Changes between Version 79 and Version 80 of WKTRaster/SpecificationWorking03
05/16/11 11:50:40 (14 years ago)
Bborie Park
ST_Histogram
  • TabularUnified WKTRaster/SpecificationWorking03
    v79 v80
    820820ST_ApproxMinMax('precip_2011', 'rast')
    821821}}}
     822
     823----
     824
     825'''ST_Histogram(raster, nband) -> set of records'''[[BR]]
     826ST_Histogram and ST_ApproxHistogram provide methods to determine a raster's data distribution.
     827
     828The return of ST_Histogram and ST_ApproxHistogram is a set of records where each record is (min, max, count, proportion).
     829
     830ST_Histogram has the following variations.
     831
     8321. ST_Histogram(rast raster, nband int, hasnodata boolean, bins int, width double precision[], right boolean) -> set of records
     833
     834  returns set of records of four columns (min, max, count, proportion)
     835
     836  nband: index of band to process on
     837
     838  hasnodata: if FALSE, any pixel who's value is nodata is ignored.
     839
     840  bins: the number of categories/bins to have in the histogram. If NULL or value less than one, the number of categories will be auto-computed using Sturges' formula if the number of values >= 30 or Square-root choice if number of values < 30.
     841
     842    http://en.wikipedia.org/wiki/Histogram#Mathematical_definition
     843
     844  width: an array indicating the width of each category/bin. If the number of bins is greater than the number of widths, the widths are repeated. Example: 9 bins, widths are [a, b, c] will have the output be [a, b, c, a, b, c, a, b, c].
     845
     846  right: compute the histogram from the right rather than from the left (default). This changes the criteria for evaluating a value x from [a, b) to (a, b].
     847
     848{{{
     849ST_Histogram(rast, 2, FALSE, NULL, NULL, FALSE)
     850
     851ST_Histogram(rast, 1, TRUE, 100, NULL, FALSE)
     852
     853ST_Histogram(rast, 2, FALSE, NULL, ARRAY[100, 50], FALSE)
     854
     855ST_Histogram(rast, 2, FALSE, 9, ARRAY[1000], TRUE)
     856
     857ST_Histogram(rast, 2, FALSE, 20, ARRAY[100, 200, 300], TRUE)
     858}}}
     859
     8602. ST_Histogram(rast raster, nband int, hasnodata boolean, bins int, right boolean) -> set of records
     861
     862  parameter "width" is not specified thus resulting in all bins having the same widths
     863
     864{{{
     865ST_Histogram(rast, 2, FALSE, 5, FALSE)
     866}}}
     867
     8683. ST_Histogram(rast raster, nband int, hasnodata boolean, bins int) -> set of records
     869
     870  the parameter "right" is removed and assumed to be FALSE
     871
     872{{{
     873ST_Histogram(rast, 2, FALSE, 5)
     874}}}
     875
     8764. ST_Histogram(rast raster, nband int, hasnodata boolean) -> set of records
     877
     878  the parameter "bins" is removed and set to NULL.  The function will compute the number of bins to use
     879
     8805. ST_Histogram(rast raster, nband int) -> set of records
     881
     882  parameter "hasnodata" is removed and assumed to be FALSE
     883
     8846. ST_Histogram(rast raster) -> set of records
     885
     886  assumes that nband is 1.
     887
     8887. ST_Histogram(rast raster, nband int, bins int, width double precision[], right boolean) -> set of records
     889
     890  hasnodata is assumed to be FALSE
     891
     8928. ST_Histogram(rast raster, nband int, bins int, right boolean) -> set of records
     893
     894  all bins will have equal widths
     895
     8969. ST_Histogram(rast raster, nband int, bins int) -> set of records
     897
     898  right is assumed to be FALSE
     899
     900ST_ApproxHistogram should have the following variations.
     901
     9021. ST_ApproxHistogram(rast raster, nband int, hasnodata boolean, sample_percent double precision, bins int, width double precision[], right boolean) -> set of record
     903
     904    sample_percent: a value between 0 and 1 indicating the percentage of the raster band's pixels to consider when generating the histogram.
     905
     906{{{
     907ST_Histogram(rast, 2, FALSE, 0.1, NULL, NULL, FALSE)
     908
     909ST_Histogram(rast, 1, TRUE, 1, 100, NULL, FALSE)
     910
     911ST_Histogram(rast, 2, FALSE, 0.2, NULL, ARRAY[100, 50], FALSE)
     912
     913ST_Histogram(rast, 2, FALSE, 0.25, 9, ARRAY[1000], TRUE)
     914
     915ST_Histogram(rast, 2, FALSE, 0.05, 20, ARRAY[100, 200, 300], TRUE)
     916}}}
     917
     9182. ST_ApproxHistogram(rast raster, nband int, hasnodata boolean, sample_percent double precision, bins int, right boolean) -> set of records
     919
     920  parameter "width" is not specified thus resulting in all bins having the same widths
     921
     9223. ST_ApproxHistogram(rast raster, nband int, hasnodata boolean, sample_percent double precision, bins int) -> set of records
     923
     924  the parameter "right" is removed and assumed to be FALSE
     925
     926{{{
     927ST_ApproxHistogram(rast, 2, FALSE, 5)
     928}}}
     929
     9304. ST_ApproxHistogram(rast raster, nband int, hasnodata boolean, sample_percent double precision) -> set of records
     931
     932  the parameter "bins" is removed and set to NULL so that function can compute the number of bins to use
     933
     9345. ST_ApproxHistogram(rast raster, nband int, sample_percent double precision) -> set of records
     935
     936  parameter "hasnodata" is removed and assumed to be FALSE
     937
     9386. ST_ApproxHistogram(rast raster, nband int) -> set of records
     939
     940  assumes that sample_percent is 0.1
     941
     9427. ST_ApproxHistogram(rast raster, sample_percent double_precision) -> set of records
     943
     944  assumes that nband is 1
     945
     9468. ST_ApproxHistogram(rast raster) -> set of records
     947
     948  assumes that nband is 1 and sample_percent is 0.1
     949
     9509. ST_ApproxHistogram(rast raster, nband int, sample_percent double precision, bins int, width double precision[], right boolean) -> set of records
     951
     952  hasnodata is assumed to be FALSE
     953
     95410. ST_ApproxHistogram(rast raster, nband int, sample_percent double precision, bins int, right boolean) -> set of records
     955
     956  all bins will have equal widths
     957
     95811. ST_ApproxHistogram(rast raster, nband int, sample_percent double precision, bins int) -> set of records
     959
     960  right is assumed to be FALSE
    822961
    823962----
