('precip_2011', 'rast', 1, TRUE, 0.2)
    2552 }}}
    2553
    2554 2. ST_ApproxStdDev(rastertable text, rastercolumn text, nband int, sample_percent double precision) -> double precision
    2555
    2556     exclude_nodata_value = TRUE
    2557
    2558 {{{
    2559 ST_ApproxStdDev('tmax_2010', 'rast', 1, 0.5)
    2560
    2561 ST_ApproxStdDev('precip_2011', 'rast', 1, 0.2)
    2562 }}}
    2563
    2564 3. ST_ApproxStdDev(rastertable text, rastercolumn text, exclude_nodata_value boolean, sample_percent double precision) -> double precision
    2565
    2566     nband = 1
    2567
    2568 {{{
    2569 ST_ApproxStdDev('tmax_2010', 'rast', FALSE, 0.5)
    2570
    2571 ST_ApproxStdDev('precip_2011', 'rast', TRUE, 0.2)
    2572 }}}
    2573
    2574 4. ST_ApproxStdDev(rastertable text, rastercolumn text, sample_percent double precision) -> double precision
    2575
    2576     nband = 1 and exclude_nodata_value = TRUE
    2577
    2578 {{{
    2579 ST_ApproxStdDev('tmax_2010', 'rast', 0.5)
    2580
    2581 ST_ApproxStdDev('precip_2011', 'rast', 0.2)
    2582 }}}
    2583
    2584 5. ST_ApproxStdDev(rastertable text, rastercolumn text) -> double precision
    2585
    2586     nband = 1, exclude_nodata_value = TRUE and sample_percent = 0.1
    2587
    2588 {{{
    2589 ST_ApproxStdDev('tmax_2010', 'rast')
    2590
    2591 ST_ApproxStdDev('precip_2011', 'rast')
    2592 }}}
    2593
    2594 The standard deviation returned in the coverage functions (has rastertable and rastercolumn arguments) is the standard deviation of all raster tiles.
    2595
    2596 ----
    2597
    2598 '''ST_MinMax(raster, nband) -> record'''[[BR]]
    2599 This function calls ST_SummaryStats and only returns the min and max values from that function.
    2600
    2601 1. ST_MinMax(rast raster, nband int, exclude_nodata_value boolean) -> record
    2602
    2603   returns the record (min double precision, max double precision)
    2604
    2605   nband: index of band
    2606
    2607   exclude_nodata_value: if FALSE, nodata values in band are included. if TRUE, nodata values are not included.
    2608
    2609 {{{
    2610 ST_MinMax(rast, 1, FALSE)
    2611 }}}
    2612
    2613 2. ST_MinMax(rast raster, nband int) -> record
    2614
    2615   assumes exclude_nodata_value = TRUE
    2616
    2617 {{{
    2618 ST_MinMax(rast, 2)
    2619 }}}
    2620
    2621 3. ST_MinMax(rast raster, exclude_nodata_value boolean) -> record
    2622
    2623   assumes nband = 1
    2624
    2625 {{{
    2626 ST_MinMax(rast, TRUE)
    2627 }}}
    2628
    2629 4. ST_MinMax(rast raster) -> record
    2630
    2631   assumes nband = 1 and exclude_nodata_value = TRUE
    2632
    2633 {{{
    2634 ST_MinMax(rast)
    2635 }}}
    2636
    2637 The set of ST_ApproxMinMax functions are:
    2638
    2639 1. ST_ApproxMinMax(rast raster, nband int, exclude_nodata_value boolean, sample_percent record) -> record
    2640
    2641   sample_percent: a value between 0 and 1 indicating the percentage of the raster band's pixels to consider
    2642
    2643 {{{
    2644 ST_ApproxMinMax(rast, 3, FALSE, 0.1)
    2645
    2646 ST_ApproxMinMax(rast, 1, TRUE, 0.5)
    2647 }}}
    2648
    2649 2. ST_ApproxMinMax(rast raster, nband int, sample_percent double precision) -> record
    2650
    2651   assumes that nband = 1
    2652
    2653 {{{
    2654 ST_ApproxMinMax(rast, 2 0.01)
    2655
    2656 ST_ApproxMinMax(rast, 4, 0.025)
    2657 }}}
    2658
    2659 3. ST_ApproxMinMax(rast raster, exclude_nodata_value boolean, sample_percent double precision) -> record
    2660
    2661   assumes that nband = 1
    2662
    2663 {{{
    2664 ST_ApproxMinMax(rast, FALSE, 0.01)
    2665
    2666 ST_ApproxMinMax(rast, TRUE, 0.025)
    2667 }}}
    2668
    2669 4. ST_ApproxMinMax(rast raster, sample_percent double precision) -> record
    2670
    2671   assumes that nband = 1 and exclude_nodata_value = TRUE
    2672
    2673 {{{
    2674 ST_ApproxMinMax(rast, 0.25)
    2675 }}}
    2676
    2677 5. ST_ApproxMinMax(rast raster) -> record
    2678
    2679   assumes that nband = 1, exclude_nodata_value = TRUE and sample_percent = 0.1
    2680
    2681 {{{
    2682 ST_ApproxMinMax(rast)
    2683 }}}
    2684
    2685 The following functions are provided for coverage tables.
    2686
    2687 1. ST_MinMax(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean) -> record
    2688
    2689   rastertable: name of table with raster column
    2690
    2691   rastercolumn: name of column of data type raster
    2692
    2693 {{{
    2694 ST_MinMax('tmax_2010', 'rast', 1, FALSE)
    2695
    2696 ST_MinMax('precip_2011', 'rast', 1, TRUE)
    2697 }}}
    2698
    2699 2. ST_MinMax(rastertable text, rastercolumn text, nband int) -> record
    2700
    2701     exclude_nodata_value = TRUE
    2702
    2703 {{{
    2704 ST_MinMax('tmax_2010', 'rast', 1)
    2705 }}}
    2706
    2707 3. ST_MinMax(rastertable text, rastercolumn text, exclude_nodata_value boolean) -> record
    2708
    2709     nband = 1
    2710
    2711 {{{
    2712 ST_MinMax('precip_2011', 'rast', TRUE)
    2713 }}}
    2714
    2715 4. ST_MinMax(rastertable text, rastercolumn text) -> record
    2716
    2717     nband = 1 and exclude_nodata_value = TRUE
    2718
    2719 {{{
    2720 ST_MinMax('tmin_2009', 'rast')
    2721 }}}
    2722
    2723 Variations for ST_ApproxMinMax are:
    2724
    2725 1. ST_ApproxMinMax(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean, sample_percent double precision) -> record
    2726
    2727 {{{
    2728 ST_ApproxMinMax('tmax_2010', 'rast', 1, FALSE, 0.5)
    2729
    2730 ST_ApproxMinMax('precip_2011', 'rast', 1, TRUE, 0.2)
    2731 }}}
    2732
    2733 2. ST_ApproxMinMax(rastertable text, rastercolumn text, nband int, sample_percent double precision) -> record
    2734
    2735     exclude_nodata_value = TRUE
    2736
    2737 {{{
    2738 ST_ApproxMinMax('tmax_2010', 'rast', 1, 0.5)
    2739
    2740 ST_ApproxMinMax('precip_2011', 'rast', 1, 0.2)
    2741 }}}
    2742
    2743 3. ST_ApproxMinMax(rastertable text, rastercolumn text, exclude_nodata_value boolean, sample_percent double precision) -> record
    2744
    2745     nband = 1
    2746
    2747 {{{
    2748 ST_ApproxMinMax('tmax_2010', 'rast', FALSE, 0.5)
    2749
    2750 ST_ApproxMinMax('precip_2011', 'rast', TRUE, 0.2)
    2751 }}}
    2752
    2753 4. ST_ApproxMinMax(rastertable text, rastercolumn text, sample_percent double precision) -> record
    2754
    2755     nband = 1 and exclude_nodata_value = TRUE
    2756
    2757 {{{
    2758 ST_ApproxMinMax('tmax_2010', 'rast', 0.5)
    2759
    2760 ST_ApproxMinMax('precip_2011', 'rast', 0.2)
    2761 }}}
    2762
    2763 5. ST_ApproxMinMax(rastertable text, rastercolumn text) -> record
    2764
    2765     nband = 1, exclude_nodata_value = TRUE and sample_percent = 0.1
    2766
    2767 {{{
    2768 ST_ApproxMinMax('tmax_2010', 'rast')
    2769
    2770 ST_ApproxMinMax('precip_2011', 'rast')
    2771 }}}
    2772
    2773 ----
    2774
    2775 '''ST_Histogram(raster, nband) -> set of records'''[[BR]]
    2776 ST_Histogram and ST_ApproxHistogram provide methods to determine a raster's data distribution.
    2777
    2778 The return of ST_Histogram and ST_ApproxHistogram is a set of records where each record is (min, max, count, percent).
    2779
    2780 ST_Histogram has the following variations.
    2781
    2782 1. ST_Histogram(rast raster, nband int, exclude_nodata_value boolean, bins int, width double precision[], right boolean) -> set of records
    2783
    2784   returns set of records of four columns (min, max, count, percent)
    2785
    2786   nband: index of band to process on
    2787
    2788   exclude_nodata_value: if FALSE, nodata values in band are included. if TRUE, nodata values are not included.
    2789
    2790   bins: the number of categories/bins to have in the histogram. If NULL or value less than one, the number of categories will be auto-computed using Sturges' formula if the number of values >= 30 or Square-root choice if number of values < 30.
    2791
    2792     http://en.wikipedia.org/wiki/Histogram#Mathematical_definition
    2793
    2794   width: an array indicating the width of each category/bin. If the number of bins is greater than the number of widths, the widths are repeated. Example: 9 bins, widths are [a, b, c] will have the output be [a, b, c, a, b, c, a, b, c].
    2795
    2796   right: compute the histogram from the right rather than from the left (default). This changes the criteria for evaluating a value x from [a, b) to (a, b].
