Changes between Version 207 and Version 208 of WKTRaster/SpecificationWorking03
07/24/12 13:42:57 (13 years ago)
pracine
  • TabularUnified WKTRaster/SpecificationWorking03
    v207 v208
    1818== ''Note that accomplished objectives have been moved at the bottom of the page.'' ==
    1919
    20 ----
    21 == '''Objective 2.0.04 - Implement better support for NULL, Empty, !HasNoBand(rast), !HasNoBand(rast, band) and !BandIsNoData rasters in all functions.''' ==
    23  Each function should better handle NULL rasters, empty rasterm rasters with no band and bands only filled with nodata values.
    25   1) Generally, when NULL rasters are provided, return NULL. If the function involves a second non NULL raster and something can be done with it, do it.
    27   2) Generally, when empty rasters are provided (ST_IsEmpty, width=0 or height=0), return an empty raster. If the function involves a second non empty raster and something can be done with it, do it.
    28
    29   2) Generally, when a !HasNoBand(rast) or a !HasNoBand(rast, band) raster is provided return a raster with no band but with the right extent. If the function involves a second raster having a band or the band, treat the first missing band like a !BandIsNoData.
    30
    31   4) A !BandIsNoData raster is a normal raster but many functions can be optimized with this type of raster.
    32
    33   5) All functions having missing the requested information (about its extent when it is a NULL or an empty raster or about its band when it is a !HasNoBand(rast) or a !HasNoBand(rast, band) raster) should return NULL or a documented value.
    34
    35   6) Try as less as possible to return EXCEPTION (or ERROR).
    36
    37  See discussion in http://trac.osgeo.org/postgis/ticket/594
    38
    39 '''ST_IsEmpty(rast) -> boolean'''
    40
    41  Returns TRUE if the raster width or the raster height is 0.
    42
    43 '''ST_HasNoBand'''
    44
    45  '''Variants'''
    46
    47   1) ST_HasNoBand(rast, band) -> boolean
    48
    49   2) ST_HasNoBand(rast) -> boolean
    50
    51  Returns TRUE if the the raster does not have this band.
    52
    53  Variant 2 returns TRUE if the the raster does not have any band.
    54
    55 '''ST_BandIsNoData'''
    56
    57  '''Variants'''
    58
    59   1) ST_BandIsNoData(rast, band) -> boolean
    60
    61   2) ST_BandIsNoData(rast) -> boolean
    62
    63  Returns TRUE if the specified raster band is only filled with no data value.
    64
    65  Variant 2 default to band 1.
    66
    67  '''Implementation details'''
    68
    69  This require a new flag to be set in the core at import and at edition. See discussion in http://trac.osgeo.org/postgis/ticket/593
    7020
    7121----
    510460
    511461----
     462== '''Objective FV.22 - Implement better support for NULL, Empty, !HasNoBand(rast), !HasNoBand(rast, band) and !BandIsNoData rasters in all functions.''' ==
     463
     464 Each function should better handle NULL rasters, empty rasterm rasters with no band and bands only filled with nodata values.
     465
     466  1) Generally, when NULL rasters are provided, return NULL. If the function involves a second non NULL raster and something can be done with it, do it.
     467
     468  2) Generally, when empty rasters are provided (ST_IsEmpty, width=0 or height=0), return an empty raster. If the function involves a second non empty raster and something can be done with it, do it.
     469
     470  2) Generally, when a !HasNoBand(rast) or a !HasNoBand(rast, band) raster is provided return a raster with no band but with the right extent. If the function involves a second raster having a band or the band, treat the first missing band like a !BandIsNoData.
     471
     472  4) A !BandIsNoData raster is a normal raster but many functions can be optimized with this type of raster.
     473
     474  5) All functions having missing the requested information (about its extent when it is a NULL or an empty raster or about its band when it is a !HasNoBand(rast) or a !HasNoBand(rast, band) raster) should return NULL or a documented value.
     475
     476  6) Try as less as possible to return EXCEPTION (or ERROR).
     477
     478 See discussion in http://trac.osgeo.org/postgis/ticket/594
     479
     480'''ST_IsEmpty(rast) -> boolean'''
     481
     482 Returns TRUE if the raster width or the raster height is 0.
     483
     484'''ST_HasNoBand'''
     485
     486 '''Variants'''
     487
     488  1) ST_HasNoBand(rast, band) -> boolean
     489
     490  2) ST_HasNoBand(rast) -> boolean
     491
     492 Returns TRUE if the the raster does not have this band.
     493
     494 Variant 2 returns TRUE if the the raster does not have any band.
     495
     496'''ST_BandIsNoData'''
     497
     498 '''Variants'''
     499
     500  1) ST_BandIsNoData(rast, band) -> boolean
     501
     502  2) ST_BandIsNoData(rast) -> boolean
     503
     504 Returns TRUE if the specified raster band is only filled with no data value.
     505
     506 Variant 2 default to band 1.
     507
     508 '''Implementation details'''
     509
     510 This require a new flag to be set in the core at import and at edition. See discussion in http://trac.osgeo.org/postgis/ticket/593
     511
     512----
    512513== '''Other functions''' ==
    513514
    521522
    522523== Accomplished objectives ==
    523
