21 | | ||= '''Berrie64''' [[br]] ,,''Rasberry Pi 64-bit[[br]](Debian Buster)[[br]]gcc 8.3.0[[br]]PG 13-15 (>=3.0 only 1 PG version depends on branch)[[br]]GDAL 2.4.0[[br]]GEOS 3.9-main (depends on branch)[[br]]Proj 5.2.0'',, =|| |
| 21 | ||= '''Berrie64''' [[br]] ,,''Rasberry Pi 64-bit[[br]](Debian Buster)[[br]]gcc 8.3.0[[br]]PG 13-15 (>=3.0 only 1 PG version depends on branch)[[br]]GDAL 2.4.0[[br]]GEOS 3.9-main (depends on branch)[[br]]Proj 5.2.0'',, =|| \ |
| 22 | ||= '''Cirrus CI''' [[br]] ,,''FreeBSD 64-bit[[br]](13.1 / 12.3)[[br]] clang 10.0.1[[br]]PG 13 [[br]]GDAL 2.4.0[[br]]GEOS 3.11 [[br]]PROJ: 8.2.1[[br]]SFCGAL: 1.4.1 |
| 23 | '',, || |
29 | 31 | || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie32&build=last:${params.reference=refs/heads/master}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32, alt=status, height="20", title='PG 13.7(branch), GDAL 3.5.0, GEOS 3.10.3')]] ||\ |
30 | 32 | || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie&build=last:${params.reference=refs/heads/master}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie, alt=status, height="20", title='PG 15(branch), GDAL 3.4.3 , GEOS 3.11')]] ||\ |
31 | | || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie64&build=last:${params.reference=refs/heads/master}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64, alt=status, height="20", title='PG 13(branch), GDAL 3.5 branch, GEOS 3.12')]] || |
| 33 | || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie64&build=last:${params.reference=refs/heads/master}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64, alt=status, height="20", title='PG 13(branch), GDAL 3.5 branch, GEOS 3.12')]] ||\ |
| 34 | || [[Image(https://api.cirrus-ci.com/github/postgis/postgis.svg?branch=master, link=https://cirrus-ci.com/github/postgis/postgis, alt=status, height="20", title='PG 13(branch), GDAL 3.5 branch, GEOS 3.12')]] || |