    2797
    2798 {{{
    2799 ST_Histogram(rast, 2, FALSE, NULL, NULL, FALSE)
    2800
    2801 ST_Histogram(rast, 1, TRUE, 100, NULL, FALSE)
    2802
    2803 ST_Histogram(rast, 2, FALSE, NULL, ARRAY[100, 50], FALSE)
    2804
    2805 ST_Histogram(rast, 2, FALSE, 9, ARRAY[1000], TRUE)
    2806
    2807 ST_Histogram(rast, 2, FALSE, 20, ARRAY[100, 200, 300], TRUE)
    2808 }}}
    2809
    2810 2. ST_Histogram(rast raster, nband int, exclude_nodata_value boolean, bins int, right boolean) -> set of records
    2811
    2812   parameter "width" is not specified thus resulting in all bins having the same widths
    2813
    2814 {{{
    2815 ST_Histogram(rast, 2, FALSE, 5, FALSE)
    2816 }}}
    2817
    2818 3. ST_Histogram(rast raster, nband int, exclude_nodata_value boolean, bins int) -> set of records
    2819
    2820   the parameter "right" is removed and assumed to be FALSE
    2821
    2822 {{{
    2823 ST_Histogram(rast, 2, FALSE, 5)
    2824 }}}
    2825
    2826 4. ST_Histogram(rast raster, nband int, exclude_nodata_value boolean) -> set of records
    2827
    2828   the parameter "bins" is removed and set to NULL.  The function will compute the number of bins to use
    2829
    2830 5. ST_Histogram(rast raster, nband int) -> set of records
    2831
    2832   exclude_nodata_value is assumed to be TRUE
    2833
    2834 6. ST_Histogram(rast raster) -> set of records
    2835
    2836   assumes that nband is 1.
    2837
    2838 7. ST_Histogram(rast raster, nband int, bins int, width double precision[], right boolean) -> set of records
    2839
    2840   exclude_nodata_value is assumed to be TRUE
    2841
    2842 8. ST_Histogram(rast raster, nband int, bins int, right boolean) -> set of records
    2843
    2844   all bins will have equal widths
    2845
    2846 9. ST_Histogram(rast raster, nband int, bins int) -> set of records
    2847
    2848   right is assumed to be FALSE
    2849
    2850 ST_ApproxHistogram should have the following variations.
    2851
    2852 1. ST_ApproxHistogram(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision, bins int, width double precision[], right boolean) -> set of record
    2853
    2854     sample_percent: a value between 0 and 1 indicating the percentage of the raster band's pixels to consider when generating the histogram.
    2855
    2856 {{{
    2857 ST_Histogram(rast, 2, FALSE, 0.1, NULL, NULL, FALSE)
    2858
    2859 ST_Histogram(rast, 1, TRUE, 1, 100, NULL, FALSE)
    2860
    2861 ST_Histogram(rast, 2, FALSE, 0.2, NULL, ARRAY[100, 50], FALSE)
    2862
    2863 ST_Histogram(rast, 2, FALSE, 0.25, 9, ARRAY[1000], TRUE)
    2864
    2865 ST_Histogram(rast, 2, FALSE, 0.05, 20, ARRAY[100, 200, 300], TRUE)
    2866 }}}
    2867
    2868 2. ST_ApproxHistogram(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision, bins int, right boolean) -> set of records
    2869
    2870   parameter "width" is not specified thus resulting in all bins having the same widths
    2871
    2872 3. ST_ApproxHistogram(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision, bins int) -> set of records
    2873
    2874   the parameter "right" is removed and assumed to be FALSE
    2875
    2876 {{{
    2877 ST_ApproxHistogram(rast, 2, FALSE, 5)
    2878 }}}
    2879
    2880 4. ST_ApproxHistogram(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision) -> set of records
    2881
    2882   the parameter "bins" is removed and set to NULL so that function can compute the number of bins to use
    2883
    2884 5. ST_ApproxHistogram(rast raster, nband int, sample_percent double precision) -> set of records
    2885
    2886   exclude_nodata_value is assumed to be TRUE
    2887
    2888 6. ST_ApproxHistogram(rast raster, nband int) -> set of records
    2889
    2890   assumes that sample_percent is 0.1
    2891
    2892 7. ST_ApproxHistogram(rast raster, sample_percent double_precision) -> set of records
    2893
    2894   assumes that nband is 1
    2895
    2896 8. ST_ApproxHistogram(rast raster) -> set of records
    2897
    2898   assumes that nband is 1 and sample_percent is 0.1
    2899
    2900 9. ST_ApproxHistogram(rast raster, nband int, sample_percent double precision, bins int, width double precision[], right boolean) -> set of records
    2901
    2902   exclude_nodata_value is assumed to be TRUE
    2903
    2904 10. ST_ApproxHistogram(rast raster, nband int, sample_percent double precision, bins int, right boolean) -> set of records
    2905
    2906   all bins will have equal widths
    2907
    2908 11. ST_ApproxHistogram(rast raster, nband int, sample_percent double precision, bins int) -> set of records
    2909
    2910   right is assumed to be FALSE
    2911
    2912 The following set of function are for coverages.
    2913
    2914 1. ST_Histogram(rastertable text, rastercolumn text, nband int DEFAULT 1, exclude_nodata_value boolean DEFAULT TRUE, bins int default 0, width double precision[] DEFAULT NULL, right boolean DEFAULT FALSE) -> set of records
    2915
    2916   rastertable: name of table with raster column
    2917
    2918   rastercolumn: name of column of data type raster
    2919
    2920 {{{
    2921 ST_Histogram('tmax_2010', 'rast')
    2922
    2923 ST_Histogram('precip_2011', 'rast', 1)
    2924
    2925 ST_Histogram('precip_2011', 'rast', 1, FALSE)
    2926
    2927 ST_Histogram('precip_2011', 'rast', 1, FALSE, 5)
    2928
    2929 ST_Histogram('precip_2011', 'rast', 1, FALSE, 10, NULL)
    2930
    2931 ST_Histogram('precip_2011', 'rast', 1, FALSE, 10, NULL, TRUE)
    2932 }}}
    2933
    2934 2. ST_Histogram(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean, bins int, right boolean) -> set of records
    2935
    2936 {{{
    2937 ST_Histogram('tmin_2010', 'rast', 2, FALSE, 5, FALSE)
    2938 }}}
    2939
    2940 3. ST_Histogram(rastertable text, rastercolumn text, nband int, bins int, width double precision[] DEFAULT NULL, right boolean DEFAULT FALSE) -> set of records
    2941
    2942 {{{
    2943 ST_Histogram('ndvi_2010', 'rast', 1, 5)
    2944
    2945 ST_Histogram('ndvi_2010', 'rast', 1, 0, ARRAY[0.5]::double precision[])
    2946
    2947 ST_Histogram('ndvi_2010', 'rast', 1, 5, NULL, TRUE)
    2948 }}}
    2949
    2950 4. ST_Histogram(rastertable text, rastercolumn text, nband int, bins int, right boolean) -> set of records
    2951
    2952 {{{
    2953 ST_Histogram('veg_2009', 'rast', 2, 3, FALSE)
    2954
    2955 ST_Histogram('veg_2009', 'rast', 2, 3, TRUE)
    2956 }}}
    2957
    2958 A set of functions of ST_ApproxHistogram for coverage tables:
    2959
    2960 1. ST_ApproxHistogram(rastertable text, rastercolumn text, nband int DEFAULT 1, exclude_nodata_value boolean DEFAULT TRUE, sample_percent double precision DEFAULT 0.1, bins int DEFAULT 0, width double precision[] DEFAULT NULL, right boolean DEFAULT FALSE) -> set of records
    2961
    2962 {{{
    2963 ST_ApproxHistogram('precip_2010', 'rast')
    2964
    2965 ST_ApproxHistogram('precip_2010', 'rast', 1)
    2966
    2967 ST_ApproxHistogram('precip_2010', 'rast', 2, FALSE)
    2968
    2969 ST_ApproxHistogram('precip_2010', 'rast', 1, TRUE, 0.25)
    2970
    2971 ST_ApproxHistogram('precip_2010', 'rast', 3, FALSE, 0.2, 10)
    2972
    2973 ST_ApproxHistogram('precip_2010', 'rast', 1, TRUE, 0.1, 0, ARRAY[1]::double precision[])
    2974
    2975 ST_ApproxHistogram('precip_2010', 'rast', 1, TRUE, 0.1, 0, ARRAY[1]::double precision[], FALSE)
    2976 }}}
    2977
    2978 2. ST_ApproxHistogram(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean, sample_percent double precision, bins int, right boolean)
    2979
    2980 3. ST_ApproxHistogram(rastertable text, rastercolumn text, nband int, sample_percent double precision)
    2981
    2982 4. ST_ApproxHistogram(rastertable text, rastercolumn text, sample_percent double precision)
    2983
    2984 5. ST_ApproxHistogram(rastertable text, rastercolumn text, nband int, sample_percent double precision, bins int, width double precision[] DEFAULT NULL, right boolean DEFAULT FALSE)
    2985
    2986 6. ST_ApproxHistogram(rastertable text, rastercolumn text, nband int, sample_percent double precision, bins int, right boolean)
    2987
    2988 ----
    2989 '''ST_Quantile(raster, nband) -> set of records'''[[BR]]
    2990 In addition to determining the histogram of a raster, providing the ability to compute quantiles permits a user to reference a value in the context of the sample or population. Thus, a value could be examined to be at the raster's 25%, 50%, 75% percentile.
    2991
    2992 http://en.wikipedia.org/wiki/Quantile
    2993
    2994 ST_Quantile variations:
    2995
    2996 1. ST_Quantile(rast raster, nband int, exclude_nodata_value boolean, quantiles double precision[]) -> set of records
    2997
    2998   each row returned is of (quantile double precision, value double precision)
    2999
    3000   nband: index of band to process on
    3001
    3002   exclude_nodata_value: if FALSE, nodata values in band are included. if TRUE, nodata values are not included.
