Changes between Version 213 and Version 214 of WikiStart
01/31/20 08:09:50 (5 years ago)
Algunenano
Change the icons of Jenkins builds to the proper branches
  • TabularUnified WikiStart
    v213 v214
    2323|| [[Image(https://secure.travis-ci.org/postgis/postgis.svg?branch=master, link=https://travis-ci.org/postgis/postgis?branch=master, alt=status, height="20")]] ||\
    2424|| [[Image(https://gitlab.com/postgis/postgis/badges/master/pipeline.svg, link=https://gitlab.com/postgis/postgis/commits/master, alt=status, title='PG 11.1, GDAL 2.4.0, GEOS 3.7.1, PROJ 5.2.0')]] ||\
    25 || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie&BRANCH=trunk, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie, alt=status, height="20", title='PG 10.1(branch), GDAL 2.1 branch, GEOS 3.6')]] ||\
    26 || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie32&BRANCH=trunk, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32, alt=status, height="20", title='PG 10.1(branch), GDAL 2.1 branch, GEOS 3.6')]] ||\
    27 || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie&BRANCH=trunk, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] ||
     25|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie&build=last:${params.reference=refs/heads/master}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie, alt=status, height="20", title='PG 10.1(branch), GDAL 2.1 branch, GEOS 3.6')]] ||\
     26|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie32&build=last:${params.reference=refs/heads/master}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32, alt=status, height="20", title='PG 10.1(branch), GDAL 2.1 branch, GEOS 3.6')]] ||\
     27|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie&build=last:${params.reference=refs/heads/master}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] ||
    2828||= '''3.0''' =|| \
    2929|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_3.0, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_3.0/, alt=status, height="20", title='PG 9.3-12(branch), GDAL 2.3 branch, GEOS 2.4')]] || \
    3232|| [[Image(https://secure.travis-ci.org/postgis/postgis.svg?branch=stable-3.0, link=https://travis-ci.org/postgis/postgis?branch=stable-3.0, alt=status, height="20")]] ||\
    3333|| [[Image(https://gitlab.com/postgis/postgis/badges/stable-3.0/pipeline.svg, link=https://gitlab.com/postgis/postgis/commits/stable-3.0, alt=status, height="20", title='PG 9.6.10, GDAL 2.1.2, GEOS 3.5.1, PROJ 4.9.3')]] ||\
    34 || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie&BRANCH=3.0, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie, alt=status, height="20", title='PG 10.1(branch), GDAL 2.1 branch, GEOS 3.6')]] ||\
    35 || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie32&BRANCH=3.0, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32, alt=status, height="20", title='PG 10.1(branch), GDAL 2.1 branch, GEOS 3.6')]] ||\
    36 || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie&BRANCH=3.0, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] ||
     34|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie&build=last:${params.reference=refs/heads/stable-3.0}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie, alt=status, height="20", title='PG 10.1(branch), GDAL 2.1 branch, GEOS 3.6')]] ||\
     35|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie32&build=last:${params.reference=refs/heads/stable-3.0}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32, alt=status, height="20", title='PG 10.1(branch), GDAL 2.1 branch, GEOS 3.6')]] ||\
     36|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie&build=last:${params.reference=refs/heads/stable-3.0}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] ||
    3737||= '''2.5''' =|| \
    3838|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_2.5, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_2.5/, alt=status, height="20", title='PG 9.3-12(branch), GDAL 2.3 branch, GEOS 2.4')]] || \
