Changes between Version 233 and Version 234 of WKTRaster/SpecificationWorking03
- 08/27/12 10:57:47 (13 years ago)
TabularUnified WKTRaster/SpecificationWorking03
v233 v234 118 118 2) Functions searching for the pixel value in a vector coverage. This is the same principle as ST_UnionToRaster() and ST_BurnToRaster(). 119 119 120 3) Functions aggregating pixel values from a raster neighborhood. This is the same principle as ST_MapAlgebraFctNbg() except that the rasters do not have to be aligned(nice advantage!).121 122 4) Functions aggregating pixel values from a neighborhood. This is the only way to do that.120 3) Functions aggregating pixel values from a raster neighborhood. This is the same principle as ST_MapAlgebraFctNbg() except that the target raster do not have to be aligned with the source raster (nice advantage!). 121 122 4) Functions aggregating pixel values from a vector neighborhood. This is the only way to do that. 123 123 124 124 5) Functions deriving metric values from a raster or a geometry coverage. This is very similar to the two previous items but the result is not an aggregate value. e.g. Distance to something. … … 128 128 * Some examples of such custom functions exists: 129 129 130 * ST_FasterUnion('schemaname', 'tablename', 'rastercolumnname'), a n alternative to ST_Union(rast, 'LAST') - Merge all the tiles of a table together into a single raster. This function is described [http://geospatialelucubrations.blogspot.fr/2012/07/a-slow-yet-1000x-faster-alternative-to.html here]. this function is dependent on the ST_FirstRasterValue4ma() ST_MapAlgebraFct() custom function.130 * ST_FasterUnion('schemaname', 'tablename', 'rastercolumnname'), a temporary alternative to ST_Union(rast, 'LAST') - Merge all the tiles of a table together into a single raster. This function act as a wrapper around the ST_FirstRasterValue4ma() ST_MapAlgebraFct() custom function and is described [http://geospatialelucubrations.blogspot.fr/2012/07/a-slow-yet-1000x-faster-alternative-to.html here]. 131 131 132 132 * ST_FirstGeomValue4ma() - Get the value from a specified column from the first geometry intersecting with the shape of the pixel (See [http://postgis.refractions.net/pipermail/postgis-users/2012-April/033875.html this post to postgis-users]) … … 134 134 * Other possible functions: 135 135 136 * ST_GeomToRaster('schemaname', 'tablename', 'geomolumnname', 'METHOD') - A generalization of ST_FirstGeomValue4ma() described above but accepting more methods of value extraction, depending on the type of coverage we want to extract from. This is very much like doing an intersection (actually more like an "identify" overlay operation) between a raster and a vector coverage. 136 * ST_GeomToRaster('schemaname', 'tablename', 'geomolumnname', 'METHOD') (Category 2) - A generalization of ST_FirstGeomValue4ma() described above but accepting more methods of value extraction, depending on the type of coverage we want to extract from. This is very much like doing an intersection (actually more like an "identify" overlay operation) between a raster and a vector coverage. 137 138 This function can further be generalised by adding parameters to define a buffer area around the pixel centroid or the pixel boundary. This would provide a category 4 type of function. 137 139 138 140 The METHOD could be: … … 143 145 144 146 * from a polygon coverage could also be MAX_AREA, MIN_AREA, AREA_RANGE, AREA_SUM, AREA_MEAN, AREA_STDDEV, COMBINED_MAX_AREA, COMBINED_MIN_AREA, COMBINED_MEAN_AREA, COMBINED_STDDEV_AREA, AREA_OF_POLYGON_WITH_GREATEST_VALUE, AREA_OF_POLYGON_WITH_SMALLEST_VALUE, AREA_OF_POLYGON_WITH_MOST_FREQUENT_VALUE, AREA_OF_LEAST_FREQUENT_VALUE, VALUE_OF_LARGEST, VALUE_OF_SMALLEST, VALUE_OF_COMBINED_LARGEST, VALUE_OF_COMBINED_SMALLEST, WEIGHTED_SUM, WEIGHTED_MEAN 147 148 * ST_EuclidianDistance() (see [http://trac.osgeo.org/postgis/wiki/PostGIS_Raster_SoC_Idea_2012/Distance_Analysis_Tools the GSoC project]) 145 149 146 150 ----