    3003
    3004   quantiles: array of percentages to compute values for
    3005
    3006 {{{
    3007 ST_Quantile(rast, 1, FALSE, ARRAY[0.1, 0.3, 0.7])
    3008
    3009 ST_Quantile(rast, 1, TRUE, ARRAY[0.2])
    3010
    3011 ST_Quantile(rast, 1, FALSE, ARRAY[0, 1])
    3012 }}}
    3013
    3014 2. ST_Quantile(rast raster, nband int, quantiles double precision[]) -> set of records
    3015
    3016   "exclude_nodata_value" is assumed to be TRUE
    3017
    3018 {{{
    3019 ST_Quantile(rast, 1, ARRAY[0.1, 0.3, 0.7])
    3020 }}}
    3021
    3022 3. ST_Quantile(rast raster, nband int, exclude_nodata_value boolean) -> set of records
    3023
    3024   "quantiles" assumed to be ARRAY[0, 0.25, 0.5, 0.75, 1]
    3025
    3026 4. ST_Quantile(rast raster, nband int) -> set of records
    3027
    3028   "exclude_nodata_value" is assumed to be TRUE and "quantiles" assumed to be ARRAY[0, 0.25, 0.5, 0.75, 1]
    3029
    3030 5. ST_Quantile(rast raster, quantiles double precision[]) -> set of records
    3031
    3032   "nband" is assumed to be 1 and "exclude_nodata_value" is TRUE
    3033
    3034 6. ST_Quantile(rast raster) -> set of records
    3035
    3036   "nband" is assumed to be 1 and "quantiles" assumed to be ARRAY[0, 0.25, 0.5, 0.75, 1]
    3037
    3038 7. ST_Quantile(rast raster, nband int, exclude_nodata_value boolean, quantile double precision) -> record
    3039
    3040   quantile: the single percentile to compute
    3041
    3042 8. ST_Quantile(rast raster, nband int, quantile double precision) -> record
    3043
    3044   "exclude_nodata_value" is assumed to be TRUE
    3045
    3046 9. ST_Quantile(rast raster, exclude_nodata_value boolean, quantile double precision) -> record
    3047
    3048   "nband" is assumed to be 1
    3049
    3050 10. ST_Quantile(rast raster, quantile double precision) -> record
    3051
    3052   "nband" is assumed to be 1  and "exclude_nodata_value" is assumed to be TRUE
    3053
    3054 ST_ApproxQuantile adds a "sample_percent" indicating the percentage of the raster to sample
    3055
    3056 1. ST_ApproxQuantile(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision, quantiles double precision[]) -> set of records
    3057
    3058   nband: index of band to process on
    3059
    3060   exclude_nodata_value: if FALSE, nodata values in band are included. if TRUE, nodata values are not included.
    3061
    3062   sample_percent: a value between 0 and 1 indicating the percentage of the raster band's pixels to consider when computing the quantiles
    3063
    3064   quantiles: array of percentages to compute values for
    3065
    3066 {{{
    3067 ST_ApproxQuantile(rast, 1, FALSE, 0.1, ARRAY[0.1, 0.3, 0.7])
    3068
    3069 ST_ApproxQuantile(rast, 1, TRUE, .2, ARRAY[0.2])
    3070
    3071 ST_ApproxQuantile(rast, 1, FALSE, 0.3, ARRAY[0, 1])
    3072 }}}
    3073
    3074 2. ST_ApproxQuantile(rast raster, nband int, sample_percent double precision, quantiles double precision[]) -> set of records
    3075
    3076   "exclude_nodata_value" is assumed to be TRUE
    3077
    3078 {{{
    3079 ST_ApproxQuantile(rast, 1, .05, ARRAY[0.1, 0.3, 0.7])
    3080 }}}
    3081
    3082 3. ST_ApproxQuantile(rast raster, nband int, sample_percent double precision) -> set of records
    3083
    3084   "exclude_nodata_value" is assumed to be TRUE and "quantiles" assumed to be ARRAY[0, 0.25, 0.5, 0.75, 1]
    3085
    3086 4. ST_ApproxQuantile(rast raster, sample_percent double precision, quantiles double precision[]) -> set of records
    3087
    3088   "nband" is assumed to be 1
    3089
    3090 5. ST_ApproxQuantile(rast raster, nband int, sample_percent double precision, quantile double precision) -> record
    3091
    3092   quantile: the single percentile to compute
    3093
    3094 6. ST_ApproxQuantile(rast raster, sample_percent double precision, quantile double precision) -> record
    3095
    3096   "nband" is assumed to be 2
    3097
    3098 7. ST_ApproxQuantile(rast raster, sample_percent double precision) -> set of records
    3099
    3100   "nband" is assumed to be 1 and "quantiles" assumed to be ARRAY[0, 0.25, 0.5, 0.75, 1]
    3101
    3102 8. ST_ApproxQuantile(rast raster, nband int, quantile double precision) -> record
    3103
    3104   "sample_percent" assumed to be 0.1
    3105
    3106 9. ST_ApproxQuantile(rast raster, quantiles double precision[]) -> set of records
    3107
    3108   "nband" is assumed to be 1 and "sample_percent" assumed to be 0.1
    3109
    3110 10. ST_ApproxQuantile(rast raster, quantile double precision) -> record
    3111
    3112   "nband" assumed to be 1 and "sample_percent" assumed to be 0.1
    3113
    3114 11. ST_ApproxQuantile(rast raster, nband int) -> set of records
    3115
    3116   "quantiles" assumed to be ARRAY[0, 0.25, 0.5, 0.75, 1] and "sample_percent" assumed to be 0.1
    3117
    3118 12. ST_ApproxQuantile(rast raster) -> set of records
    3119
    3120   "nband" is assumed to be 1, "quantiles" assumed to be ARRAY[0, 0.25, 0.5, 0.75, 1] and "sample_percent" assumed to be 0.1
    3121
    3122 ----
    3123 == '''Objective FV.03 - Implement all the necessary versions of ST_MapAlgebra''' ==
    3124
    3125 '''ST_SameAlignment(raster, raster) -> boolean'''
    3126
    3127 This function returns true if both rasters' grids are aligned.
    3128
    3129 Two rasters grid are aligned if:
    3130
    3131 * They share the same pixel scales and skews
    3132
    3133 * At least one of any of the four corner of any pixel of one raster fall on any corner of the grid of the other raster.
    3134
    3135 Alignment is not the same concept as georeference. Two rasters can be aligned but not have the same georeference.
    3136
    3137 Rotation is important here since two rasters grid might look perfectly aligned but are not if their rotated are different.
    3138
    3139 Knowing if two rasters share the same alignment is useful when it is time to decide if one of them must be resampled before doing other operations (like ST_MapAlgebra on two rasters).
    3140
    3141 The variants of ST_SameAlignment are:
    3142
    3143 1. ST_SameAlignment(rast1 raster, rast2 raster)
    3144
    3145 2. ST_SameAlignment(ulx1, uly1, scalex1, scaley1, skewx1, skewy1, ulx2, uly2, scalex2, scaley2, skewx2, skewy2)
    3146
    3147 ~~The first variant is useful to PL/pgSQL function which have already get the values of the parameters.
    3148
    3149 ~~'''Implementation Details'''
    3150
    3151 ~~Only the first variant should be implemented in C. The second one is a PL/pgSQL variants. The C implementation should follow the PL/pgSQL version implemented in http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql/st_mapalgebra.sql
    3152
    3153 ~~It is not clear if this PL/pgSQL implementation works when raster are rotated. To verify.
    3154
    3155 ~~See discussion in http://trac.osgeo.org/postgis/ticket/589
    3156
    3157 ~~Bborie:
    3158
    3159 ~~The variant that should be developed in C is (2) as it is more likely that someone will have two rasters instead of that large set of raster elements.  Instead, (1) should be a pl/pgsql function calling (2).
    3160
    3161 ----
    3162 == '''Objective FV.05 - Being able to reproject a raster. - ''Done''''' ==
    3163
    3164
    3165 '''ST_Transform(raster|geometry, SRID) -> same type as input'''
    3166
    3167 ST_Transform enables the end-user to reproject a raster to a new projection.  Unlike the ST_Transform function for geometries, ST_Transform for rasters depends upon the specificiation of a resampling algorithm and an error tolerance.  In addition, reprojecting a raster will probably change the scale of the pixels.  Therefore, ST_Transform for rasters can be more involved than the ST_Transform for geometries.
    3168
    3169 ''If a skewed raster is provided to ST_Transform, the output raster will be deskewed (zero skew in X and Y axes thus "north up").  To preserve the skew, use ST_Resample.''
    3170
    3171 1. ST_Transform(rast raster, srid integer, algorithm text DEFAULT '!NearestNeighbour', maxerr double precision DEFAULT 0.125, scalex double precision DEFAULT 0, scaley double precision DEFAULT 0)
    3172
    3173   returns a new raster in the projection specified by "srid"
    3174
    3175   srid: the SRID of the projection to use when reprojecting the raster
    3176
    3177   algorithm: the resampling algorithm to use when reprojecting the raster.  default is '!NearestNeighbour'.  possible algorithms are:
    3178
    3179 {{{
    3180 NearestNeighbour (default.  fastest performance but worst interpolation)
    3181
    3182 NearestNeighbor (for those wanting to use the American spelling)
    3183
    3184 Bilinear
    3185
    3186 Cubic
    3187
    3188 CubicSpline
    3189
    3190 Lanczos
    3191 }}}
    3192
    3193   maxerr: the threshold for transformation approximation by the resampling algorithm (in pixel units).  default is 0.125, which is the same value used in GDAL gdalwarp utility.  if set to zero, no approximation takes place.
    3194
    3195   scalex: the reprojected raster's scale in the X axis.  default is 0 indicating that the user isn't specifying the reprojected raster's scale
    3196
    3197   scaley: the reprojected raster's scale in the Y axis.  default is 0 indicating that the user isn't specifying the reprojected raster's scale
    3198
    3199 {{{
    3200 ST_Transform(rast, 3310)
    3201
    3202 ST_Transform(rast, 3310, 'Bilinear')
    3203
    3204 ST_Transform(rast, 3310, 'Lanczos', 0)
    3205
    3206 ST_Transform(rast, 3310, 'Lanczos', 0.5)
    3207
    3208 ST_Transform(rast, 3310, 'Lanczos', 0.125, 1000)
    3209
    3210 ST_Transform(rast, 3310, 'Lanczos', 0.125, 1000, 1000)
    3211 }}}
    3212
    3213 2. ST_Transform(rast raster, srid integer, scalex double precision, scaley double precision, algorithm text DEFAULT '!NearestNeighbour', maxerr double precision DEFAULT 0.125)
    3214
    3215 {{{
    3216 ST_Transform(rast, 4326, 500, 500)
    3217
    3218 ST_Transform(rast, 4326, 500, 500, 'Cubic')
    3219
    3220 ST_Transform(rast, 4326, 500, 500, 'CubicSpline', 0)
    3221 }}}
    3222
    3223 3. ST_Transform(rast raster, srid integer, scalexy double precision, algorithm text DEFAULT '!NearestNeighbour', maxerr double precision DEFAULT 0.125)
    3224
    3225   scalexy: the reprojected raster's scale in the X and Y axes.  default is 0 indicating that the user isn't specifying the reprojected raster's scale
    3226
    3227 {{{
    3228 ST_Transform(rast, 4326, 250)
    3229
    3230 ST_Transform(rast, 4326, 250, 'Cubic')
    3231
    3232 ST_Transform(rast, 4326, 100, 'CubicSpline', 0)
    3233 }}}
    3234
    3235 ----
    3236 == '''Objective FV.06 - Being able to do some base raster operations. - ''Done Partially''''' ==
    3237
    3238
    3239 '''ST_ValueCount(raster, value) -> integer'''[[BR]]
    3240
    3241 ST_ValueCount provides the ability to count the number of times that a user-provided value is present in a raster. To handle floating point values, a rounding argument is provided.
