40 | | For topogeoms, the user would need to specify the table to create, topology, and column, with default column name being topo if the user does not specify. This will behave more or less the same as geography/geometry loading. For the first pass, we will assume this will just use basic topo element types (areal, lineal, punctal) and will not use subelements. |
| 40 | For topogeoms, the user would need to specify the table to create, topology, and column, with default column name being ''topo'' if the user does not specify. This will behave more or less the same as geography/geometry loading. For the first pass, we will assume this will just use basic topo element types (areal, lineal, punctal) and will not use subelements. |
