Changes between Version 76 and Version 77 of WKTRasterTutorial01
- 06/29/10 13:32:20 (15 years ago)
WKTRasterTutorial01
v76 v77 69 69 == Visualizing the caribou point in OpenJUMP == 70 70 71 [[Image( buffers.gif, align=right, 50%)]]The favorite tool of the PostGIS community to display geometries loaded into PostGIS is OpenJUMP. This java open source software is very easy to install and work very well with PostGIS. Once OpenJUMP have been installed, you can view the caribou points by following these steps:71 [[Image(WKTRasterViewOf814buffers.gif, align=right, 50%)]]The favorite tool of the PostGIS community to display geometries loaded into PostGIS is OpenJUMP. This java open source software is very easy to install and work very well with PostGIS. Once OpenJUMP have been installed, you can view the caribou points by following these steps: 72 72 73 73 1. Start OpenJUMP and select "Layer->Run Datastore Query" from the menu.