    3242
    3243 A set of functions for one or more search values:
    3244
    3245 ''If NULL is passed for "searchvalues" to any of the ST_ValueCount variations with "searchvalues", the function returns the counts for all unique values''
    3246
    3247 1. ST_ValueCount(rast raster, nband integer, exclude_nodata_value boolean, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, count)
    3248
    3249     returns the number of times that each value in searchvalues is present in the raster
    3250
    3251     exclude_nodata_value: if FALSE, nodata values in band are considered in the count. if TRUE, nodata values are not considered
    3252
    3253     searchvalues: the set of values to count in the raster
    3254
    3255     roundto: the decimal position to round a pixel value to. Originally intended for use with 32BF and 64BF pixel types, it can also be used with integers when round to the tens, hundreds or higher place.
    3256
    3257         examples are...
    3258
    3259 {{{
    3260         roundto < 0: no rounding
    3261
    3262         0: no rounding
    3263
    3264         0.1: round to the tenths place
    3265
    3266         0.01: round to the hundredths place
    3267
    3268         0.001: round to the thousandths place
    3269
    3270         1: round to the ones place
    3271
    3272         10: round to the tens place
    3273
    3274         100: round to the hundreds place
    3275 }}}
    3276
    3277 {{{
    3278 ST_ValueCount(rast, 1, TRUE, ARRAY[23], 0)
    3279
    3280 ST_ValueCount(rast, 5, FALSE, ARRAY[3.14], 0.01)
    3281
    3282 ST_ValueCount(rast, 2, TRUE, ARRAY[100], 100)
    3283
    3284 ST_ValueCount(rast, 1, FALSE, ARRAY[-9999, 0], 1)
    3285
    3286 ST_ValueCount(rast, 1, FALSE, NULL::double precision[], 1)
    3287 }}}
    3288
    3289 2. ST_ValueCount(rast raster, nband integer, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, count)
    3290
    3291     exclude_nodata_value is assumed to be TRUE
    3292
    3293 {{{
    3294 ST_ValueCount(rast, 5, ARRAY[3.14], 0.01)
    3295
    3296 ST_ValueCount(rast, 2, NULL::double precision[], 100)
    3297 }}}
    3298
    3299 3. ST_ValueCount(rast raster, nband integer, searchvalues double precision[]) -> setof record (searchvalue, count)
    3300
    3301     roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE
    3302
    3303 {{{
    3304 ST_ValueCount(rast, 1, ARRAY[-9999])
    3305
    3306 ST_ValueCount(rast, 1, NULL::double precision[])
    3307 }}}
    3308
    3309 4. ST_ValueCount(rast raster, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, count)
    3310
    3311     nband is assumed to be 1. exclude_nodata_value is assumed to be TRUE.
    3312
    3313 5. ST_ValueCount(rast raster, searchvalues double precision[]) -> setof record (searchvalue, count)
    3314
    3315     nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
    3316
    3317 A set of functions for a single search value:
    3318
    3319 1. ST_ValueCount(rast raster, nband integer, exclude_nodata_value boolean, searchvalue double precision, roundto double precision) -> integer
    3320
    3321     returns the number of times that searchvalue is present in the raster
    3322
    3323     searchvalue: the value to count in the raster
    3324
    3325 {{{
    3326 ST_ValueCount(rast, 1, TRUE, 23, 0)
    3327
    3328 ST_ValueCount(rast, 5, FALSE, 3.14, 0.01)
    3329
    3330 ST_ValueCount(rast, 2, TRUE, 100, 100)
    3331
    3332 ST_ValueCount(rast, 1, FALSE, -9999, 1)
    3333 }}}
    3334
    3335 2. ST_ValueCount(rast raster, nband integer, searchvalue double precision, roundto double precision) -> integer
    3336
    3337     exclude_nodata_value is assumed to be TRUE
    3338
    3339 {{{
    3340 ST_ValueCount(rast, 5, 3.14, 0.01)
    3341
    3342 ST_ValueCount(rast, 2, 100, 100)
    3343 }}}
    3344
    3345 3. ST_ValueCount(rast raster, nband integer, searchvalue double precision) -> integer
    3346
    3347     roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE
    3348
    3349 {{{
    3350 ST_ValueCount(rast, 1, -9999)
    3351 }}}
    3352
    3353 4. ST_ValueCount(rast raster, searchvalue double precision, roundto double precision) -> integer
    3354
    3355     nband is assumed to be 1. exclude_nodata_value is assumed to be TRUE.
    3356
    3357 5. ST_ValueCount(rast raster, searchvalue double precision) -> integer
    3358
    3359     nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
    3360
    3361 The set of functions for processing coverages return "bigint" instead of "integer".
    3362
    3363 A set of functions for one or more search values:
    3364
    3365 1. ST_ValueCount(rastertable text, rastercolumn text, nband integer, exclude_nodata_value boolean, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, count)
    3366
    3367     rastertable: name of the table with a raster column
    3368
    3369     rastercolumn: name of the raster column
    3370
    3371 {{{
    3372 ST_ValueCount('test', 'rast', 1, TRUE, ARRAY[23], 0)
    3373
    3374 ST_ValueCount('test', 'rast', 5, FALSE, ARRAY[3.14], 0.01)
    3375
    3376 ST_ValueCount('test', 'rast', 2, TRUE, ARRAY[100], 100)
    3377
    3378 ST_ValueCount('test', 'rast', 1, FALSE, ARRAY[-9999, 0], 1)
    3379
    3380 ST_ValueCount('test', 'rast', 1, FALSE, NULL::double precision[], 1)
    3381 }}}
    3382
    3383 2. ST_ValueCount(rastertable text, rastercolumn text, nband integer, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, count)
    3384
    3385     exclude_nodata_value is assumed to be TRUE
    3386
    3387 {{{
    3388 ST_ValueCount('test', 'rast', 5, ARRAY[3.14], 0.01)
    3389
    3390 ST_ValueCount('test', 'rast', 2, NULL::double precision[], 100)
    3391 }}}
    3392
    3393 3. ST_ValueCount(rastertable text, rastercolumn text, nband integer, searchvalues double precision[]) -> setof record (searchvalue, count)
    3394
    3395     roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE
    3396
    3397 {{{
    3398 ST_ValueCount('test', 'rast', 1, ARRAY[-9999])
    3399
    3400 ST_ValueCount('test', 'rast', 1, NULL::double precision[])
    3401 }}}
    3402
    3403 4. ST_ValueCount(rastertable text, rastercolumn text, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, count)
    3404
    3405     nband is assumed to be 1. exclude_nodata_value is assumed to be TRUE.
    3406
    3407 5. ST_ValueCount(rastertable text, rastercolumn text, searchvalues double precision[]) -> setof record (searchvalue, count)
    3408
    3409     nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
    3410
    3411 A set of functions for a single search value:
    3412
    3413 1. ST_ValueCount(rastertable text, rastercolumn text, nband integer, exclude_nodata_value boolean, searchvalue double precision, roundto double precision) -> bigint
    3414
    3415     searchvalue: the value to count in the raster
    3416
    3417 {{{
    3418 ST_ValueCount('test', 'rast', 1, TRUE, 23, 0)
    3419
    3420 ST_ValueCount('test', 'rast', 5, FALSE, 3.14, 0.01)
    3421
    3422 ST_ValueCount('test', 'rast', 2, TRUE, 100, 100)
    3423
    3424 ST_ValueCount('test', 'rast', 1, FALSE, -9999, 1)
    3425 }}}
    3426
    3427 2. ST_ValueCount(rastertable text, rastercolumn text, nband integer, searchvalue double precision, roundto double precision) -> bigint
    3428
    3429     exclude_nodata_value is assumed to be TRUE
    3430
    3431 {{{
    3432 ST_ValueCount('test', 'rast', 5, 3.14, 0.01)
    3433
    3434 ST_ValueCount('test', 'rast', 2, 100, 100)
    3435 }}}
    3436
    3437 3. ST_ValueCount(rastertable text, rastercolumn text, nband integer, searchvalue double precision) -> bigint
    3438
    3439     roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE
    3440
    3441 {{{
    3442 ST_ValueCount('test', 'rast', 1, -9999)
    3443 }}}
    3444
    3445 4. ST_ValueCount(rastertable text, rastercolumn text, searchvalue double precision, roundto double precision) -> bigint
    3446
    3447     nband is assumed to be 1. exclude_nodata_value is assumed to be TRUE.
    3448
    3449 5. ST_ValueCount(rastertable text, rastercolumn text, searchvalue double precision) -> bigint
    3450
    3451     nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
    3452
    3453 ----
    3454
    3455 '''ST_ValuePercent(raster, value) -> double precision'''[[BR]]
    3456
    3457 ST_ValuePercent is the sibling of ST_ValueCount and returns the percentage of a raster's band that is of a specified value. To handle floating point values, a rounding argument is provided.
    3458
    3459 A set of functions for one or more search values:
    3460
    3461 ''If NULL is passed for "searchvalues" to any of the ST_ValuePercent variations with "searchvalues", the function returns the percents for all unique values''
    3462
    3463 1. ST_ValuePercent(rast raster, nband integer, exclude_nodata_value boolean, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, percent)
    3464
    3465     returns the percentage of a raster's band that each value in searchvalues is found
    3466
    3467     exclude_nodata_value: if FALSE, nodata values in band are considered in the percents. if TRUE, nodata values are not considered
    3468
    3469     searchvalues: the set of values to get percents for in the raster
    3470
    3471     roundto: the decimal position to round a pixel value to. Originally intended for use with 32BF and 64BF pixel types, it can also be used with integers when round to the tens, hundreds or higher place.
