Changes between Version 63 and Version 64 of WKTRasterTutorial01
- 06/15/10 13:29:45 (15 years ago)
WKTRasterTutorial01
v63 v64 33 33 * The first dataset is a point shapefile of 814 caribou observations done by airplane in the northern part of the province of Quebec by the provincial ministry of natural ressources between 1999 and 2005. We will see later in the tutorial how you can easily produce a similar point cover. 34 34 35 * The second dataset is a series of 13 SRTM elevation rasters covering most of the province of Quebec. These free rasters, available on the web, are 6000x6000 pixels each, have a pixel size of about 60 x 90 meters and weight a total of 900 MB once unzipped. There are many versions of SRTM. We choose the one at ftp://srtm.csi.cgiar.org/ . You can find a pretty good description of this dataset in Wikipedia (http://en.wikipedia.org/wiki/SRTM).35 * The second dataset is a series of 13 SRTM elevation rasters covering most of the province of Quebec. These free rasters, available on the web, are 6000x6000 pixels each, have a pixel size of about 60 x 90 meters and weight a total of 900 MB once unzipped. There are many versions of SRTM. We choose the one at ftp://srtm.csi.cgiar.org/SRTM_v41/SRTM_Data_GeoTIFF/ . You can find a pretty good description of this dataset in Wikipedia (http://en.wikipedia.org/wiki/SRTM). 36 36 37 37 We will import the shapefile and the raster coverage into PostGIS, create buffers around each point and then intersect those buffers with the elevation coverage in order to get a weighted mean elevation for each buffer. We will have a graphical look at the different results along the way using OpenJUMP.