    3472
    3473         examples are...
    3474
    3475 {{{
    3476         roundto < 0: no rounding
    3477
    3478         0: no rounding
    3479
    3480         0.1: round to the tenths place
    3481
    3482         0.01: round to the hundredths place
    3483
    3484         0.001: round to the thousandths place
    3485
    3486         1: round to the ones place
    3487
    3488         10: round to the tens place
    3489
    3490         100: round to the hundreds place
    3491 }}}
    3492
    3493 {{{
    3494 ST_ValuePercent(rast, 1, TRUE, ARRAY[23], 0)
    3495
    3496 ST_ValuePercent(rast, 5, FALSE, ARRAY[3.14], 0.01)
    3497
    3498 ST_ValuePercent(rast, 2, TRUE, ARRAY[100], 100)
    3499
    3500 ST_ValuePercent(rast, 1, FALSE, ARRAY[-9999, 0], 1)
    3501
    3502 ST_ValuePercent(rast, 1, FALSE, NULL::double precision[], 1)
    3503 }}}
    3504
    3505 2. ST_ValuePercent(rast raster, nband integer, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, percent)
    3506
    3507     exclude_nodata_value is assumed to be TRUE
    3508
    3509 {{{
    3510 ST_ValuePercent(rast, 5, ARRAY[3.14], 0.01)
    3511
    3512 ST_ValuePercent(rast, 2, NULL::double precision[], 100)
    3513 }}}
    3514
    3515 3. ST_ValuePercent(rast raster, nband integer, searchvalues double precision[]) -> setof record (searchvalue, percent)
    3516
    3517     roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE
    3518
    3519 {{{
    3520 ST_ValuePercent(rast, 1, ARRAY[-9999])
    3521
    3522 ST_ValuePercent(rast, 1, NULL::double precision[])
    3523 }}}
    3524
    3525 4. ST_ValuePercent(rast raster, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, percent)
    3526
    3527     nband is assumed to be 1. exclude_nodata_value is assumed to be TRUE.
    3528
    3529 5. ST_ValuePercent(rast raster, searchvalues double precision[]) -> setof record (searchvalue, percent)
    3530
    3531     nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
    3532
    3533 A set of functions for a single search value:
    3534
    3535 1. ST_ValuePercent(rast raster, nband integer, exclude_nodata_value boolean, searchvalue double precision, roundto double precision) -> integer
    3536
    3537     searchvalue: the value to get a percent for in the raster
    3538
    3539 {{{
    3540 ST_ValuePercent(rast, 1, TRUE, 23, 0)
    3541
    3542 ST_ValuePercent(rast, 5, FALSE, 3.14, 0.01)
    3543
    3544 ST_ValuePercent(rast, 2, TRUE, 100, 100)
    3545
    3546 ST_ValuePercent(rast, 1, FALSE, -9999, 1)
    3547 }}}
    3548
    3549 2. ST_ValuePercent(rast raster, nband integer, searchvalue double precision, roundto double precision) -> integer
    3550
    3551     exclude_nodata_value is assumed to be TRUE
    3552
    3553 {{{
    3554 ST_ValuePercent(rast, 5, 3.14, 0.01)
    3555
    3556 ST_ValuePercent(rast, 2, 100, 100)
    3557 }}}
    3558
    3559 3. ST_ValuePercent(rast raster, nband integer, searchvalue double precision) -> integer
    3560
    3561     roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE
    3562
    3563 {{{
    3564 ST_ValuePercent(rast, 1, -9999)
    3565 }}}
    3566
    3567 4. ST_ValuePercent(rast raster, searchvalue double precision, roundto double precision) -> integer
    3568
    3569     nband is assumed to be 1. exclude_nodata_value is assumed to be TRUE.
    3570
    3571 5. ST_ValuePercent(rast raster, searchvalue double precision) -> integer
    3572
    3573     nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
    3574
    3575 The set of functions for processing coverages return "bigint" instead of "integer".
    3576
    3577 A set of functions for one or more search values:
    3578
    3579 1. ST_ValuePercent(rastertable text, rastercolumn text, nband integer, exclude_nodata_value boolean, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, percent)
    3580
    3581     rastertable: name of the table with a raster column
    3582
    3583     rastercolumn: name of the raster column
    3584
    3585 {{{
    3586 ST_ValuePercent('test', 'rast', 1, TRUE, ARRAY[23], 0)
    3587
    3588 ST_ValuePercent('test', 'rast', 5, FALSE, ARRAY[3.14], 0.01)
    3589
    3590 ST_ValuePercent('test', 'rast', 2, TRUE, ARRAY[100], 100)
    3591
    3592 ST_ValuePercent('test', 'rast', 1, FALSE, ARRAY[-9999, 0], 1)
    3593
    3594 ST_ValuePercent('test', 'rast', 1, FALSE, NULL::double precision[], 1)
    3595 }}}
    3596
    3597 2. ST_ValuePercent(rastertable text, rastercolumn text, nband integer, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, percent)
    3598
    3599     exclude_nodata_value is assumed to be TRUE
    3600
    3601 {{{
    3602 ST_ValuePercent('test', 'rast', 5, ARRAY[3.14], 0.01)
    3603
    3604 ST_ValuePercent('test', 'rast', 2, NULL::double precision[], 100)
    3605 }}}
    3606
    3607 3. ST_ValuePercent(rastertable text, rastercolumn text, nband integer, searchvalues double precision[]) -> setof record (searchvalue, percent)
    3608
    3609     roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE
    3610
    3611 {{{
    3612 ST_ValuePercent('test', 'rast', 1, ARRAY[-9999])
    3613
    3614 ST_ValuePercent('test', 'rast', 1, NULL::double precision[])
    3615 }}}
    3616
    3617 4. ST_ValuePercent(rastertable text, rastercolumn text, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, percent)
    3618
    3619     nband is assumed to be 1. exclude_nodata_value is assumed to be TRUE.
    3620
    3621 5. ST_ValuePercent(rastertable text, rastercolumn text, searchvalues double precision[]) -> setof record (searchvalue, percent)
    3622
    3623     nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
    3624
    3625 A set of functions for a single search value:
    3626
    3627 1. ST_ValuePercent(rastertable text, rastercolumn text, nband integer, exclude_nodata_value boolean, searchvalue double precision, roundto double precision) -> bigint
    3628
    3629     searchvalue: the value to get a percent for in the raster
    3630
    3631 {{{
    3632 ST_ValuePercent('test', 'rast', 1, TRUE, 23, 0)
    3633
    3634 ST_ValuePercent('test', 'rast', 5, FALSE, 3.14, 0.01)
    3635
    3636 ST_ValuePercent('test', 'rast', 2, TRUE, 100, 100)
    3637
    3638 ST_ValuePercent('test', 'rast', 1, FALSE, -9999, 1)
    3639 }}}
    3640
    3641 2. ST_ValuePercent(rastertable text, rastercolumn text, nband integer, searchvalue double precision, roundto double precision) -> bigint
    3642
    3643     exclude_nodata_value is assumed to be TRUE
    3644
    3645 {{{
    3646 ST_ValuePercent('test', 'rast', 5, 3.14, 0.01)
    3647
    3648 ST_ValuePercent('test', 'rast', 2, 100, 100)
    3649 }}}
    3650
    3651 3. ST_ValuePercent(rastertable text, rastercolumn text, nband integer, searchvalue double precision) -> bigint
    3652
    3653     roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE
    3654
    3655 {{{
    3656 ST_ValuePercent('test', 'rast', 1, -9999)
    3657 }}}
    3658
    3659 4. ST_ValuePercent(rastertable text, rastercolumn text, searchvalue double precision, roundto double precision) -> bigint
    3660
    3661     nband is assumed to be 1. exclude_nodata_value is assumed to be TRUE.
    3662
    3663 5. ST_ValuePercent(rastertable text, rastercolumn text, searchvalue double precision) -> bigint
    3664
    3665     nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
    3666
    3667 ----
    3668
    3669 '''ST_Resample(raster, method, originx, originy, pixelsizex, pixelsizey) -> raster'''
    3670
    3671 ST_Resample is the main function underlying the ST_Transform, ST_Rescale, ST_Reskew and ST_SnapToGrid functions.  ST_Resample provides the ability to change a raster's projection, adjust the scale of the raster within its extent, change the skew (or deskew) and "dissolve" the raster to a grid.
    3672
    3673 ''If a skewed raster is provided to ST_Resample and skewx and/or skewy are not provided, the output raster will be deskewed (zero skew in X and Y axes thus "north up")''
    3674
    3675 1. ST_Resample(
    3676         rast raster,
    3677         srid integer DEFAULT NULL,
    3678         scalex double precision DEFAULT 0, scaley double precision DEFAULT 0,
    3679         gridx double precision DEFAULT NULL, gridy double precision DEFAULT NULL,
    3680         skewx double precision DEFAULT 0, skewy double precision DEFAULT 0,
    3681         algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125
    3682 ) -> raster
    3683
    3684   srid: the SRID that the function will use to reproject the raster to.  If NULL, the raster's SRID will be used.
    3685
    3686   scalex: the scale/pixel size in the X axis of the resampled raster.  If scalex and scaley are zero (0), the resampled raster's scale will be autocomputed.  If provided, scaley must also be provided.
    3687
    3688   scaley: the scale/pixel size in the Y axis of the resampled raster.  If scalex and scaley are zero (0), the resampled raster's scale will be autocomputed.  If provided, scalex must also be provided.
    3689
    3690   gridx: the X coordinate of a point on the grid to which the raster will be aligned.  Value is in the resampled raster's world coordinates.  If provided, gridy must also be provided.
    3691
    3692   gridy: the Y coordinate of a point on the grid to which the raster will be aligned.  Value is in the resampled raster's world coordinates.  If provided, gridx must also be provided.
    3693
    3694   skewx: the skew along the X axis of the resampled raster.  If skewx and skewy are zero (0), the resampled raster will be "north up".
    3695
    3696   skewy: the skew along the Y axis of the resampled raster.  If skewx and skewy are zero (0), the resampled raster will be "north up".
    3697
    3698   algorithm: the algorithm to use when resampling the raster. default is 'NearestNeighbour'. possible algorithms are:
    3699
    3700 {{{
    3701 NearestNeighbour (default.  fastest performance but worst interpolation)
    3702
    3703 NearestNeighbor (for those wanting to use the American spelling)
    3704
    3705 Bilinear
    3706
    3707 Cubic
    3708
    3709 CubicSpline
    3710
    3711 Lanczos
    3712 }}}
    3713
    3714   maxerr: the threshold for approximation by the resampling algorithm (in pixel units). default is 0.125, which is the same value used in GDAL gdalwarp utility. if set to zero, no approximation takes place.
    3715
    3716 2. ST_Resample(
    3717         rast raster,
    3718         ref raster,
    3719         algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125
    3720 ) -> raster
    3721
    3722   ref: the reference raster to which rast will copy the scalex, scaley, skewx, skewy and srid.  In addition, the upperleft corner of ref will be used as a grid point to align rast.
    3723
    3724 ----
    3725
    3726 '''ST_Rescale(raster, scalex, scaley) -> raster'''
    3727
    3728 ST_Rescale is a focused function of ST_Resample for changing the X and Y scale without affecting the extent of the raster.
    3729
    3730 ''If a skewed raster is provided to ST_Rescale, the output raster will be deskewed (zero skew in X and Y axes thus "north up").  To preserve the skew, use ST_Resample.''
    3731
    3732 1. ST_Rescale(rast raster, scalex double precision, scaley double precision, algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125) -> raster
    3733
    3734   scalex: the scale/pixel size in the X axis of the resampled raster
    3735
    3736   scaley: the scale/pixel size in the Y axis of the resampled raster
    3737
    3738 2. ST_Rescale(rast raster, scalexy double precision, algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125) -> raster
    3739
    3740   scalexy: the scale/pixel size in the X and Y axes of the resampled raster.
    3741
    3742 ----
    3743
    3744 '''ST_Reskew(raster, skewx, skewy) -> raster'''
    3745
    3746 ST_Reskew is a focused function of ST_Resample for changing the skew along the X and Y axes.
    3747
    3748 1. ST_Reskew(rast raster, skewx double precision, skewy double precision, algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125) -> raster
    3749
    3750   skewx: the skew along the X axis of the resampled raster.  If skewx and skewy are zero (0), the resampled raster will be "north up".
    3751
    3752   skewy: the skew along the Y axis of the resampled raster.  If skewx and skewy are zero (0), the resampled raster will be "north up".
    3753
    3754 2. ST_Reskew(rast raster, skewxy double precision, algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125) -> raster
    3755
    3756   skewxy: the skew along both X and Y axes of the resampled raster.  If skewxy is zero (0), the resampled raster will be "north up".
    3757
    3758 ----
    3759
    3760 '''ST_SnapToGrid(raster, gridx, gridy)'''
    3761
    3762 ST_SnapToGrid provides the ability to align a raster to grid (possibly that of a coverage).  The returned raster has its upper-left corner placed at the closest valid grid point to the source raster's upper-left corner without losing a data.  The same is done for the lower-right corner.
    3763
    3764 [[Image(snaptogrid.png)]]
    3765
    3766 ''If a skewed raster is provided to ST_SnapToGrid, the output raster will be deskewed (zero skew in X and Y axes thus "north up").  To preserve the skew, use ST_Resample.''
    3767
    3768 1. ST_SnapToGrid(
    3769         rast raster,
    3770         gridx double precision, gridy double precision,
    3771         algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125,
    3772         scalex double precision DEFAULT 0, scaley double precision DEFAULT 0
    3773 ) -> raster
    3774
    3775   gridx: the X coordinate of a point on the grid to which the raster will be aligned.  Value is in the raster's world coordinates.
    3776
    3777   gridy: the Y coordinate of a point on the grid to which the raster will be aligned.  Value is in the raster's world coordinates.
    3778
    3779   scalex: the scale/pixel size in the X axis of the resampled raster.  This is also the scale of the grid to which the raster is being "snapped".  If provided, scaley must be provided.  If scalex and scaley are zero, the input raster's scale will be used.
    3780
    3781   scaley: the scale/pixel size in the Y axis of the resampled raster.  This is also the scale of the grid to which the raster is being "snapped"  If provided, scalex must be provided.  If scalex and scaley are zero, the input raster's scale will be used.
    3782
    3783 2. ST_SnapToGrid(
    3784         rast raster,
    3785         gridx double precision, gridy double precision,
    3786         scalex double precision, scaley double precision,
    3787         algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125
    3788 ) -> raster
    3789
    3790 3. ST_SnapToGrid(
    3791         rast raster,
    3792         gridx double precision, gridy double precision,
    3793         scalexy double precision,
    3794         algorithm text DEFAULT 'NearestNeighbour', maxerr double precision DEFAULT 0.125
    3795 ) -> raster
    3796
    3797   scalexy: the scale/pixel size in the X and Y axes of the resampled raster.
    3798
    3799 ~~ * Implemented as a wrapper around GDAL like done for ST_DumpAsPolygons()~~
    3800 ~~ * Resampling methods are the same as the one priovided by GDAL~~
    3801
    3802 ~~ '''Variants'''~~
    3803
    3804 ~~ * The '''first series of variants''' only change the pixelsize of the raster.~~
    3805
    3806 ~~ 1) ST_Resample(raster, pixelsize) - modify pixelsize only and resample using the default method~~
    3807
    3808 ~~ 2) ST_Resample(raster, method, pixelsize) - modify pixelsize and resample using the specified method~~
    3809
    3810 ~~ 3) ST_Resample(raster, pixelsizex, pixelsizey) - modify pixelsize with different values for x and y using the default method~~
    3811
    3812 ~~ 4) ST_Resample(raster, method, pixelsizex, pixelsizey) - modify pixelsize with different values for x and y using the specified method~~
    3813
    3814 ~~ * The '''second series of variants''' realign the raster and change the pixelsize~~
    3815
    3816 ~~ 5) ST_Resample(raster, x, y, pixelsize) - realign and modify pixelsize using the default method~~
    3817
    3818 ~~ 6) ST_Resample(raster, method, x, y, pixelsize) - realign and modify pixelsize using the specified method~~
    3819
    3820 ~~ 7) ST_Resample(raster, x, y, pixelsizex, pixelsizey) - realign and modify pixelsize with different values for x and y using the default method~~
    3821
    3822 ~~ 8) ST_Resample(raster, method, x, y, pixelsizex, pixelsizey) - realign and modify pixelsize with different values for x and y using the specified method~~
    3823
    3824 ~~ 9) ST_Resample(raster, x, y, pixelsizex, pixelsizey, skewx, skewy) - realign and modify pixelsize and skew with different values for x and y using the default method~~
    3825
    3826 ~~ 10) ST_Resample(raster, method, x, y, pixelsizex, pixelsizey, skewx, skewy) - realign and modify pixelsize and skew with different values for x and y using the specified method~~
    3827
    3828 ~~ * The '''third series of variants''' align and resample the raster to match the alignment, pixelsize and skew of an existing raster.~~
    3829
    3830 ~~ 11) ST_Resample(destraster, sourceraster)~~
    3831
    3832 ~~ '''Questions'''~~
    3833
    3834 ~~ * Should there be a band parameter?~~
    3835
    3836 ~~ * How does GDAL allow resampling?~~
    3837
    3838 ~~ * Which methods GDAL supports? ArcGIS supports NEAREST | BILINEAR | CUBIC | MAJORITY~~
    3839
    3840 ~~ * Does GDAL support change in skew?~~
    3841
    3842 ----
    3843 == '''Objective FV.22 - Making raster_columns and raster_overview as views''' ==
    3844
    3845 raster_columns and raster_overviews are now constraint-based views.  The structure of the raster_columns views is below.
    3846
    3847 {{{
    3848 #!html
    3849 <TABLE BORDER=1>
    3850         <THEAD>
    3851                 <TR>
    3852                         <TD ALIGN=LEFT style="font-weight: bold; font-style: italic;">Column</TD>
    3853                         <TD ALIGN=LEFT style="font-weight: bold; font-style: italic;">PostgreSQL Type</TD>
    3854                         <TD ALIGN=LEFT style="font-weight: bold; font-style: italic;">Description</TD>
    3855                 </TR>
    3856         </THEAD>
    3857         <TBODY>
    3858                 <TR>
    3859                         <TD ALIGN=LEFT>r_table_catalog</TD>
    3860                         <TD ALIGN=LEFT>name</TD>
    3861                         <TD ALIGN=LEFT>Name of the database containing the table with the raster column.</TD>
    3862                 </TR>
    3863                 <TR>
    3864                         <TD ALIGN=LEFT>r_table_schema</TD>
    3865                         <TD ALIGN=LEFT>name</TD>
    3866                         <TD ALIGN=LEFT>Name of the schema containing the table with the raster column.</TD>
    3867                 </TR>
    3868                 <TR>
    3869                         <TD ALIGN=LEFT>r_table_name</TD>
    3870                         <TD ALIGN=LEFT>name</TD>
    3871                         <TD ALIGN=LEFT>Name of the table containing a column of type raster.</TD>
    3872                 </TR>
    3873                 <TR>
    3874                         <TD ALIGN=LEFT>r_raster_column</TD>
    3875                         <TD ALIGN=LEFT>name</TD>
    3876                         <TD ALIGN=LEFT>Name of the raster column in the table.  All attribute columns following this column apply to the rasters in this column.  <span style="font-style: italic; font-weight: bold;">This column was previously known as r_column.</span></TD>
    3877                 </TR>
    3878                 <TR>
    3879                         <TD ALIGN=LEFT>srid</TD>
    3880                         <TD ALIGN=LEFT>integer</TD>
    3881                         <TD ALIGN=LEFT>ID of the spatial reference system of the rasters in this column.  Value is extracted from the ST_SRID constraint on this raster column.  <span style="font-style: italic;">The constraint is typically named enforce_srid_&lt;r_raster_column&gt;.</span></TD>
    3882                 </TR>
    3883                 <TR>
    3884                         <TD ALIGN=LEFT>scale_x</TD>
    3885                         <TD ALIGN=LEFT>double precision</TD>
    3886                         <TD ALIGN=LEFT>The scale on the X-axis of the rasters in this column.  Value is extracted from the ST_ScaleX constraint on this raster column.  <span style="font-style: italic;">The constraint is typically named enforce_scalex_&lt;r_raster_column&gt;.</span></TD>
    3887                 </TR>
    3888                 <TR>
    3889                         <TD ALIGN=LEFT>scale_y</TD>
    3890                         <TD ALIGN=LEFT>double precision</TD>
    3891                         <TD ALIGN=LEFT>The scale on the Y-axis of the rasters in this column.  Value is extracted from the ST_ScaleY constraint on this raster column.  <span style="font-style: italic;">The constraint is typically named enforce_scaley_&lt;r_raster_column&gt;.</span></TD>
    3892                 </TR>
    3893                 <TR>
    3894                         <TD ALIGN=LEFT>blocksize_x</TD>
    3895                         <TD ALIGN=LEFT>integer</TD>
    3896                         <TD ALIGN=LEFT>The width of the rasters in this column.  Value is extracted from the ST_Width constraint on this raster column.  <span style="font-style: italic;">The constraint is typically named enforce_width_&lt;r_raster_column&gt;.</span></TD>
    3897                 </TR>
    3898                 <TR>
    3899                         <TD ALIGN=LEFT>blocksize_y</TD>
    3900                         <TD ALIGN=LEFT>integer</TD>
    3901                         <TD ALIGN=LEFT>The height of the rasters in this column.  Value is extracted from the ST_Height constraint on this raster column.  <span style="font-style: italic;">The constraint is typically named enforce_height_&lt;r_raster_column&gt;.</span></TD>
    3902                 </TR>
    3903                 <TR>
    3904                         <TD ALIGN=LEFT>same_alignment</TD>
    3905                         <TD ALIGN=LEFT>boolean</TD>
    3906                         <TD ALIGN=LEFT>If TRUE, all rasters in this column are aligned.  State is extracted from the ST_SameAlignment constraint comparing the rasters in this column against coordinates known to be on the grid.  <span style="font-style: italic;">The constraint is typically named enforce_same_alignment_&lt;r_raster_column&gt;.</span></TD>
    3907                 </TR>
    3908                 <TR>
    3909                         <TD ALIGN=LEFT>regular_blocking</TD>
    3910                         <TD ALIGN=LEFT>boolean</TD>
    3911                         <TD ALIGN=LEFT>If TRUE, all rasters in this column are regularly blocked.  <span style="color: red; font-weight: bold;">Though this column is technically based upon a constraint, the constraint is purely information and does NO actual constraining.  Therefore if this column is TRUE, a user explicitly specified that the rasters in this column are regularly blocked.</span>  <span style="font-style: italic;">The constraint is typically named enforce_regular_blocking_&lt;r_raster_column&gt;.</span></TD>
    3912                 </TR>
    3913                 <TR>
    3914                         <TD ALIGN=LEFT>num_bands</TD>
    3915                         <TD ALIGN=LEFT>integer</TD>
    3916                         <TD ALIGN=LEFT>The number bands within each raster of this column.  Value is extracted from the ST_NumBands constraint on this raster column.  <span style="font-style: italic;">The constraint is typically named enforce_num_bands_&lt; r_raster_column&gt;.</span></TD>
    3917                 </TR>
    3918                 <TR>
    3919                         <TD ALIGN=LEFT>pixel_types</TD>
    3920                         <TD ALIGN=LEFT>text[]</TD>
    3921                         <TD ALIGN=LEFT>Text array of the pixel types of the bands within each raster of this column.  Value is extracted from a special function that creates an array of the band pixel types of the rasters in this column.  <span style="font-style: italic;">The constraint is typically named enforce_pixel_types_&lt;r_raster_column&gt;.</span></TD>
    3922                 </TR>
    3923                 <TR>
    3924                         <TD ALIGN=LEFT>nodata_values</TD>
    3925                         <TD ALIGN=LEFT>double precision[]</TD>
    3926                         <TD ALIGN=LEFT>Double precision array of the NODATA values of the bands within each raster of this column.  Value is extracted from a special function that creates an array of the band NODATA values of the rasters in this column.  <span style="font-style: italic;">The constraint is typically named enforce_nodata_values_&lt;r_raster_column&gt;.</span></TD>
    3927                 </TR>
    3928                 <TR>
    3929                         <TD ALIGN=LEFT>out_db</TD>
    3930                         <TD ALIGN=LEFT>boolean[]</TD>
    3931                         <TD ALIGN=LEFT>Boolean array of the out-of-database flag of the bands within each raster of this column.  Value is extracted from a special function that creates an array of the band out-of-database flags of the rasters in this column.  <span style="font-style: italic;">The constraint is typically named enforce_out_db_&lt;r_raster_column&gt;.</span></TD>
    3932                 </TR>
    3933                 <TR>
    3934                         <TD ALIGN=LEFT>extent</TD>
    3935                         <TD ALIGN=LEFT>geometry</TD>
    3936                         <TD ALIGN=LEFT>The maximum extent within which all rasters of this column must be covered by.  The maximum extent is computed by ST_ConvexHull(ST_Collect(ST_ConvexHull(raster))) of all rasters in this column at the time that the extent constraint was added..  Value is extracted from the ST_CoveredBy(ST_ConvexHull(raster)) constraint on this raster column.  <span style="font-style: italic;">The constraint is typically named enforce_max_extent_&lt;r_raster_column&gt;.</span></TD>
    3937                 </TR>
    3938         </TBODY>
    3939 </TABLE>
    3940
    3941 }}}
    3942
    3943 Raster constraints can be set using one of the !AddRasterConstraints functions.
    3944
    3945 1. !AddRasterConstraints (
    3946         rastschema name,[[BR]]
    3947         rasttable name,[[BR]]
    3948         rastcolumn name,[[BR]]
    3949         VARIADIC constraints text[]
    3950 )
    3951
    3952         constraints: keywords indicating constraint to attempt to add.  possible keywords are:
    3953
    3954 {{{
    3955 srid
    3956 scale_x or scalex
    3957 scale_y or scaley
    3958 scale
    3959 blocksize_x or blocksizex or width
    3960 blocksize_y or blocksizey or height
    3961 blocksize
    3962 same_alignment or samealignment or alignment
    3963 regular_blocking or regularblocking
    3964 num_bands or numbands
    3965 pixel_types or pixeltypes
    3966 nodata_values or nodatavalues or nodata
    3967 out_db or outdb
    3968 extent
    3969 }}}
    3970
    3971 {{{
    3972 SELECT AddRasterConstraints('schema', 'table', 'rast', 'srid', 'extent')
    3973 }}}
    3974
    3975 2. !AddRasterConstraints (
    3976         rasttable name,[[BR]]
    3977         rastcolumn name,[[BR]]
    3978         VARIADIC constraints text[]
    3979 )
    3980
    3981 3. !AddRasterConstraints (
    3982         rastschema name,[[BR]]
    3983         rasttable name,[[BR]]
    3984         rastcolumn name,[[BR]]
    3985         srid boolean DEFAULT TRUE,[[BR]]
    3986         scale_x boolean DEFAULT TRUE,[[BR]]
    3987         scale_y boolean DEFAULT TRUE,[[BR]]
    3988         blocksize_x boolean DEFAULT TRUE,[[BR]]
    3989         blocksize_y boolean DEFAULT TRUE,[[BR]]
    3990         same_alignment boolean DEFAULT TRUE,[[BR]]
    3991         regular_blocking boolean DEFAULT FALSE,[[BR]]
    3992         num_bands boolean DEFAULT TRUE,[[BR]]
    3993         pixel_types boolean DEFAULT TRUE,[[BR]]
    3994         nodata_values boolean DEFAULT TRUE,[[BR]]
    3995         out_db boolean DEFAULT TRUE,[[BR]]
    3996         extent boolean DEFAULT TRUE
    3997 )
    3998
    3999 4. !AddRasterConstraints (
    4000         rasttable name,[[BR]]
    4001         rastcolumn name,[[BR]]
    4002         srid boolean DEFAULT TRUE,[[BR]]
    4003         scale_x boolean DEFAULT TRUE,[[BR]]
    4004         scale_y boolean DEFAULT TRUE,[[BR]]
    4005         blocksize_x boolean DEFAULT TRUE,[[BR]]
    4006         blocksize_y boolean DEFAULT TRUE,[[BR]]
    4007         same_alignment boolean DEFAULT TRUE,[[BR]]
    4008         regular_blocking boolean DEFAULT FALSE,[[BR]]
    4009         num_bands boolean DEFAULT TRUE,[[BR]]
    4010         pixel_types boolean DEFAULT TRUE,[[BR]]
    4011         nodata_values boolean DEFAULT TRUE,[[BR]]
    4012         out_db boolean DEFAULT TRUE,[[BR]]
    4013         extent boolean DEFAULT TRUE
    4014 )
    4015
    4016 Though users can manually remove raster constraints, it is easier to use one of the !DropRasterConstraints functions
    4017
    4018 1. !DropRasterConstraints (
    4019         rastschema name,[[BR]]
    4020         rasttable name,[[BR]]
    4021         rastcolumn name,[[BR]]
    4022         VARIADIC constraints text[]
    4023 )
    4024
    4025         constraints: the same keywords as function !#1 for !AddRasterConstraints
    4026
    4027 2. !DropRasterConstraints (
    4028         rasttable name,[[BR]]
    4029         rastcolumn name,[[BR]]
    4030         VARIADIC constraints text[]
    4031 )
    4032
    4033 3. !DropRasterConstraints (
    4034         rastschema name,[[BR]]
    4035         rasttable name,[[BR]]
    4036         rastcolumn name,[[BR]]
    4037         srid boolean DEFAULT TRUE,[[BR]]
    4038         scale_x boolean DEFAULT TRUE,[[BR]]
    4039         scale_y boolean DEFAULT TRUE,[[BR]]
    4040         blocksize_x boolean DEFAULT TRUE,[[BR]]
    4041         blocksize_y boolean DEFAULT TRUE,[[BR]]
    4042         same_alignment boolean DEFAULT TRUE,[[BR]]
    4043         regular_blocking boolean DEFAULT TRUE,[[BR]]
    4044         num_bands boolean DEFAULT TRUE,[[BR]]
    4045         pixel_types boolean DEFAULT TRUE,[[BR]]
    4046         nodata_values boolean DEFAULT TRUE,[[BR]]
    4047         out_db boolean DEFAULT TRUE,[[BR]]
    4048         extent boolean DEFAULT TRUE
    4049 )
    4050
    4051 4. !DropRasterConstraints (
    4052         rasttable name,[[BR]]
    4053         rastcolumn name,[[BR]]
    4054         srid boolean DEFAULT TRUE,[[BR]]
    4055         scale_x boolean DEFAULT TRUE,[[BR]]
    4056         scale_y boolean DEFAULT TRUE,[[BR]]
    4057         blocksize_x boolean DEFAULT TRUE,[[BR]]
    4058         blocksize_y boolean DEFAULT TRUE,[[BR]]
    4059         same_alignment boolean DEFAULT TRUE,[[BR]]
    4060         regular_blocking boolean DEFAULT TRUE,[[BR]]
    4061         num_bands boolean DEFAULT TRUE,[[BR]]
    4062         pixel_types boolean DEFAULT TRUE,[[BR]]
    4063         nodata_values boolean DEFAULT TRUE,[[BR]]
    4064         out_db boolean DEFAULT TRUE,[[BR]]
    4065         extent boolean DEFAULT TRUE
    4066 )
    4067
    4068
    4069
    4070 The raster_overviews view is structured as the following:
    4071
    4072 {{{
    4073 #!html
    4074 <TABLE BORDER=1>
    4075         <THEAD>
    4076                 <TR>
    4077                         <TD ALIGN=LEFT style="font-weight: bold; font-style: italic;">Column</TD>
    4078                         <TD ALIGN=LEFT style="font-weight: bold; font-style: italic;">PostgreSQL Type</TD>
    4079                         <TD ALIGN=LEFT style="font-weight: bold; font-style: italic;">Description</TD>
    4080                 </TR>
    4081         </THEAD>
    4082         <TBODY>
    4083                 <TR>
    4084                         <TD ALIGN=LEFT>o_table_catalog</TD>
    4085                         <TD ALIGN=LEFT>name</TD>
    4086                         <TD ALIGN=LEFT>Name of the database containing the table with the overview column.</TD>
    4087                 </TR>
    4088                 <TR>
    4089                         <TD ALIGN=LEFT>o_table_schema</TD>
    4090                         <TD ALIGN=LEFT>name</TD>
    4091                         <TD ALIGN=LEFT>Name of the schema containing the table with the overview column.</TD>
    4092                 </TR>
    4093                 <TR>
    4094                         <TD ALIGN=LEFT>o_table_name</TD>
    4095                         <TD ALIGN=LEFT>name</TD>
    4096                         <TD ALIGN=LEFT>Name of the table containing a column of type raster considered an overview.</TD>
    4097                 </TR>
    4098                 <TR>
    4099                         <TD ALIGN=LEFT>o_raster_column</TD>
    4100                         <TD ALIGN=LEFT>name</TD>
    4101                         <TD ALIGN=LEFT>Name of the overview column in the table. All attribute columns following this column apply to the rasters in this column.  <span style="font-weight: bold; font-style: italic;">This column was previously known as o_column.</span></TD>
    4102                 </TR>
    4103                 <TR>
    4104                         <TD ALIGN=LEFT>r_table_catalog</TD>
    4105                         <TD ALIGN=LEFT>name</TD>
    4106                         <TD ALIGN=LEFT>Name of the database containing the table with the raster column from which this overview column was derived.</TD>
    4107                 </TR>
    4108                 <TR>
    4109                         <TD ALIGN=LEFT>r_table_schema</TD>
    4110                         <TD ALIGN=LEFT>name</TD>
    4111                         <TD ALIGN=LEFT>Name of the schema containing the table with the raster column from which this overview column was derived.</TD>
    4112                 </TR>
    4113                 <TR>
    4114                         <TD ALIGN=LEFT>r_table_name</TD>
    4115                         <TD ALIGN=LEFT>name</TD>
    4116                         <TD ALIGN=LEFT>Name of the table containing a column of type raster from which this overview column was derived.</TD>
    4117                 </TR>
    4118                 <TR>
    4119                         <TD ALIGN=LEFT>r_raster_column</TD>
    4120                         <TD ALIGN=LEFT>name</TD>
    4121                         <TD ALIGN=LEFT>Name of the raster column in the table from which this overview column was derived.  <span style="font-weight: bold; font-style: italic;">This column was previously known as r_column.</span></TD>
    4122                 </TR>
    4123                 <TR>
    4124                         <TD ALIGN=LEFT>overview_factor</TD>
    4125                         <TD ALIGN=LEFT>integer</TD>
    4126                         <TD ALIGN=LEFT>The factor used to compute the overviews in this column.  If the factor is 2, the overviews' scale is 2x of the reference rasters.  </TD>
    4127                 </TR>
    4128         </TBODY>
    4129 </TABLE>
    4130 }}}
    4131
    4132 '''One column has been removed from the raster_overviews views: out_db.'''
    4133
    4134 As all overviews are rasters, overviews will have have a record in raster_columns and another record in raster_overviews.
    4135
    4136 The distinguishing factor that makes a raster be treated as an overview is the ''enforce_overview_<o_raster_column>'' constraint.  The constraint can be applied using one of the !AddOverviewConstraints functions.  '''The overview constraint checks that the reference raster column and table exists.  If the reference raster column does not exist, the constraint is violated.'''
    4137
    4138 1. !AddOverviewConstraints (
    4139         ovschema name, ovtable name, ovcolumn name,[[BR]]
    4140         refschema name, reftable name, refcolumn name,[[BR]]
    4141         ovfactor int
    4142 )
    4143
    4144 2. !AddOverviewConstraints (
    4145         ovtable name, ovcolumn name,[[BR]]
    4146         reftable name, refcolumn name,[[BR]]
    4147         ovfactor int
    4148 )
    4149
    4150 To drop an overview constraint, use !DropOverviewConstraints.
    4151
    4152 1. !DropOverviewConstraints (
    4153         ovschema name,[[BR]]
    4154         ovtable name,[[BR]]
    4155         ovcolumn name
    4156 )
    4157
    4158 2. !DropOverviewConstraints (
    4159         ovtable name,[[BR]]
    4160         ovcolumn name
    4161 )
    4162
    4163
    4164 ~~Following the conversion of geometry_columns to a view in PostGIS, it is planned to do the same with raster_column and raster_overview for the raster part. Converting to a view has a number of advantages:
    4165
    4166 ~~ * The raster_column view rows will always be in synch with the existing list raster columns.
    4167
    4168 ~~ * All the information will be trustworthy because it will be enforced by constraints, so people can't change the band types etc... without changing the constraints. The raster_columns information will always be correct or null (if the constraint can not be applied).
    4169
    4170 ~~ * Idem for the raster_overview table.
    4171
    4172 ~~PostGIS is using the typmod feature of PostgreSQL to 'store' metadata about a table and then display them in the geometry_column view. Unfortunately the typmod is limited to XXX bytes and there is too much information to 'store' about a raster table to use typmod. PostGIS raster will therefore use another approach consisting of 'storing' metadata about a raster table as constraints on the table. A set of constraints will be applied to a raster table and those constraints will be read and displayed by the raster_column view.
    4173
    4174 ~~The '''major changes concerning the raster_column table''' are as follow:
    4175
    4176 ~~ * There will be a flexible !AddRasterConstraint() function trying to add a set of constraint on a table. As for any constraint, each constraint will be successfully applied only when all the rows of the table fulfill this constraint. The list of potential constraint applied by the C loader (using the !AddRasterConstraint function) and hence the list of column available in the raster_column view will be: srid int, samealignment boolean, scalex float8, scaley float8, width int, height int, numberofbands int, pixeltypes text[], nodatavalues float[] in addition to the 'r_table_catalog', 'r_table_schema', 'r_table_name' and 'r_column' columns. There is still discussion about if global extent as a geometry should be added to this list. Comments are welcome.
    4177
    4178 ~~ * The raster_column view rows will be determined by querying the PostgreSQL catalog. A typical query exists for this.
    4179
    4180 ~~ * The raster_column view will derive columns of metadata from the constraints applied to each table listed. When a constraint does not exist (because it could not be applied successfully to the table by !AddRasterconstraint()), the column corresponding to this constraint for this table will be null.
    4181
    4182 ~~The '''major changes concerning the raster_overview table''' are as follow:
    4183
    4184 ~~ * The raster_overview table will also be replaced by a raster_overview view.
    4185
    4186 ~~ * We will provide a new function to support the creation of the raster_overview view and application of three additional constraints specific to overviews (!AddOverviewConstraints). These three additional constraints are: 'reference raster table oid', 'overview factor' and 'global extent'. Those constraints will be displayed by the raster_overview view as 'r_table_catalog', 'r_table_schema', 'r_table_name', 'r_column', 'overview_factor' and 'global_extent' in addition to the 'o_table_catalog', 'o_table_schema', 'o_table_name' and 'o_column' columns.
    4187
    4188 ~~ * We will also provide a SQL function for creating overviews (ST_CreateOverview(schemaname text, tablename teat, columnname, factor int)).
    4189
    4190 ~~ * The raster_overview view will NOT be created by default by the rtpostgis.sql script. It will be the responsibility of applications to use the !AddOverviewConstraints and ST_CreateOverview() function to create the raster_overviews view and create overviews.
    4191
    4192 ~~The '''major changes concerning the raster2pgsql loader''' are as follow:
    4193
    4194 ~~ * We are working on a new C importer to get rid of any Python, Numpy and Python GDAL Binding dependency which is a major obstacle to successful installation of PostGIS 2.0.
    4195
    4196 ~~ * This new loader will attempt to add the constraints on the loaded table using the !AddRasterConstraint() function. There will be an option to NOT try to add the constraint for applications preferring to have no constraint applied to the tables over having a raster_column view filled with the proper information.
    4197
    4198 ~~ * This new importer will NOT have any option to create the raster_overview view, nor to create overview tables as we leave this to the application. We also think that it is more important to be able to create overviews in SQL as a post loading process query so overviews can be updated/recreated when rasters tiles are edited, added or deleted. Application wishing to create overview can implement their own overview creation code or just use the future ST_CreateOverview() SQL function.
    4199
    4200 ~~ * We will stop supporting the old raster2pgsql.py which was creating overview tables and filling the raster_overview table. It will be available in the script/python folder for people wishing to create overviews after a slight addaptation (to the new !AddRasterConstraints() and !AddOverviewConstraints() functions).
